Lifted 2016 Tacoma with OEM wheels?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hellapeno, Apr 11, 2016.
  1. Jun 25, 2017 at 11:34 PM
    #181
    hiloTACO808
    hiloTACO808 Member
    2016 Tacoma OR
    Cooper stt pros 285/75/16 spidertrax 1.25 spacers 3/1 level kit
    Catfish21, Powerprozeus and kgilly like this.
  2. Jun 26, 2017 at 4:02 AM
    #182
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    remember back in the 90's when Toyota started really building these trucks before the first gen in the mid 90's most of them came with 31x10.5x15's and had that wider stance and they looked really sweet and made the domestic small trucks look like crap...
    Blue taco 84 likes this.
  3. Jun 26, 2017 at 4:12 AM
    #183
    kgilly
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    so question for you? are the stock OR wheels 7" wide that you are putting the 285's on? my stock SR5 wheels are 7" wide and the 285's I thought should go on 7.5 to 8" rims?
    71tattooguy likes this.
  4. Jun 26, 2017 at 6:16 AM
    #184
    panda_taco
    panda_taco Well-Known Member
    SWFL
    '16 TRD Off-Road 4x4
    @trd-joe mind posting a picture of the truck from the front/front & side view with the spacers? Been contemplating spacers but want to see how it looks on one if possible sir! :bowdown:
  5. Jun 26, 2017 at 7:33 AM
    #185
    Powerprozeus
    Powerprozeus IG: @1987toyota4r
    Aaron
    Birmingham, AL
    2016 Quicksand TRD OR 4x4 / 1987 4Runner SR5
    I'm considering the same lift and now I'm sold. Definitely a good looking truck! What kind of sliders do you have installed?
    kgilly likes this.
  6. Jun 26, 2017 at 8:10 AM
    #186
    cragginshred
    cragginshred Well-Known Member
    Don Anderson
    2017 TRD Sport
    How much power is lost with the lift and larger tires?
    I am pulling a boat with my 2017 TRD V6.
    What is a mellow lift and tire size bump I could get away with and still not cause power suck?
    Also what is the scoop with a 'leveling' where I'm told the front end is brought up a bit to level it out?
  7. Jun 26, 2017 at 9:26 AM
    #187
    Camel89
    Camel89 Well-Known Member
    Houston, TX
    2016 TRD OR 4x4
    Thanks!
    They are the Marshall Offroad Fabrication hybrid sliders with kickout, at 10 degrees because I wanted to be able to use them as steps too. Normal is 15 or 20 degrees I think. @ETaco23 makes them.
    Powerprozeus[QUOTED] likes this.
  8. Jun 26, 2017 at 9:41 AM
    #188
    Powerprozeus
    Aaron
    Birmingham, AL
    Thank you! Those are sweet because I need a step myself to access the top of the shell.
    Camel89[QUOTED] likes this.
  9. Jun 26, 2017 at 6:24 PM
    #189
    cafreeman27
    cafreeman27 Member
    Arkansas
    2016 TRD Off Road 4x4
    Rough Country 3/2 lift, 285/75 16 BFG KO2s
    Yep these are the stock 7" wheels and they do just fine. I was worried about them not looking wide but they look good!
    No regrets at all. Once I wear this tires out I will be upgrading to new wheels and tires though.
  10. Jun 26, 2017 at 8:39 PM
    #190
    tarandus
    tarandus Well-Known Member
    Montucky
    '17 TRD DCab OR Supah White
    ProComp/Headstrong leveling kit, AllPro rock sliders.
    ProComp leveling kit 2.5" spacers front, HeadStrong 3 leaf AAL in rear. Ended up with .5" difference with rear slightly higher. Wanted a bit more rake, and not sure how much settling so we'll see. Towed horses this weekend and it worked great. 20170607_181005.jpg 20170607_181041.jpg Stock tires and rims, probably go with 275 Coopers or BFG KO2s when these wear out. I like the stock rims so will keep them.
  11. Jun 27, 2017 at 12:49 AM
    #191
    Polax
    Polax Well-Known Member
    Miami
    Toytec 2.5 with single AAL.
    Spider trax 1.25 inch wheel spacers
    Powerprozeus, 2k4Taco and kgilly like this.
  12. Jun 27, 2017 at 4:02 AM
    #192
    kgilly
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    did you replace the ECGS bushing?
    once my factory tires wear out I guess I am heading that way with a mild lift or leveling kit and some spacers to gain some more space...thanks for the info..
  13. Sep 8, 2017 at 5:54 PM
    #193
    hunter.tom
    hunter.tom Well-Known Member
    2016 tacoma trd off-road
    Sweet set up. Any lift here or just new wheels? Also, are you the real hickok45? Haha
  14. Sep 8, 2017 at 10:28 PM
    #194
    liquidhazelnuts
    liquidhazelnuts Well-Known Member
    2017 Tacoma TRD Off Road Quicksand
  15. Sep 13, 2017 at 6:42 PM
    #195
    G33k
    G33k Member
    South Texas
    Scion fr-s, future Tacoma owner
    Those are stock wheels some people have been getting them on the sr5 model iirc. I honestly really like those wheels.
    hunter.tom[QUOTED] likes this.
  16. Sep 18, 2017 at 7:35 AM
    #196
    clayman12
    clayman12 New Member
    The wheels look great! What did you paint them with? Thanks in advance!
  17. Feb 20, 2018 at 4:13 PM
    #197
    Jleeb
    Jleeb Well-Known Member
    Vermont
    2017 DCLB OR SUPERwhite.
    Stock
    Your car looks so sick! Any rubbing with these tires?
  18. Feb 20, 2018 at 5:14 PM
    #198
    pismo61
    pismo61 Well-Known Member
    Temecula,Ca.
    SR 4x2 auto.
    Did you have to trim your wheels studs to install the 3/4 inch wheel spacers?
  19. May 31, 2018 at 9:00 AM
    #199
    rideawalrus
    rideawalrus Well-Known Member
    Four Corners area
    '16 TRD OR 4x4 Prem Tech/JBL Blazing Blue, King coils/shocks, deaver leafs
    King coils/shocks, deaver leafs Pelfrey skid soft topper Nalgene holder
    Would 1.25 wheel spacers affect the suspension at all? I'm thinking of adding them and right now I have a King set up (front coils, control arms, rear socks and deaver leafs). I've seen lots of info on increased bearing and ball joint wear, but never anything on if that extra leverage changes how the suspension rides? Would it make it seem softer?
    TACO Outlaw and SilverII like this.
  20. Jul 9, 2018 at 7:10 PM
    #200
    moser633
    moser633 2016 TRD OR AC
    2016 magnetic grey Tacoma TRD Offroad
    Aux Reverse Lights, tailgate inserts , TRD PRo Grill, Truxedo lo pro gt tonnaeu cover, Cali Raised led Apex stealth light bar Cali raised led Ditch Lights ARB on Board air Method NV Bronze 16 in with 265 75 16 Cooper STT Pro
    what lift and did you do your UCAs and brake lines?
