Light burned out on A/C fan switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ZEROPILOT, Oct 5, 2017.
  1. Oct 5, 2017 at 2:47 AM
    ZEROPILOT
    ZEROPILOT [OP] Can't re-MEMBER
    ED
    SUNRISE,FLORIDA
    09 2.7 XTRA CAB 5 SPEED
    LARGER WHEELS. DIFFERENT STEREO. PUSH BAR. TAILGATE EXTENDER. WIPER MOD. TPMS LIGHT DELETE MOD.
    The dash board light for my A/C fan switch must have burned out. In the dark everything lights up but that area.
    Is replacement of the bulb simple? What type bulb?
    Thanks.
  2. Oct 5, 2017 at 2:56 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
  3. Oct 6, 2017 at 11:02 AM
    ZEROPILOT
    ED
    SUNRISE,FLORIDA
    Thanks
    I ordered some
    Plain Jane Taco likes this.
  4. Oct 6, 2017 at 1:05 PM
    camit34
    camit34 Well-Known Member
    Aaron
    CO
    '08 Mostly Stock
    Here's the issue I'm having... Happens about every 3 out of 5 times. Any idea? Can't be the bulb itself but probably the connection the bulb is making, or not making, in this case???
  5. Oct 6, 2017 at 2:15 PM
    blu92in99
    blu92in99 Hates everyone, equally
    Elk Grove, Ca
    More than likely the filament in the bulb is loose, or the bulb might be loose [or have a loose connection] in its socket. It's a 1/4-turn socket so doubtful that's loose.
    Takes ~5 minutes to replace, and the bulbs are cheap.
  6. Oct 8, 2017 at 2:23 PM
    ZEROPILOT
    ED
    SUNRISE,FLORIDA
    I agree. It's the contacts.
    The bulb contacts a circuit board.
    I bought a package of five. Free shipping for $15. That's just $3 a pop.
    There are even LED bulbs on Ebay.
    camit34 likes this.
  7. Oct 8, 2017 at 7:24 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    An LED option? I bought some a while back that don't fit.
    Neo T4.. I just ordered some from SuperbrightLeds.com. Looks like last time I ordered T5 from Amazon
  8. Oct 12, 2017 at 6:13 AM
    ZEROPILOT
    ED
    SUNRISE,FLORIDA
    I got the bulbs yesterday and two things:
    1) They are super tiny. Like a grain of rice tiny.
    2)They are very easy to install. The plate pops off with a screwdriver blade and the same flatblade screwdriver removes the covers for the bulbs. Five minute job.
  9. Oct 12, 2017 at 7:42 AM
    TheDrMaSuess
    TheDrMaSuess Well-Known Member
    Loren
    South Jordan, UT
    "Big-Red" Tacoma
    Custom Bumper Fab'd by me, Warn VR-8s, Cab mount chop, Dosecc Sliders, Dosecc BedCage, CVT RTT, Timbren active offroad bumpstops F/R, Nitto Ridge Grappler, Blue Sea Systems Aux Fuse Block, PIAA Fogs, Rough Country X5 LIghtbar, EBC Stage 5 Brake Pads/rotors, 6" Tough Country Lift (hate it), AFE Cold air intake, Custom Exhaust, Nascar Tip
    Don't go LED's they aren't nearly as bright as the bulbs. I've tried multiple types of LED and they don't light up like the bulbs do. If the light is going on and off... it's usually a bad connection. You just need to take the ac unit out re'adjust the bulb and then put it back in. Should fix the issue. If the connection is still weak... consider taping some foam in to have constant pressure on the connection points.
  10. Oct 12, 2017 at 1:14 PM
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    Thanks for the info!
    Mine is at the point where hitting it doesn't bring it back on, it just turns on whenever it likes.
  11. Oct 12, 2017 at 1:26 PM
    TheDrMaSuess
    Loren
    South Jordan, UT
    "Big-Red" Tacoma
    Mine is the same... It just stays off now... need to pull it out and put it back in... takes like 1 minute but I just keep forgetting/not caring about it.
  12. Oct 12, 2017 at 4:55 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Got some Neo4 (4mm) led bulbs from SuperbrightLEDS.com
    Factory incandecent
    NEO4-xHP Cool White
    NEO4-xHP Natural White These are the ones I'm gonna stick with, no real reason other than I didn't feel like taking them out again.
