Lifter Chatter
Discussion in '1st Gen. Tacomas (1995-2004)' started by ToyotaHondaOwner, Nov 13, 2011.
  1. Nov 13, 2011 at 8:40 PM
    ToyotaHondaOwner
    ToyotaHondaOwner [OP] Member
    San Antonio
    2001 Toyota Tacoma
    Okay so again new member I have a 2001 Taco with 115k miles and I am having lifter chatter in the morning. I have added Rislone oil treatment with little progress. Any suggestions or is this normal what should I do? Now my Taco runs great other than this. Thanks for the help!
  2. Nov 13, 2011 at 9:10 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    what kind of oil (brand and weight) and oil filter are you using?
    Does it go away once it warms up? Only at idle or does it increase/persist with RPM's?
  3. Nov 13, 2011 at 9:13 PM
    ToyotaHondaOwner
    San Antonio
    2001 Toyota Tacoma
    5w20 pensoil .... It's only in the morning and it goes away after a couple of minutes.... Help
  4. Nov 14, 2011 at 4:23 AM
    jandrews
    '09 FourDubDee TRD OR
    If it's just there in the morning and goes away after a few minutes, it's just an older engine waiting for the oil to warm up.
    An oil change may help. 5w30 may help. Both may help or make it go away.
    FWIW I don't think any harm is being done. My Matrix does the same in winter only when it's getting close to an oil change.
  5. Nov 14, 2011 at 2:07 PM
    TacoMX
    Jonathan
    Deltona, Florida
    type of filter? Some filters starve the motor of oil on cold-start-up and the motor will make a little bit of chatter. When I used Fram/Purolator filters the motor made a lot more noise on cold startup for this reason. Use Toyota filters...best available for our trucks.
    And use 5w30 like toyota recommends.
  6. Nov 14, 2011 at 2:16 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    My old 2.7 would clatter a little bit when it was really cold but it was one of the best engines I ever had in a Toyota still clattered when I sold it with 248K on it.
