light condensation
Discussion in 'Lighting' started by garrettski, Apr 19, 2009.
  1. Apr 19, 2009 at 8:31 AM
    garrettski
    garrettski [OP] Well-Known Member
    Truckee CA
    07 Tacoma 2 ten in JL, 5100s, flowmaster 40.
    BFG allterrains, 2 ten inch JL w3,alpine v power amp,alpine cda-9886, bilstein 5100, flowmaster 40.
    put on my hids the other day...washed my truck for the first time since then and got condensation in my lights...what do i do?!?:eek:
  2. Apr 19, 2009 at 8:46 AM
    MacTaco
    MacTaco Mustache May
    Pensacola, Florida
    06 Indigo, Lifted, Flowmaster
    Skyjacker 3" Lift, 285/75/R16 Toyo M/T tires/ Eagle Alloy Wheels, Flowmaster 50 Series, Pioneer Din Head Unit, Viper Alarm/Remote Start System, Debadged, DT Headers, True Flow Intake
    There have been a couple different methods discussed.
    I too have HIDs in my aftermarket projector housings. I had to deal with condensation, and still might in the future.
    You can:
    1. Be patient and let them dry out naturally.
    2. Pull them back out of the truck, and put them in the oven to dry them out.(Never done it)
    3. Use some condensation reducing materials to dry it out.
    4. Drill two small holes in the bottom of the clear lens area, which will speed up the drying process, then seal them back up with silicone when it's dry.
    After you have done one of these and it is dry, seal the rubber grommet that you cut with some silicone, and any other areas that you think would break the seal.
  3. Apr 27, 2009 at 3:29 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    None of those have anything to do with his situation.
    To the OP, did you reused the rubber boots around the bulbs? If you did, how much bigger did you make the holes?
