Light bar switch
Discussion in '3rd Gen. Tacomas (2016+)' started by tnt817, Jun 2, 2016.
  1. Jun 2, 2016 at 12:04 PM
    tnt817
    tnt817 [OP] Active Member
    Dayton, OH
    '16 MGM TRDOF DCSB MANUAL
  2. Jun 2, 2016 at 12:07 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  3. Jun 2, 2016 at 12:08 PM
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Why not OTRATTW switches?
  4. Jun 2, 2016 at 12:10 PM
    T4RFTMFW
    Probably wants it to look OEM.
    jgr81 likes this.
  5. Jun 2, 2016 at 12:13 PM
    tnt817
    Dayton, OH
  6. Jun 2, 2016 at 12:15 PM
    T4RFTMFW
    I just Google'd "CH4x4 light bar switch," and it was the first thing that came back. :headbang:
  7. Jun 2, 2016 at 12:16 PM
    dzkritzas
    dzkritzas Well-Known Member
    D
    South Kakalaki
    16 TRD-OR DCSB
    superwhite (IN THE WORKS) SOS offroad concepts streamline bumper + winch Ballistic Tank Wheels- 305/70/17 "3 OME coilovers with top plate Camburg Uniball UCA 2.5 Fox rear shock with remote resv custom 3rd brake light mod custom TRD OR bed decals or replica's- @stickerhi on instag tell him i sent you for his %off..he can make it happen! (INSTALLED) LEDs everywhere...not a halogen on the truck LEXUS GS350 LED projector fog lamp exact swap LED puddle light +int footwells TRD PRO skid plate TRD PRO shifter TRD Pro grille insert llumar AIR80 tint on windshield 20% ceramic tint across the rest remote start EVO ALL+rf extender front camera mod w/crux harness custom hood + bedlights all black badges pop n lock tailgate lock custom raptor lights attached to DRLs more to come im sure....
    anybody find any switches for the dual changing light bars? like the white/amber combo bars?
    i cant find any switches that would give me the option of only white, only amber, etc...
  8. Jun 2, 2016 at 12:18 PM
    T4RFTMFW
    Not sure how that would work.
    @Iggy. ?
  9. Jun 2, 2016 at 12:19 PM
    tnt817
    Dayton, OH
    You just need a 3 position switch instead of a 2 position switch.
    dzkritzas likes this.
  10. Jun 2, 2016 at 5:07 PM
    Iggy
    Iggy Vagabond Outdoors Vendor
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    You would actually need a 4 position with and I don't know if they exist.
    You would want, OFF, Amber On, White On, All On.
    You could wire it up with two switches.
    One that's a SPST on/off switch, and one that's a DPTT, ON/ON/ON. The on/off switch would cut all power to the light bar, and the other switch would control the 3 light modes. You need a double pole 3 way to get both amber and white to illuminate.
    This is all an assumption, since I've never worked with one and don't know what your inputs to the light look like.
    dzkritzas and T4RFTMFW like this.
  11. Jun 2, 2016 at 7:42 PM
    tnt817
    Dayton, OH
    They have 4 position rotary switches that are usually used for headlights. Off, drl, on, and auto are usually the options. Bet you could get one to fit in the little cubby hole above the inverter switch.
    T4RFTMFW likes this.
  12. Jun 2, 2016 at 7:47 PM
    pruchai
    pruchai KAMA3
    Igor
    San Diego, CA
    '14 TRD TX Baja
    Not enough...
  13. Jun 2, 2016 at 7:48 PM
    pruchai
    pruchai KAMA3
    Igor
    San Diego, CA
    '14 TRD TX Baja
    Not enough...
    These. I got me green/green, but they have alternating colors.
    http://www.aironboard.com/online/toyota-replacement.html
  14. Jun 2, 2016 at 7:50 PM
    pruchai
    pruchai KAMA3
    Igor
    San Diego, CA
    '14 TRD TX Baja
    Not enough...
    Because they are fucking hideous.
    breader3 and T4RFTMFW like this.
  15. Jun 3, 2016 at 8:50 AM
    dzkritzas
    D
    South Kakalaki
    16 TRD-OR DCSB
  16. Jun 3, 2016 at 8:58 AM
    pruchai
    pruchai KAMA3
    Igor
    San Diego, CA
    '14 TRD TX Baja
    Not enough...
    There are 2 ways to wire these, but the diagram is somewhat confusing because it just says "Older models" and "Newer models", and expects you to tap into the high beam wire, meaning you won't be able to use the bar unless your high beams are on. If you don't want that, use the first, "Older models" diagram and connect Green/Yellow wire from the switch to ignition power. Connect Blue/Yellow to your dash lights, so the lettering on the switch lights up when you turn on your lights.
  17. Jun 6, 2016 at 6:45 AM
    justchil
    justchil Well-Known Member
    Andy
    WV
    13 AC TRD OR
