Lifting the 4 cylinder
Discussion in '4 Cylinder' started by alexander323bc, Nov 14, 2011.
  1. Nov 14, 2011 at 10:56 AM
    alexander323bc
    alexander323bc [OP] Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    I did search this but couldn't find the exact answer I was looking for. Because of the weight difference between the 4 cylinder and V6 does is there a lift that is actually better for the truck because of the difference? I had read all the info about about OME VS ULTIMATE but all those guys seem to be running the V6. Just want to make sure I dont get coils that are to heavy for the truck if I got ome This may sound silly but just want to cover my ass.
  2. Nov 14, 2011 at 10:59 AM
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    You can choose which OME springs you want to get. I have a 1st gen. and I have 881 coils from OME. For your truck, you should look into the 884s. You might get a more stiff ride without the extra weight of the v6 but it shouldn't be too bad if you pick the right coils. Are you 4x4?
    It all depends on how much lift you actually want. If it were me, I'd look into the 884s. You won't be disappointed with Old Man Emu
  3. Nov 14, 2011 at 11:07 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    I have a 4x4 4cylinder 2011 Ya I am looking at EMU just for the cost difference. I dont think the ride quality would be much different. Just want a lift that will let me do some offroading now and again with a solid 3 inch lift. I saw posts in here it seemed like people got some wrong coils and due the weight the front of the truck was lifted. Just trying to make sure this doesn't happen to me.
  4. Nov 14, 2011 at 11:12 AM
    YellowDog01
    04 4x4
  5. Nov 14, 2011 at 11:44 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Whipper yes the 884 are the lightest coils. Yellow i like at his post he did a good job! thanks for the info and answering the question. Toytec doesnt have a weight advantage compared to EMU apparently thanks for all the help guys. Do you guys know if I need longer break lines? I just read he put them in his lift.
  6. Nov 14, 2011 at 11:51 AM
    Juggernaut
    Juggernaut Captain
    Sacramento
    10 PreRunner AC Sport Rally 5 Spd
    Tail gate hose clamp, Front Windows 50% tint, fog lights, 894 backup light mod, LED license & interior.
    883's will fit too, but provide less lift.
  7. Nov 14, 2011 at 11:59 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Ya i spelled brake wrong. Thanks for all the help guys you answered all my questions. best forum on the planet!!!!!
  8. Nov 14, 2011 at 12:06 PM
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    I have the OME lift on my I4 access cab. The weight of the coils didn't affect anything really. It's the bigger heavier tires that will change things.
  9. Nov 14, 2011 at 12:26 PM
    YellowDog01
    04 4x4
    I put extended brake lines on my truck...Might not be a bad idea if you are flexing the rear.
  10. Nov 14, 2011 at 12:31 PM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    OME 885s & Dakars on my '11 4Banger Access Cab. 3" lift front & rear. Trim packer but no spacers. Rides great on & off road.
  11. Nov 14, 2011 at 4:16 PM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    I have a 2.7ltr and intalled the toytec ultimate lift. IMO its a perfect lift for the truck. Not too harsh not too soft. Great off road. Only thing is if youre going to go this route and want to do it right the first time then purchase after market UCA's.
  12. Nov 15, 2011 at 4:31 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    Tepidy on the toytec site you can get the light racing uca with that lift. Is that what you are running?
  13. Nov 15, 2011 at 10:24 AM
    0uTkAsT
    0uTkAsT Gunslingin' Gearhead
    Josh
    Gilbert, AZ
    Rock Flinging Turd Gen
    Stuff that makes it easier to run over other stuff.
    The LR UCAs will work fine.
    I opted to stick with a 2.5" lift in the front to avoid needing adjustable UCAs and brake lines by using Eibach coils and 5100s set at .85". I have 5100s and a Deaver high arch AAL in the back for 3" lift. The truck sits pretty level, I'm running 33x11.5" Mud Terrains with no rub even at full stuff / full droop, have a decently compliant ride in town, and plenty of travel without the sway bar. It doesn't do so well wash running but that's not going to be an issue for you in NY.
  14. Nov 15, 2011 at 10:55 AM
    alexander323bc
    Eric
    Buffalo New York
    4cyl access cab
    OUTKAST I am exactly sure what wash running is so i am pretty sure it wont effect me hahaha. Thanks for all info glad you put the numbers in there for detail really helps out! thanks man
  15. Nov 15, 2011 at 11:44 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    If I had it to do over OME on the reg cab, and I wanted full 3" lift, I'd go 884 springs with 1/2" top plate spacer instead of 885 springs.
    That would trade a little less up travel for a little more down travel, once you went to an aftermarket UCA.
    That suspension is designed to carry weight. You'll like the ride better if you add weight to the truck.
    I've probably added 400lbs in tools, gas cans, sliders, winch, receiver mounts, etc...
    Still rides firm. No one would mistake it for plush.
  16. Nov 15, 2011 at 11:57 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    Yes you can use Light racing although I went with the UCA's designed by Down South Motorsports, they are made by desert products and are rock solid. Give Sonny a call at DSM and he will hook you up.
  17. Apr 14, 2016 at 4:12 AM
    ecgreen
    ecgreen overeducated redneck
    Sean
    2015 4x4 4-banger Access
    Bump...anyone tried ome 887s with a 4 cyl?
  18. Apr 16, 2016 at 8:53 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    Holy thread revival batman. I would think that's too much lift for a lighter 4cyl, I would stick to 885 (or 884).
  19. Apr 17, 2016 at 3:02 AM
    ecgreen
    Sean
    I wonder though, with weight like sliders and skids (and maybe bumpers) they might be perfect. They are only 3/8" longer and people who use 885s on 4 cyls are always putting spacers on after adding weight. I might give it a try.
  20. Apr 18, 2016 at 4:00 PM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    My 4 cyl ain't light she's a heavy ass bitch..
    Tips the scales at 5112lbs... once you start adding armour and stuff it gets heavy fast
