Lighting FAQ - Please Read Before Posting
Discussion in 'Lighting' started by Viet2100, Mar 30, 2010.
  1. Jul 21, 2011 at 3:18 PM
    #41
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    ^^ your oem plug
    you pulled the 3 prong plug out of your stock bulb... now plug that HID 3 prong plug into the one you just took out.... (your passenger side will be dangling)
  2. Aug 23, 2011 at 1:09 PM
    #42
    Manwithoutaplan
    ID
    I question here MY side marker bulb keeps burning out. what can i do to check if their is a short or something???
  3. Sep 2, 2011 at 9:09 AM
    #43
    veet skeet
    veet skeet Well-Known Member
    Cali
    14 4Runner Trail Edition MGM
    Bilstein 5100s, 17' Method NV Race Wheels, Goodyear Duratrac 265/70/17, Demello Sliders, Xenon/LEDs All Around, Dark Window Tint, Gobi Roof Rack (In the Mail), JL Audio Subs, Alpine Speakers and Amps
    I just got the angel eye HID halo projectors. One of the LED lights in the strand of four on the bottom of the lights is out, and I don't know what bulb to buy to replace it. It's only one of em that's out, but I don't know what bulb to buy to replace it. Also one of the parking lights is out as well on my halo projectors.
    Where can I buy bulbs to replace the parking light and one of the LED bulbs in my halo projectors? I have 6000K HID's right now.
    Any help is appreciated, thanks.
  4. Sep 2, 2011 at 9:12 AM
    #44
    twistax
    twistax Toyota Freak
    Carlsbad NM
    2017 Tacoma 4x4 Off-Road
    CaliRaised ditch mounts & Side Projecting pods
    Get a multimeter set it to 12v AC reader..
    Thhen turn on the lights then dip the prods in to the positive and negative feeds of the balist to see if there is fluxuation.
    Ofcourse 12v is what is what you should be reading on it.
  5. Sep 7, 2011 at 3:14 PM
    #45
    UF06Tacoma
    UF06Tacoma Member
    California
    Base 06, 2TR-FE, Access cab
    CD player w/ USB & Satellite Fog lights Cruise control K&N stock air filter
    Title says most of it, but I am looking to upgrade to the 4300K or the 6000K HIDs but I have stock headlights for my 06. I half read it's "illegal" but if you adjust them correctly they shouldn't be a problem... at least that's kind of what I gather.
  6. Oct 2, 2011 at 12:21 PM
    #46
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    So can anybody tell me what setup they have, have had in the past, or suggest for a 1st gen. I'm looking for a 35w 4000K bulbs.
  7. Oct 19, 2011 at 12:49 PM
    #47
    pikuptruk
    pikuptruk Well-Known Member
    Vallejo
    01 4x4 2.7 Lifted
    6" Fabtech Lift 33" Tires Flowmaster Cold Air Intake
    I am having a lighting issue. I bought a used 01 taco. It had HIDs installed, but I had issues with them since I drove it home from the guys house. I noticed a couple days after I bought it, Whe my headlights are on, and I use the turn signal, the relay clicks very fast, and when I inspected this, both my rear tail it's and turning signals flash, alternating between turning signal light and brake lights. When I press on the brake pedal, they function as designed. When the headlights are off, the blinkers work fine until I press the brake, then the issue happens again. Also, the HIDs stopped working. My incandescent bulbs that are supposed to be my "low beams" only work when my high beams are engaged. I have tested the connections at the headlight bulbs, and I only get 12v when the highs are engaged. The previous owner had installed aftermarket power windows, but this should not affect this. I am thinking the circuit board located under the drivers side dash might be the culperate. Anyone out there have any suggestions?
