Light Racing or Total Chaoss UCAs???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RBoyd0325, Feb 22, 2012.
  1. Feb 22, 2012 at 9:41 AM
    RBoyd0325
    RBoyd0325 [OP] Well-Known Member
    Richard
    Alabama
    08 TRD Off Road 4x4 3" lift
    its a toss up for me on these two, and i wanted to see what you guys think about them. maybe give me a little insight. thanks
  2. Feb 22, 2012 at 9:58 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Do you need maximum articulation , or a booted ball joint and adjustability ?
  3. Feb 22, 2012 at 10:06 AM
    Hunter423
    Hunter423 Hunter423
    hunter
    TN
    2008 Tacoma TRD off road
    brush guard, piaa foggs, tinted tail light, tinted windows, rain guards, pure white with blue tinted bulbd all over, white bulbs for licencess plate lighting, blacked out head lights
    what would be best for max articulation
  4. Feb 22, 2012 at 10:07 AM
    ThePoogna
    ThePoogna Active Member
    Las Vegas
    07 prerunner trd off road double cab
    Trd Cold Air Intake, Window Tint, Grillcraft mesh grille, Halo Projector Headlights 6000k HIDs, LED Tail lights, Aero Turbine 2525 Exhaust, Python Alarm/Remote Start, Ipod interface, 3" OME Suspension lift, Camburg B/J UCAs
    There are quite a few threads on this subject just search for them. Correct me if im worng guys but It depends on your needs, if you just need clearance from an aftermarket spring and to maintain correct alignment after a lift and you dont go hardcore off roading LR should suit your needs. TC is geared toward off roading, it gives you more travel i believe because it has a uniball as opposed to the ball joint the LR has. Both help to keep proper alignment specs after a lift 3" or higher.
  5. Feb 22, 2012 at 10:07 AM
    OZ-T
    Peter North
    British Columbia
    A uniball type UCA will have more articulation that the LR UCA
  6. Feb 22, 2012 at 10:15 AM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    I went with the uniball and damn are they smooth my ride is 100x better.
  7. Feb 22, 2012 at 10:19 AM
    OZ-T
    Peter North
    British Columbia
    I chose the LR UCA's because I wanted a booted ball joint for my winter driving conditions
  8. Feb 22, 2012 at 10:22 AM
    pAP
    pAP ==========
    NJ
    11 Tacoma SR5
    ARB locker and OBA, All Pro front & rear bumper, All Pro IFS skid & modified t-case skid, Custom Trans Skid., 4x Innovations sliders, Custom tire carrier/bed bars, Warn Winch, Fox 2.5" Front coilover, Walker Evans 2.5" rear Shock, All pro Leaf, All Pro U-bolt flip, Baja Designs lights, PIA 510 lights, TRD exhaust cut back, Doug Thorley Pipe Bomb
    Do the LR's have any less flex than uniballs with extended travel shocks? I have the FOX extended travel CO's...At full droop, my CO's top out before the UCA binds. I don't know about compression though. I never fully compressed the suspension with the springs removed. So, not sure if the shock or UCA would be the limiting factor.
  9. Feb 22, 2012 at 10:23 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Get uniball if you're running ext travel c/o
  10. Feb 22, 2012 at 10:38 AM
    pAP
    pAP ==========
    NJ
    11 Tacoma SR5
    I answered my own question here. Extended travel CO's are not restricted by the LR UCA's. Extended travel CO's provide more down travel. The up travel movement is the same between the extended and standard CO's. The question is (for me) do the LR's restrict uptravel on coilovers?
