Lifting this Saturday, anything I'm missing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hookedontronics, Sep 21, 2010.
  1. Sep 21, 2010 at 8:26 AM
    hookedontronics
    hookedontronics [OP] Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    I'm lifting my truck 3" this Saturday and want to double check and make sure I have everything I need.
    -icon extended travel coilovers
    -walker evans 2.0 rear shocks
    -wheelers tsb AAL with centering pins
    -all pro u-bolt flip kit
    -beefed taco's cb drop kit
    -diff drop kit
    -stock bump stops fitted to the all pro flip kit
    I know I don't have ucas but I plan to add them next month when I get some more money I can put towards my taco. Anything else I'm missing?
  2. Sep 21, 2010 at 8:31 AM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    case of your favorite beer.
  3. Sep 21, 2010 at 8:38 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I think you're gonna have to do some fabbing to mount your stock rear bump stop on that shackle reverse. Do you have everything you need to tack-weld it?
    This isn't a mod I've done, so I can't be more specific, sorry.
  4. Sep 21, 2010 at 8:43 AM
    hookedontronics
    Jake
    Glenville, NY
    I also have a buddy, whose a welder and machinist, with a lift which should really help :yay:
    All you need to do is drill and tap a couple holes to do this, very easily done
  5. Sep 21, 2010 at 11:27 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    forget the diff drop, it does nothing for you and is a pain in the ass to install. Other than that you look like you're ready to go.
  6. Sep 21, 2010 at 11:33 AM
    JTaco386
    JTaco386 Well-Known Member
    JT
    San Antonio, TX
    13 DCSB TRD Sport 4x4
    x2
    I installed it with my toytec co's and it barely corrected the cv angles...in my opinion, it's not worth the hassle
  7. Sep 21, 2010 at 11:35 AM
    Masada
    Taylor
    Laveen, AZ
    from what I've read it's only a one ince drop and that only moves the CV .5*
  8. Sep 21, 2010 at 11:37 AM
    hookedontronics
    Jake
    Glenville, NY
    ^Is there another option to correct the cv angles? besides a drop bracket kit, i mean.
  9. Sep 21, 2010 at 11:42 AM
    Masada
    Taylor
    Laveen, AZ
    No there really isn't any alternative. But you won't need it, I had my truck lifted over 3" in the front and my CV angles were hardly affected. There is a thread on here where someone lifted their truck and then took pics and then bought the diff drop and took pics again and there was hardly any difference. I'll see if I can find it.:D
  10. Sep 21, 2010 at 12:29 PM
    hookedontronics
    Jake
    Glenville, NY
    I drive about 3kmi a month, i deffinately don't want my CVs wearing out faster than expected
  11. Sep 21, 2010 at 12:36 PM
    Masada
    Taylor
    Laveen, AZ
    They won't, I have to correct myself though. I found a quote by Chris4x4 about the diff drops and it's still only a 1" drop that moves the CV down by 1/2" which is a 3* change. Still not enough to help the angles, but if you want to install it, by all means you should. It's not going to hurt anything, I'm just trying to save you some time and effort.
  12. Sep 21, 2010 at 12:45 PM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    I have the front and rear Bilstein 5100's already. I am getting the TSB done next week. So what would be my safest, and best to really get the full 3 inches up front. Should I get the Eibech's? Which I hear if you get the top spacer assembly it will give you the full 3 inches. In the back I plan on doing a 1 1/2 inch AAL from Toytec. Will I need the shims for the rear? The carriage bolt assembly? Please help I really want to do this right. And does anyone else have the Billie's and Eibech's up front with the top plate spacer, and have any alignment issues? Thanks for your time.
  13. Sep 21, 2010 at 12:47 PM
    hookedontronics
    Jake
    Glenville, NY
    Way to hi-jack my thread dude. Please start your own
  14. Sep 21, 2010 at 12:47 PM
    Masada
    Taylor
    Laveen, AZ
    Might be a better idea to start a new thread or search around in the suspension section, don't want to thread jack the OP ;)
  15. Sep 21, 2010 at 12:48 PM
    hookedontronics
    Jake
    Glenville, NY
    I'm gonna install it because i already have it. 3 degree correction is better than nothing
  16. Sep 21, 2010 at 12:52 PM
    raswank
    Rick
    Auburn,Ma
    Sorry about that.
  17. Sep 21, 2010 at 12:54 PM
    hookedontronics
    Jake
    Glenville, NY
    NP, just didn't want my thread to get off track. i PM'd you
  18. Sep 21, 2010 at 12:56 PM
    Masada
    Taylor
    Laveen, AZ
    As will I ;)
  19. Sep 22, 2010 at 6:06 AM
    hookedontronics
    Jake
    Glenville, NY
    Any other solution for the cv angles?
  20. Sep 22, 2010 at 6:14 AM
    Masada
    Taylor
    Laveen, AZ
    Lower lift...:notsure:
    I'm telling you dude, guys lift their trucks a lot on here and have very little problems with their CV's...not trying to be a jerk, but I think you are worrying too much about it. You'll be just fine :thumbsup:
