Lifting My 04 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by iHUNTLEATHERFACE, Jul 25, 2011.
  1. Jul 25, 2011 at 3:46 PM
    iHUNTLEATHERFACE
    iHUNTLEATHERFACE [OP] Member
    H.E.L.P.3.R
    Cannon AFB
    04 Tacoma 4X4 SR5
  2. Jul 25, 2011 at 3:52 PM
    TacoSID138
    TacoSID138 Well-Known Member
    SoCal
    04 PreRunner TRD
    Faded out tinted tails and 3rd brake light,deck-plate mod, dumped Flow Master 40, King EXTD coil overs, 1.5 AP shackles, AP EXPD leafs. 285 Hankook DynaPro ATM tires
    Will you be wheeling at all? Or is it just for street. Blocks ride like shit. And are you sure you want a spacer lift? There are many options on getting a 3inch lift.
  3. Jul 25, 2011 at 3:53 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    do you want a city truck look, or a performer? Don't get blocks and spacers if you want to take it off road at all. Blocks in the rear will increase the stress on your springs, as well.
    Most larger than stock tires will rub at some point, even with a lift, usually while at full lock (turning) in one direction or the other). Either a huge lift or some body mods will probably be necessary to not rub at all.
  4. Jul 25, 2011 at 3:56 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    If your only looking at spending $300, you might wanna go this route. You can use your factory front shocks for the time being till you get some nitrochargers. Works for me. And yes, your gonna rub but with a set of spacers or properly backspaced wheels and some minor trimming you will be good to go.
  5. Jul 25, 2011 at 3:59 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    33" tires will fit a 3" lift after trimming, yes, but you will want to think twice about running that specific lift set up. The ride will be worse with the spacers and blocks.
    A decent suspension lift will not break the bank. I recommend doing some research on popular suspension lift set ups to get some ideas and you'll also learn why spacer/block lifts are frowned upon which will lead you away from wanting to run it.
    Better to do it right the first time. :)
  6. Jul 25, 2011 at 4:17 PM
    jbrandt
    Justin
    Yes, this.
    do a search for Bilstien 5100's. Many guys are getting them for their tacos. I'm planning on a set myself.
  7. Jul 25, 2011 at 4:33 PM
    iHUNTLEATHERFACE
    H.E.L.P.3.R
    Cannon AFB
    04 Tacoma 4X4 SR5
    Hey thanks guys! Yeah i wanna be wheeling around with it, and I guess Ill have to do some more research
  8. Jul 25, 2011 at 7:28 PM
    MTNative
    MTNative Well-Known Member
    OME complete lift. Spend the extra money. I have done a lot of research and for the money this is the one. IMHO...Good luck with your search. Look at Downsouthmotorsports.com Call Marco and he will hook you up.
  9. Jul 25, 2011 at 7:33 PM
    Honey badger
    Honey badger Honey badger hits whatever tree he wants to hit!!
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    Kings FTW! No really if you are going to wheel it OME makes a great kit you can get it from Down south motor sports or Wheelers off road. Both are vendors here so go to the vender section and check them out.
  10. Jul 25, 2011 at 7:40 PM
    04taco2wd
    04taco2wd Take your flame, ignite the world!!!!
    Colby
    Southern Pitt,NC
    06 AC 4x4 SR5
    6" Fabtech Lift, Custom bedside decals, ICON C/Os, 17x9 Cruiser Alloys, 33x12.5x17 Coopers, UWS Lopro Toolbox, more to come...
    Billies and Eibachs make for a great front lift on the first gens. and you will get a complete three inches of lift. like everyone else said, blocks suck. either an aal and/or a shackle kit will be better
  11. Jul 25, 2011 at 10:22 PM
    andycass
    andycass Well-Known Member
    Andrew
    New Orleans
    2012 DCLB TRD Sport
    17 inch FN FX Pro Wheels, 3inch Toytec Adjustable coil-overs w/ rear AAL, OEM Roof Rack, Pioneer double-din in dash, Two Pioneer 10 Inch subs with custom box behind rear seat, HID Hi/Lo and fogs, FLowmaster 40 single in dual out. Weather Tech floor mats, LED Dome/Map lights, Cover Kings Camo seat covers,
    Rough country all the way
  12. Jul 26, 2011 at 7:00 AM
    04taco2wd
    Colby
    Southern Pitt,NC
    06 AC 4x4 SR5
    Thats the kit I had on my 04 and it rode like crap...plus you have to cut and reweld the exhaust pipe because the new shackle makes the leaf hit the exhaust pipe.
  13. Jul 26, 2011 at 7:03 AM
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    OME all the way. I have it on my '02
  14. Jul 26, 2011 at 7:05 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Lolz
  15. Jul 26, 2011 at 9:50 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Have this lift on my truck now...and it sucks. PO put it on.
    Do not get blocks man, just does more damage then good. Killed my leaf springs.
    Get 5100s, eibachs(no they aren't on backorder anymore) and then an AAL or be a real man and get new leaf packs
  16. Jul 26, 2011 at 3:41 PM
    tacotopher
    tacotopher Well-Known Member
    Memphis
    Zombie TRD OR
    Grey wire mod, 5100's on all four corners, AAL in the rear, deckplate mod,
    Like the others said. Please stay away from the block style lifts. I have always thought those were for old fords :rolleyes:
  17. Jul 28, 2011 at 7:51 AM
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
    That's why the guy asked me about the exhaust when I got the Magnaflow installed. He re-ran the piping from the muffler back.