  8. Oct 20, 2011 at 2:17 PM
    #48
    Relik
    Relik Well-Known Member
    Eddy
    Thousand Oaks, CA
    '11 TRD Sport PreRunner-Auto-Magnetic Gray
    Bilstein 5100s (Front & ext. Rear), Eibach coils @ 0, MaxTrac 4" Spindles, Light Racing UCAs, 1/4" lean spacer, All-Pro 3" Standard leafs, u-bolt flip kit, SpiderTrax 1.25" wheel spacers, 33" (285/70/17) TreadWright Warden A/T tires, extended lines
    Man I got to get me that Avid Light Rack, I mean Bar....:D
  9. Oct 21, 2011 at 6:54 AM
    #49
    pikuptruk
    Vallejo
    01 4x4 2.7 Lifted
    Are those stock or aftermarket? Lol yaharg!
  10. Nov 10, 2011 at 8:13 PM
    #50
    04tacodad
    04tacodad New Member
    Drew
    West Jordan
    04 Tacoma TRD
    leveling kit 2.5 front, Flowmaster catback exhaust, Cold air intake
    I can't find the projector style headlights for my 04 anywhere, any suggestions?
  11. Jan 18, 2012 at 8:56 AM
    #51
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    Anyone know the difference between H10 and H11 bulbs. Looking for a foglight application.
  12. Jan 18, 2012 at 8:57 AM
    #52
    Warhorseforever
    Will
    Sand Lapper
    Theretrofitsource.com
  13. Jan 24, 2012 at 10:09 AM
    #53
    Tacozoid
    Tacozoid Well-Known Member
    Terry
    Katy Texas
    White Tacoma Pre-runner
    Billsteins,Texas tint. Blue Dash mod. Console mod. in Blue, Customized grille
    [​IMG] Oznium Baby! Only way to go for PLCC2s
  14. Mar 8, 2012 at 3:29 PM
    #54
    jacobblocker
    jacobblocker Well-Known Member
    Jacob
    east tennessee
    billet grill, black out emblems, procomp 7089, hankook dynapro 265/70/17
  15. May 21, 2012 at 11:05 PM
    #55
    TJay Sr.
    TJay Sr. Member
    TJay
    Reno, NV
    TRD sport
    lift, wheels, tires, intake, exhaust, battery, JBL. Nevada pinstriping
    Well I'm a rookie and I'm stuck. I got the black version of the- 2nd Generation Projector Headlights with the ccfl's the adjustment screws move the bulb in the center but thats the high beams. How do I adjust the projector part- the low beam? It doesnt need much but the passenger side plane is greater than the drivers just need to move it up and outside a hair. I guess I should have started asking- is it even adjustable? I know there not the greatest lights but I like them so far.
  16. May 21, 2012 at 11:10 PM
    #56
    Warhorseforever
    Will
    Sand Lapper
    IIRC you adjust them just like you would regular bulbs by using the screws on the backs of the headlights.
  17. May 22, 2012 at 10:04 PM
    #57
    TJay Sr.
    TJay Sr. Member
    TJay
    Reno, NV
    TRD sport
    Ok, I did that now and it works!! I just didnt see it moving the projector part, which is my bad. Even still I cant get a good pattern. The way it looks is like a flat plane on the left into a outside curve on the right. By looking at it, it could be said that both the projectors might be the same because they show the same pattern in the same way I was covering up one headlight at a time with a towel and its the same pattern a flat left and a round right hand side I hope what I'm saying makes sense.
    If I should start a new thread about it just let me know.
    Could it be the shape of the light in the projector? Could it just be the cheapy projector itsself?
    I figure they should be universally compatible with either side cause it only a light but it looks as though I have 2 right hand side patterns lol. I just spent the last hour fooling with it driving around and shinning it on a wall and all that mess but it all does no good cause of the flat left and round right. i'll get pics up if it needs to be seen
  18. Jun 11, 2012 at 10:23 AM
    #58
    jdk52
    jdk52 Bro do you even 'Merica?
    Utah
    11 SR5
    3 inch OME lift kit, rear diff breather mod, cb install, sliders, brute force fab front end.
    Just what I needed...
  19. Jun 11, 2012 at 9:52 PM
    #59
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    I can help you out if you need any lighting or wiring done. I don't think you got a chance to see all my lights in action on the last meet :D
  20. Jun 12, 2012 at 6:26 AM
    #60
    jdk52
    Utah
    11 SR5
    Gonna have to do the inside LEDs.
