LIFT/TIRES gas milage drop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rpoint16, Jun 23, 2008.
  1. Jun 23, 2008 at 7:46 AM
    rpoint16
    rpoint16 [OP] Well-Known Member
    Tempe, AZ
    2022 TRD Off-Road, Super White.
    Bone Stock
    Going with the run-of-the-mill 2 1/2" leveling kit, spacer/aal in back, 17"rims & tires... how much of a drop do you see in gas milage?
  2. Jun 23, 2008 at 8:11 AM
    Banchi94
    Banchi94 Well-Known Member
    Ron
    Parker, CO
    2008 Indigo Blue TRD Sport DCSB 4x4
    ToyTec 3" basic lift
    You probably won't see a change in gas mileage if you go with the stock tire size of 265/65/17. If you go any bigger, like a 285/70/17, you probably will see a drop of about 2 mpg - I don't have any backup data for this yet as I haven't calculated what I've been getting running on 285/70/17's.
  3. Jun 23, 2008 at 9:27 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    You have to remember also that your speedometer and odometer are going to be off with larger tires. You'll have to factor that in as well.
    With your tire change, you have about a 7% error. So if you wen't 250 miles according to your odometer, you'd have really gone 267.5 miles. If we assume it took 14 gallons to fill at that gas mileage, you'd indicate about 17.8 mpg (250/14) when in actuality you'd be getting 19.1 mpg (267.5/14).
  4. Jun 23, 2008 at 2:11 PM
    Banchi94
    Ron
    Parker, CO
    That might actually be a good thing! Having less miles than I've actually driven! Sweet! I might still get a calibrator, but debating if $240 is worth it.
    Thanks for the clarification!
