lifted truck issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PVT Clark, Mar 11, 2011.
  1. Mar 11, 2011 at 3:31 PM
    PVT Clark
    PVT Clark [OP] Well-Known Member
    chase
    Missouri City
    07 tacoma 4x4 4.0L
    train horns, rhinoliner bumper and fenders, 3" ProComp lift, HID's, GT Racing seat covers, smoked tail lights.
    thinking about doing a lift....originally wanted a 6" but im wondering if that would put too much strain on the engine and transmission? has anyone heard or know of problems that arise with running 33" tires or bigger? also what is the smallest lift i can get and run 33" or 35" tires? i want an aggressive offoading look and get more ground clearance without my taco turning into a slug and without spending thousands on a 6"suspension lift.
  2. Mar 11, 2011 at 3:33 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I'm running 33's on a 3" 35's are doable but you will be doing a lot of cutting.
  3. Mar 11, 2011 at 3:41 PM
    PVT Clark
    chase
    Missouri City
    07 tacoma 4x4 4.0L
    what do you mean by alot of cutting? and what is a good lift that isnt a 6 inch and will fit 33s or 35s?
  4. Mar 11, 2011 at 3:46 PM
    JLee
    Jerry
    Grass valley CA
    Well if you want 35's you will have to do the cab mount chop and cut your fenders there is a few threads of guys putting 35's on a 3" I know RelentlessTaco modified his fenders to for the 35's.
    If you like wheelin I don't recommend a 6" lift the drop bracket will give you less ground clearance then a 3" lift. if you really want ground clearance go with a 3" and 35's
    also a aftermarket front bumper is a must if you run 35's
  5. Mar 11, 2011 at 3:51 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    35's will be alot worse for your engine and tranny than 33's would be. Check out Toyteclifts.com and look at the OME complete 3'' lift kit. In my opinion a very good lift hope, this helps
  6. Mar 11, 2011 at 4:00 PM
    JLee
    Jerry
    Grass valley CA
    Oh yeah i forgot to mention a re-gear would be needed with 35's
  7. Mar 11, 2011 at 4:04 PM
    Crownedcustoms
    Crownedcustoms Well-Known Member
    Gilbert
    07 dc 4x4 fox coilovers 20's & toyo mudders
    Fox coil-overs, Fox shocks, 20" Helo wheels, blowthough, Jl and focal system, Grillcraft grill, Toyo Mud terrains
    I"ve got 33's on 2.5ish. I Have Fox coils up front and tsb leafs with an add a leaf in the rear. You will have to cut a little but its totally worth it. I wouldn't go 35's unless you plan on changing your gears and if your afraid to cut I wouldn't go 35's on 3". The fox are a little spendy but nice. :D What price range are you trying to stay around?
  8. Mar 11, 2011 at 4:37 PM
    PVT Clark
    chase
    Missouri City
    07 tacoma 4x4 4.0L
    less than 800 for all suspension parts. not including tires. what is regearing? is it hard?
  9. Mar 11, 2011 at 4:40 PM
    JLee
    Jerry
    Grass valley CA
    Its about 1000 bucks if you have a shop do and seeing how you don't know what it is that would be your best bet.
    And for 800 bucks you can get the OME lift or some bilies and. Add a leaf.
  10. Mar 11, 2011 at 4:43 PM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    Changing the actual gears in the differentials. For your price range id say bilstein 5100s n OME 884s. Might be tough to buy all the parts and do it correctly for what you wanna spend. Possibly run 265/75/16s
  11. Mar 11, 2011 at 4:58 PM
    PVT Clark
    chase
    Missouri City
    07 tacoma 4x4 4.0L
    your right i dont know much about this stuff but as long as its take off and replace i think ill be fine. im trying to find a good thread about cab mount chop but cant really find one...
  12. Mar 11, 2011 at 5:20 PM
    Sandhopper
    Sandhopper Well-Known Member
    So it sounds like 3" is the most versatile for on and off road. With the 3" toytec lift will 33's fit without trimming or are back spacers needed? I already have the Rear Leaf TSB could I just get away with the 5100's and still fit 33's or 285's?
