lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by scyota03, Dec 11, 2011.
  1. Dec 11, 2011 at 3:10 PM
    scyota03
    scyota03 [OP] Well-Known Member
    sumter,southcarolina
    03 trd prerunner
    3 inch coil spiring spacer, front bull bar
    can i put the adjustable bilstein 5100 shocks on my truck with the factory springs and still be able to ajust the shocks for higher lift or do i need to buy the longer coil springs?
  2. Dec 11, 2011 at 3:13 PM
    98tacoma27
    Ben
    Not Beech Creek
    The 5100's are designed for stock coil use and lift coil use. You don't have to buy lift coils if you don't want to. They have 3 settings 0" (stock), 1.25", and 2.5". If you want to use lift coils, leave the spring perch at the 0" setting.
  3. Dec 11, 2011 at 3:50 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    If you leave the bilstein on setting 0" and run a longer coil, your ride will be smoother than just raising the setting to 2.5".
