Light Wiring Help Please
Discussion in 'Lighting' started by BeardedWeirdo, Mar 17, 2010.
  1. Mar 17, 2010 at 8:49 PM
    BeardedWeirdo
    BeardedWeirdo [OP] Junior Mint
    Texas
    2010 AC SR5 PreRunner
    Barcelona Red Pop & Lock, Tint, New Shoes, Removed Rear Headrests, Grille(in the works)
    I'm going to be doing a project soon to wire up some lights on my 2010 PreRunner. I figure there is an easy way to accomplish this, but I couldn't find exactly what I'm looking for. Here's what I'm looking to accomplish:
    I want to wire up these lights up to a switch so that I can turn them on and off. But at the same time I want to wire them up so that when my truck is off, the lights go off. That way I can't run down my battery if I accidentally leave them on.
    I'm figuring a relay with 30-battery positive, 87-lights positive, 86-ground, and 85 going to one side of my switch.
    I'm hoping that sounds right. However, my question is on where I should run the other side of my switch. Should I run it to the running light, accessory side of the key switch, etc.? What's the best place to tie into, where is the wire and what color?
    Any help is greatly appreciated. Thanks!
  2. Mar 17, 2010 at 11:12 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Why not hook up your 30 to a switched 12-volt?
  3. Mar 17, 2010 at 11:19 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
  4. Mar 17, 2010 at 11:24 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    What I am saying is to connect 30 on the relay to a switched 12-volt. Meaning it only gets power when your truck is on.
  5. Mar 18, 2010 at 12:08 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    easiest way is to do that ^^^^ with the sig lighter or 12v outlet. or you can get an add-a-fuse. just plug it into the IG1 or IG2 fuse position. those are in the small fuse box behind your coin compartment
  6. Mar 18, 2010 at 5:38 AM
    BeardedWeirdo
    Texas
