Lighter Socket - Half Pulled Out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wvtac0, Aug 6, 2011.
  1. Aug 6, 2011 at 9:44 AM
    wvtac0
    wvtac0 [OP] Well-Known Member
    Eastern Panhandle - WV
    17 TRD DC Sport
    I am attempting to pull the lighter socket assembly out and replace it with the outlet and cover assembly. I can get the assembly about half way out and it feels hung up. Any ideas what is causing the hang up?
    The attached photo is about how far I can get the socket assemply out. (Photo taken from a Baldwin45 post. Thanks Baldwin45.)
  2. Aug 6, 2011 at 9:46 AM
    AK27
    AK27 Well-Known Member
    mine pulled out easily. the wires are short and will come off with a slight pull
  3. Aug 6, 2011 at 10:27 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    Slow and easy with a pair of needle nose pliers .... Turning left to right .... slow and easy.
    The connection is a two blade .... in an "L" shape.
    It'll come .... let us know.
  4. Aug 6, 2011 at 10:30 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Like they said, wires? What exactly are you replacing it with just curious? The little cover that is on the passnger side socket?
  5. Aug 6, 2011 at 10:32 AM
    Tacoma831
    Tacoma831 Member
    Santa Cruz, CA
    08 Tacoma Sport 4x4
    OME 886 Coils, OME Shocks, OME Dakars, Snug Top, De-Badged, ARB Bullbar, XRC8 Winch
    Mine has never even worked since it was off the lot.
  6. Aug 6, 2011 at 10:35 AM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    The reason it won't come straight out is that it is L shaped. In order to get it out you need to get behind the dash. When I got my truck the socket didn't work cause it wasn't connected and I had to remove it to plug it back in. I won't lie it's a pain in the ass. Some needle nose pliers and some patience will get you there.
  7. Aug 6, 2011 at 4:54 PM
    wvtac0
    17 TRD DC Sport
    Thanks for the replys.
    After reading your responses, the socket finally came out with much gentle pulling and twisting. The black lighter assembly ring was a problem for a second till I figured out that there were tabs on the top and the bottom. I have attached a picture of the ring assembly that I removed. (NelsonTacoma, thanks for letting me know it was offset.) If there was any additional pieces to remove, I left them. Installed the Power Socket Assembly (p/n 85530-06010) and the Power Outlet Socket Cover (p/n 85535-0C010-B2)(gray) that I ordered from Toyota of Dallas's website. Everything works.
    I love this website!!!!!
  8. Aug 6, 2011 at 6:37 PM
    NelsonTacoma
    Tucson, AZ
    Glad I could help. :)
  9. Aug 6, 2011 at 6:43 PM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    thanks for the part # op. Just curious, why Toyota of Dallas when you live else where?
  10. Aug 7, 2011 at 11:24 AM
    wvtac0
    17 TRD DC Sport
    Pricing is almost everything. My local dealer would not budge on the pricing on anything. I ordered 4 oil filters, 6 plugs (due to be changed at next oil change) and these 2 parts to make it worth while.
