lifted without changing tire size ?
Discussion in '4 Cylinder' started by Ghost Rider, Nov 19, 2010.
  1. Nov 19, 2010 at 11:44 AM
    Ghost Rider
    Ghost Rider [OP] Well-Known Member
    Quebec Canada
    Tacoma Sr5 4x4
    Can I lifte the truck a litle and still used the same size tire and still look good ?
  2. Nov 19, 2010 at 11:49 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    look good, no. I lifted mine 3" and it looks kind of goofy with stock tires. Getting 33s soon
  3. Nov 19, 2010 at 11:50 AM
    Ghost Rider
    Quebec Canada
    Tacoma Sr5 4x4
    Just 1 inch or maybe 2 ??
  4. Nov 19, 2010 at 11:50 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Tacomas always look good.... but seriously, its all a matter of what you like and what you think.
    A mild lift with stock tires probably won't be all that noticable and still look normal.
    What do you consider a mild lift?
  5. Nov 19, 2010 at 11:52 AM
    Ghost Rider
    Quebec Canada
    Tacoma Sr5 4x4
    scused my englishhhh
    I dont want the I4 to be out off power whit bigger tire and i want a small lift for my truck. The front end look very low
  6. Nov 19, 2010 at 11:54 AM
    ShaShasBoo
    ShaShasBoo Well-Known Member
    Casey
    Lexington, KY
    06 DC Prerunner
    Why throw away your money on a 1" or 2" lift? besides I don't think you can even get a 1" or 2" suspension lift. So I assume your thinking of either a 1" body lift or a 2" leveling kit. Either way it's gonna look awkward. But everybody has their own opinion.
  7. Nov 19, 2010 at 11:55 AM
    Ghost Rider
    Quebec Canada
    Tacoma Sr5 4x4
    Wath a leveling kit ?
  8. Nov 19, 2010 at 11:56 AM
    ShaShasBoo
    Casey
    Lexington, KY
    06 DC Prerunner
    Sounds like your wanting a 2" leveling kit. Takes out the rake of the tacoma. I did that to mine and it looked awkward till I added a AAL to the rear and got bigger tires.
  9. Nov 19, 2010 at 11:59 AM
    Ghost Rider
    Quebec Canada
    Tacoma Sr5 4x4
    You have a V6 whit the I4 will the truck still mooved ???
  10. Nov 19, 2010 at 12:13 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I stuck with the stock (265/70R/16) tires with a 2" lift (front and back) and it didn't look all that bad but I wanted to fill up the wheel well a bit more. At 15,000 I changed out the stock tires to 265/75R/16 and am very pleased with how it turned out... no vibrations, the cv angles look great, and didn't have to do any trimming.
  11. Nov 19, 2010 at 12:21 PM
    Ghost Rider
    Quebec Canada
    Tacoma Sr5 4x4
    Do you have before and after pictures ??
  12. Nov 19, 2010 at 12:49 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Billies at .85 in the front + 1" AAL(or TSB leaf) = 1" suspension lift and it's expandable if you want to add Eibachs or OME's later on in the front and swap out AAL's in the rear.
    With 1-2" of lift all around I think it'd look fine on stock size tires. I'd look better if those tires were more aggressive than the stock but that's a personal preference.
  13. Dec 1, 2010 at 9:18 PM
    JLaScala
    JLaScala Super White is gonna treat you right.
    Snohomish Washington
    2010 TRD Sport 4x4 long bed crew cab.
    Secondary air filter removal, K&N drop in, Removed front mud flaps, Toyota all weather matts, skid plate, bug guard. Bilstein 5100's all around fronts set at 2.5", OME add a leaf, Goodyear Wrangler Authority 265/70/17, stubby 6.5" antenna, smoked tail lights, blacked out badges.
    I lifted mine 3inches and it looked pretty weak with 245/75 16's on it. After I put the 265/75 16's on it completely changed the look of the truck. I am now very happy with my truck. Its suttle, but looks and performs way better.
  14. Dec 1, 2010 at 11:41 PM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    What this guy said.
    With the stock 245's on stock sucked in wheels, it didn't look any more retarded with 3" of lift than stock, it just didn't look right with factory wheels sucked in and essentialy street/AT tires.
  15. Dec 18, 2010 at 8:20 AM
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    You gotta do your home work man, and just consider the options in my opinion. I have the 4 cyl myself, and temporarily ran 31's w/o a lift. There was a negligable amont of power loss, but enough that I wasn't happy with it. I went back down to stock, and put a 2.5'' lift on it w/ wheel spacers, and in my taste like it. It's all up to you. Good luck :)
