Lift/suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GARSHA91, Jan 12, 2015.
  1. Jan 12, 2015 at 5:07 PM
    GARSHA91
    GARSHA91 [OP] YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    Anyone with suggestions or advice. Looking to get a 2014 double can short bed. I'm looking to do a 3" lift. Want to do a mid travel set up hopefully. Anyone with part suggestions or photos of their mid travel with details feel free to help. Looking at Dakar leafs but we will see what comes from the help. Thanks!
  2. Jan 13, 2015 at 2:00 PM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
    Here's what I did, in pursuit of a 3" lift:
    Bought the Old Man Emu kit that YotaDan sells via wheelersoffroad.com and specify in the order that you want 887 front coils with your kit AND pay extra to have the front coils assembled by the knowledgeable team at Wheelers Offroad prior to shipping them out to you. This is an extra $156 dollars and will save you from having to either buy a spring compressor that you will use exactly one time or taking them to be assembled by a half-wit part-timer at Pep Boys who will probably mess up your kit.
    The reason for the 887 coils is that it is a longer spring than the 885 coils, but are not stiffer. The 886 coils are the same length as the 885 coils but are much more rigid so you're going to feel every bump in the road right in your teeth if you get the 886 springs and don't put some extra weight on your truck to smooth them out.
    This is the kit I'm talking about BECAUSE YOU'RE GOING FOR 3" of lift, you are probably going to want to get a new set of upper control arms. I bought the Total Chaos ones from Wheelers, they were not the cheapest ones(Camburg), and they were not the most expensive ones(Icon). I read good things about Total Chaos and so I chose those.
    There are people who say you don't need new upper control arms with that amount of lift, but it doesn't hurt anything but your wallet to take the extra precaution against fucking up a set of tires due to alignment issues (which will cost you the same or more than just getting the set of UCA's in the first place).
    I installed the kit with the help of 1 other person myself. This was my first Taco lift kit install. It worked great, I was meticulous about the instructions and torque specs ... and when it was all done I put some 285/75/16 hankook tires on some Vision Manx wheels and got them aligned and only rubbed a little bit at half lock until I took the front factory flaps off the front.
  3. Jan 13, 2015 at 2:06 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
