lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaTSP4, Nov 3, 2009.
  1. Nov 3, 2009 at 12:04 PM
    TacomaTSP4
    TacomaTSP4 [OP] Go Big or Go Home!!
    Travis
    Rohnert Park, CA
    can i run a 2" aal, 1" block on a rear 5100's set at a 1" lift on a 2007 tacoma 4x4
  2. Nov 3, 2009 at 12:07 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    what r u asking? you an do a 2" aal and 5100 in the front, 1" block and 5100 in front, or the 2" aal and 1" block with the 5100 but idk why you would want to.
    go with a aal and the 5100's
  3. Nov 3, 2009 at 12:12 PM
    TacomaTSP4
    Travis
    Rohnert Park, CA
    ok ill do the 2" aal and 5100 in rear. can i run a 3" spacer in front with 5100 in front set at 1" or more?
  4. Nov 3, 2009 at 12:19 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    if u want the CV's to explode.....dont stack front lifts....and w/ the 4x4 u cant expect to get over 3" in the front w/o CV damage unless u go to the 4.5" RCD lift or a 6" drop bracket
  5. Nov 3, 2009 at 2:06 PM
    TacomaTSP4
    Travis
    Rohnert Park, CA
    whats the CV?
  6. Nov 3, 2009 at 2:06 PM
    The_Hodge
    SC
    the CVs are what works the front wheels for 4x4
  7. Nov 3, 2009 at 2:27 PM
    08pretaco
    az
    if you want the most lift in the front and have the money get spindles. lifting the front otherwise more than 3" is absolutely pointless to do. if you keep it at 3" or less do 5100's or ome coils.
    look into toyteclifts.com it will solve anything you need. they got kits for 300
  8. Nov 3, 2009 at 4:42 PM
    TacomaTSP4
    Travis
    Rohnert Park, CA
    yea i know bout toytec thats the 2" aal i have sitting in my garage.
    Yea im prob gunna buy the 5100's for the rear set at 1" of lift and put my aal in and run the revtek 3" spacer kit in the front for the time being with my trd bilsteins until i can buy coilovers or a 6" lift
  9. Nov 3, 2009 at 4:42 PM
    TacomaTSP4
    Travis
    Rohnert Park, CA
    i just want to get the most lift as i can before i have to buy a 6" lift kit cause i just dont have 2k right now for a 6" lift
  10. Nov 3, 2009 at 5:10 PM
    The_Hodge
    SC
    just an FYI, u cannot set lift on the rear 5100s....they accommodate up to 2" of lift, but they dont give lift themselves. only the front 5100s actually GIVE lift.
