Light Bar in hood scoop
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ACK, Apr 22, 2018.
  1. Aug 3, 2019 at 8:59 AM
    #181
    TacoSportTRD
    TacoSportTRD Well-Known Member
    Michigan
    2017 TRD Sport AC 4x4 V6 Barcelona Red
    This is what mine looks like on a sunny day with the light off. You can also use a color film.
    itsmike[QUOTED] and MrBrooks like this.
  2. Aug 11, 2019 at 7:14 PM
    #182
    itsmike
    itsmike Well-Known Member
    SoCal
    How did you do the wiring for that switch? The light bar I received has 3 wires (blue, white, and black wire). And these Oem type switches have 4 wires (black, green, and two red wires).
    Thanks!
  3. Aug 11, 2019 at 7:43 PM
    #183
    TacoSportTRD
    Michigan
    Connect the green to the battery +side
    Connect the red #1 to the relay switch
    Connect the red #2 to I think the brown
    Wire on the neighboring switch. It's for illuminating the switch with the other dash
    Lights, (dimming) I think it's the brown but I can't remember.
    Then connect the black wire to a solid ground.
    I will see if I can find the correct color for the
    Red #2 tomorrow but I believe it is brown
    You can check it with a volt meter by turning on the parking lights and then using the dimmer switch to check for voltage drop.
    You don't have to use the red #2 if you don't care if the switch illuminates with the dash lights. Hope this helps.
    itsmike[QUOTED] likes this.
  4. Aug 11, 2019 at 8:30 PM
    #184
    itsmike
    SoCal
    Ok thanks. So I got that black goes to black, and switch illum source to red#2.
    How can I find out if it it be the blue or white wire coming off the light bar relay goes to the green and which to red#1?
  5. Aug 11, 2019 at 8:58 PM
    #185
    TacoSportTRD
    Michigan
    Your light bar should have come with a wiring diagram and you would have to use it to determine the + and - leads. Where did you get your light bar at? If it is the same as I bought (I linked it in my previous post) then I could tell you which color of wires go where.
    Edit:
    Did you buy this one? Different manufacturers use different color wiring.
    https://m.ebay.com/itm/17inch-Singl...o-Offroad-Truck-For-Ford-Driving/183689616669
  6. Aug 11, 2019 at 9:08 PM
    #186
    itsmike
    SoCal
    Ya same light bar from ebay (but with the rocker switch instead of remote). Unfortunately the diagram doesn’t show very much.
  7. Aug 11, 2019 at 9:19 PM
    #187
    TacoSportTRD
    Michigan
    I am going to go through my notes after I get off work tomorrow and see if I can help you with which color on the relay switch goes to which color on the switch. I can't remember exactly what I did at the moment.
    Also you could bench test it using a battery or battery charger like I did and if it works then you could trace the wiring to find the +&- leads. But I gotta get up for work in 7 hours so I gotta hit the sack now. I'll post later Monday at around 6:00 PM eastern time.
  8. Aug 11, 2019 at 9:22 PM
    #188
    itsmike
    SoCal
    Cool, thanks for the help. No hurry. Appreciate it!
  9. Aug 12, 2019 at 4:44 PM
    #189
    TacoSportTRD
    Michigan
    Hey Mike I was unable to find my notes.
    All of my wiring is sealed up.
    Just follow the instructions that came with the light and hook it up to a battery or charger.
    Turn it on and there are only two wires you need to worry about the other one feeds the switches internal light.
    Unplug them one at a time and see what happens then you can see which ones do what.
    Do you have a volt meter or a 12v testing light? It really is pretty easy.
  10. Aug 12, 2019 at 4:59 PM
    #190
    HiProofProducts
    HiProofProducts Well-Known Member
    NE Ohio
    2017 Tacoma TRD Sport
    Does this count as a hood scoop light? That is shown in bright sunlight. It really stands out as it gets dark. Kinda goes along with our moonshine still business. PS The fogs are off getting halos installed.
  11. Sep 17, 2019 at 4:54 PM
    #191
    RabidRotty
    RabidRotty Active Member
    Tried contacting him on IG and no answet
  12. Sep 17, 2019 at 5:00 PM
    #192
    RabidRotty
  13. Sep 17, 2019 at 5:17 PM
    #193
    Boss hoss
    Boss hoss Well-Known Member
    Richard
    Silverton Oregon
    2021 TRD OR premium access cab.
    Carpet bed liner and Matt, fuel wheels KO 2 tires. Bilstein 6112,5160 frt. lift .white with black leather seats.
    High proof, that is bad ass looking.
  14. Sep 17, 2019 at 7:35 PM
    #194
    MrBrooks
    MrBrooks Well-Known Member
    Midwest
    2018 DCSB - 2021 Rav4
    I don't think he is doing the scoop lights anymore. Something about his supplier upping the price too high
  15. Sep 17, 2019 at 8:24 PM
    #195
    Tacospike
    Two Trucks
    Yeah, he’s been doing a lot of other stuff. Three way fog light that have three functions. 5500k to 6000k to yellow... pos with yellow DRL. idk, I fell off watching after I got my hood scoop light a few years ago.
    MrBrooks[QUOTED] likes this.
  16. Sep 27, 2019 at 3:13 PM
    #196
    RabidRotty
    Attempted to contact him a couple of times with no results. Might have to look elsewhere
  17. Sep 27, 2019 at 3:15 PM
    #197
    RabidRotty
    Did you ever find who did this?
  18. Oct 26, 2019 at 6:33 PM
    #198
    Voodootaco19
    Voodootaco19 Well-Known Member
    2023 solar octane Tacoma Trd pro
    Stock
    Just to verify on spartanxcustoms hood scoop light setup ,just placed an order for the stealth knight rider loaded out set up with remote, switch and harness ,should be here in 3weeks. He does top notch work on all his light setups can't wait to install this on my pro.
  19. Dec 20, 2019 at 6:54 PM
    #199
    MidWestTRDPro
    MidWestTRDPro Well-Known Member
    C-bus, Ohio
    2019 Tacoma TRD Pro
    As much as $ will allow
    Has Spartan X Customs replied to anyone? Trying to get one of his light bars.
  20. Dec 20, 2019 at 6:57 PM
    #200
    Tacospike
    Two Trucks
    idk I got mine a few years ago. Has been semi active on IG
    MidWestTRDPro[QUOTED] likes this.
