lift
Discussion in 'Suspension' started by edwin, Mar 11, 2011.
  1. Mar 11, 2011 at 3:03 PM
    edwin
    edwin [OP] New Member
    cv
    03tacoma
    hi guys, does bilstein 5100 makes your vehicle lifted or still need to buy lift kit? sorry, pretty new to truck world.
  2. Mar 11, 2011 at 3:10 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Welcome to TW
    The front ones have an adjustable spring perch that will preload your stock springs to achieve either 0.85", 1.75", or 2.5" of lift. the rear shocks do not provide lift, they only accommodate it. For the rear you can buy an add-a-leaf.
  3. Mar 11, 2011 at 3:16 PM
    757southpaw
    757southpaw Well-Known Member
    Jay
    757
    07' DC LB TRD Sport 4x4
    BAK BakFlip Tonneau cover, 30% front tinted windows, AVS vent shades, Black Billet Grill,Pop& Lock, secondary air filter removed, Goodyear Duratrac's, Billies @ 2.5" on front, Billies on back w/ 1.5" AAL, Toytec Diff drop, NOKYA Hyper Yellow fog light bulbs, LaminX Weathertechs, Rear diff breather mod, BHLM
    Welcome to TW! To answer your question, the 5100's are known as a leveling option lifting up to 2.5". No need for anything else up front if this is what you want to do. Adding a block or a set of AAL's will give you some lift in the back!
    Edit: I see that you're a 1st gen Tacoma. I'm not sure if what I said is correct in your case. Sorry
  4. Mar 11, 2011 at 10:21 PM
    edwin
    cv
    03tacoma
    thanks, will you recommend that kind of lift for my 03?
  5. Mar 12, 2011 at 7:49 AM
    KPT
    09 Prerunner
    yep
