Lifting my Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jweir1995, Mar 10, 2015.
  1. Mar 10, 2015 at 5:08 PM
    Jweir1995
    Jweir1995 [OP] Member
    Greenwood, SC
    05 Black DC Tacoma
    double din boss radio, 2 10 in kicker subs, flowmaster delta flow exhaust, 33in mud tires
    Hi guys, I've had a Tacoma for a while (2005 double cab black 4x4), and I've finally decided to get a small lift on it with some oversized off road tires. I was wondering what I should ask the mechanic to do after he installs the 3" rough country suspension lift and my 33" Nitto trail grapplers? Like do I need an alignment or what? Thanks in advance.
  2. Mar 10, 2015 at 5:46 PM
    FloTaco
    FloTaco Well-Known Member
    Bay Area, CA
    2021 SR DC 4X4
    Yes, you will need an alignment. You will also need to recheck the torque on every bolt after 200 miles.
  3. Mar 10, 2015 at 5:56 PM
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Alignment, will likely need to do some minor trimming with 33's and as was mentioned re-torque after a bit of driving time
  4. Mar 10, 2015 at 6:28 PM
    scoutpilot
    scoutpilot Well-Known Member
    Dallas
    TN
    2010 4WD DCLB
    OME 886x with OME shocks, Dakar springs, LR UCAs, ARB bumper with Warn VR8000. Midland 75-822 cb with 3' firestik. Cooper AT3 265/75/16 on stock steelies, rear diff breather mod.
    If you have access to tools or a shop and are even a little bit mechanically inclined, I highly recommend doing it yourself. I was going to have my OME kit installed professionally a couple months ago but the good TW folks here told me to do it myself. So glad I did...saved a lot of money, learned a lot about what's under my truck, and have the pride of doing it myself. It's a good feeling.
  5. Mar 10, 2015 at 6:34 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    This. Lots of good tutorials and info on here. Do some research, you will find out more than you know. Yes you will need an alignment. And do yourself a favor and get a good lift, don't get a crappy cheap lift. You get what you pay for.
  6. Mar 10, 2015 at 7:28 PM
    FloTaco
    Bay Area, CA
    2021 SR DC 4X4
    I concur, DO NOT get a cheap lift. Save your money and get the best you can possibly afford. I've gone through 5 lift kits between my 4runner and tacoma. Wasted a lot of time and money before doing things the right way.
  7. Mar 10, 2015 at 8:29 PM
    Jweir1995
    Greenwood, SC
    05 Black DC Tacoma
    Yeah I ended up going with the Rough Country 3" suspension lift. Thanks for the info I was pretty sure I needed an alignment but had no idea about the re-torquing. I'll post a pic when the finish project is done.
  8. Mar 11, 2015 at 6:49 AM
    FloTaco
    Bay Area, CA
    2021 SR DC 4X4
    Isn't the Rough Country lift just front spacers and rear blocks? You're going to get upset and replace it within 1 year...
  9. Mar 11, 2015 at 6:52 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Yep. Its just spacers. It costs more to have it installed then the parts cost.
  10. Mar 11, 2015 at 6:54 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    :facepalm:
    It's called Rough Country for a reason..
