Lifted: 5100's with OME 2885 coils, rear wheeler's progressive add a leaf
Discussion in 'Suspension' started by Plan_C, Dec 23, 2016.
  1. Dec 28, 2016 at 9:52 PM
    #41
    Plan_C
    Plan_C [OP] Member
    Thanks for the info! That's what I'll have to do.
    Quick question, did you replace your UCAs? If so what brand?
    Also, do you have alignment numbers your going to go in there with and ask the tech to aim for when doing the alignment?
    Thanks!
  2. Dec 28, 2016 at 10:08 PM
    #42
    6uam671_tacoma
    6uam671_tacoma Well-Known Member
    SOCAL (LA/OC)
    08 SW TRD OR & 13 SSM TRD OR
    (08)12-15 Front-end conversion w/TRD Pro grill, Icon UCAs, 5100s w/OME 885, 1.5” Headstrong AAL, SCS Matte Black Ray10s mounted with Nitto 265/75/16 Ridge Grapplers (13) Ironman 4X4 UCAs, Bilstein 6112/5160, Headstrong AAL, SCS Matte Black w/Blaze Bronze lip Ray10s mounted with Nitto 285/70/17 Ridge Grapplers
    I installed ICON Tubular UCAs. My numbers:
    Before:
    Camber D:1.2* P:1.6*
    Caster D:2.5* P:2.4*
    Toe D.08* P:.04*
    After:
    Camber D:.9* P:1.0*
    Caster D:1.9* P:1.7*
    Toe D:.04* P:.04*
    From research, the goal is to get Camber and Toe at 0* and Caster at 3*. If I get Caster as close to 3* with Camber at 0*, I'll be good. I drove the truck about 300 miles before doing the initial alignment and it drove better on the freeway at the higher Caster numbers. More stable and less wandering.
  3. Dec 28, 2016 at 10:14 PM
    #43
    Plan_C
    Plan_C [OP] Member
    Thank you, Those goal setting numbers sound right from what I've read also. If you have a chance let me know how it goes tomorrow at the shop and what final alignment numbers they are able to get for you.
    Good luck!
  4. Dec 28, 2016 at 10:18 PM
    #44
    6uam671_tacoma
    SOCAL (LA/OC)
    Thanks! I have a thread in the suspension section. I plan on updating it and will let you know.
  5. Dec 28, 2016 at 10:27 PM
    #45
    Plan_C
    Plan_C [OP] Member
    Thanks! I'll check out your other thread and let me know how it goes!
  6. Dec 29, 2016 at 12:46 PM
    #46
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    That quote was from me. I only ask because I've seen others install the perch on the 5100's upside down and get the 3.5"+ lifts. The perch should go over the snap ring like the picture below. If you can see your snap ring, it's installed incorrectly.
  7. Dec 29, 2016 at 5:45 PM
    #47
    6uam671_tacoma
    SOCAL (LA/OC)
    I got my realignment done this morning. I updated my thread. The truck drives noticeably more stable on the freeway. The tech was cool! He talked with me about the numbers I was searching for and understood why I was doing it even before he attempted the realignment. Once he was done, he came and told me what he was able to get and confirmed that I was ok with it.
  8. Dec 31, 2016 at 10:10 AM
    #48
    PartTime
    PartTime Active Member
    2010 DBC TRD Sport
    PlanC. Have you posted your alignment #'s or did I miss it?
  9. Feb 3, 2017 at 8:00 PM
    #49
    kyuss88
    kyuss88 Well-Known Member
    Jimmy
    New Jersey
    2012 MGM DCLB TRD Sport 4x4 V6
    No skids, no lockers, no winch.
    Plan_c I love the truck! Just wondering what load range your tires are, and what you did about the tire sensors. Also where did you get the TRD badge on your grill?
