Lighting FAQ - Please Read Before Posting
Discussion in 'Lighting' started by Viet2100, Mar 30, 2010.
  1. Jun 13, 2012 at 1:16 AM
    #61
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Hell yeah man! Hit me up!
  2. Jun 15, 2012 at 8:39 AM
    #62
    gm242
    gm242 Active Member
    Gabriel
    Miami
    2012 PreRunner
    LED Dome, LED Map Lights, Autopage w/remote start, Tints 15%+factory & 20%
    I am confused :confused:...I want to do all LEDs outside. In the front i have the two side markers (2827/168). But my parking light is the turn signal, why is are there two different bulbs:
    Parking light
    2827
    4157NA
    Front turn signal
    4157NA
  3. Jun 15, 2012 at 11:34 PM
    #63
    Drunknsloth
    Retribution
    South West
    Parking lights are considered DTRL and tacos with DTRLs have their turn signals as their DTRLs. Get the 3157 LED bulb for these. I haven't seen a wide variety of 4157 bulbs in LEDs and 3157s work just fine
  4. Jun 16, 2012 at 9:32 AM
    #64
    gm242
    gm242 Active Member
    Gabriel
    Miami
    2012 PreRunner
    If that is the case then I have the DTRLs would they still work with a 3157.
  5. Jun 16, 2012 at 7:49 PM
    #65
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Bridgestone Dueler A/T Revo 3 265/50, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    Huh? :confused:
  6. Jun 16, 2012 at 11:14 PM
    #66
    Drunknsloth
    Retribution
    South West
    Yep
  7. Aug 6, 2012 at 10:54 AM
    #67
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2018 4Runner LE
    TRD Pro Wheels BFG AT Tires
    Sub'd for ref.
  8. Aug 12, 2012 at 10:38 AM
    #68
    subliminalbmx
    subliminalbmx New Member
    Dan
    South Jersey
    02 single cab sr5 2.7L 4x4 5 speed
    K&N 57 Series FIPK Performance Intake Kit. Flowmaster 40 Series Delta Flow 409S 2.25"IN/OUT Muffler. Converted to 2004 TRD 16in alloy rims and has some nice Falken High Country A/T tires. Front Skid Plate, hand made in NJ by someone, out of heavy steel. 2 matching front tow hooks. Kobalt diamond plate low-profile tool box. Painted front brake calipers with red brush on caliper paint kit. painted rear drums with black spray on brake paint, (painted before ever used) Depo Clear front corners. LED taillight bulbs, front turn signals, front parking lamp, reverse light, license plate light.
  9. Aug 14, 2012 at 7:11 PM
    #69
    akaryanreynolds
    akaryanreynolds STRIKER TRD
    Los Angeles
    2012 DCLB MGM TRD Sport 4x4
    Debadged, Tint, Euro Antenna, OEM Roofracks, OEM skid plate, SMD LED interior lighting, AFE ProDry Drop-in, FX-R 6000K headlights w XB halos, VHT taillights, Fog light mod, Flyzeye V2W, T-Rex T1 Eyelids by Toyota Man, King 2.5 resis Front and Back, Devil Horns by Andres, Redline Hood Struts, PIAA 2500K H11 Fog Bulbs, Escort 9500ix, Ultra Gauge, Cobra 75 WXST, Firestik II w/ Quick Disconnect & Spring
    ^^^^^GOOD to know! Any suggestions on a brand or website to buy high quality HIDs??
    Harleroy likes this.
  10. Aug 17, 2012 at 8:18 AM
    #70
    Rebel Taco Man
    Rebel Taco Man Well-Known Member
    Tyler
    Western Kentucky
    2002 Manual TRD SR5 4x4
    Bilsteins front and rear, Eibachs up front, 2" Toytec AAL in rear, Diff Drop, Grey Wire Mod
    So do all these light #'s match up to the older 1st gens? im wanting to swap out all my lights to leds. and cant find anything about this being done in the 1st gen section thanks.
  11. Sep 23, 2012 at 6:21 PM
    #71
    doc1911
    doc1911 Well-Known Member
    NC
    2018 Pro
    Is the original bulb list for 1st or 2nd Gen or both?
    Is the list in the manual? I need a list for 1st Gen.
  12. Jan 2, 2013 at 9:06 AM
    #72
    Gadsden
    Gadsden Active Member
    Nor-Cal
    04 Tacoma
    Bump... I'm looking for 1st Gen also
  13. Jan 2, 2013 at 9:11 PM
    #73
    Drunknsloth
    Retribution
    South West
    I'm not sure what you mean by wiring them to the relay for the amber corners. Do you want them to come on with the amber corners?
    The one already that comes with the fogs. The wire goes from the battery positive to the fuse to the relay pin 30.
    The ground is for the light on the switch. I'm assuming the light on the switch comes on when the switch is turned on. The switch will need a fused power source. It doesn't matter if you use the same power source as the fog lights like in the diagram above or a separate fused power source. I recommend using a separate power source and putting a smaller fuse on it because the switch most likely doesn't handle the amps that the fog lights need and the relay does not require that many amps. I would recommend using an add-a-circuit to your internal fuse box and using that as a power source for the switch. The outgoing of the switch will go to pin 86 of the relay so when the switch is turned on the relay will connect the circuit from 30 to 87. Pin 85 will need to be grounded for the relay to complete the circuit.
    If the fog lights did not come with a relay you will need to buy one.
    http://www.radioshack.com/product/index.jsp?productId=3020762
    Local Radioshack, Autozone, or O'reilly's
    You will need one that can handle more amps then your fog lights need and that you are fused for.
    Add the relay, you'll be safer.
    Hope this helps.
  14. Feb 7, 2013 at 12:46 PM
    #74
    pidro_el_pirata
    pidro_el_pirata Well-Known Member
    Me too. It seems to be for both but not explicitly mentioned
  15. Feb 9, 2013 at 11:19 PM
    #75
    whonoez
    whonoez Well-Known Member
    Jay
    Bay Area
    2013 Tacoma TRD Sport DCSB
    3"lift, Monster XD w/ 285/65/18 Nitto Trail Grapplers, Blacked out emblems, tinted front windows, BHLM
    Cool thread. Sub'd
  16. Mar 13, 2013 at 8:29 AM
    #76
    cvisinho
    cvisinho Well-Known Member
    Rhode Island
    2005 TRD Sport DCSB new frame edition
    Bilstein 5100's, Eibach springs, Cali Raised Amber fogs,Cali Raised side projecting ditch lights, 17" gunmetal trd pro reps w/ falken wildpeaks, MESO interior lighting, Alpine ilx Android auto head unit, rear view camera, blue sea fuse panel, mbrp cat back, Morimoto retros in Depos, Ranch cap, triple black clazzios, DIY thin lip satoshi with FJ letters, oem roof rack, AJT climate knobs, slim sub behind rear seat, fosgate speakers all around, thule cap rack
    seems a couple questions are not clearly resolved.
    bulb size behind fog light button?
    bulb size behind hvac dials?
    These seem to be the twist lock subminiatures.
    I see the PLCC-2 SMT LEDs listed as dash gauge bulb type but there are different sizes behind the dash it seems.
    Neo-3 Neo-4 Neo-5 from www.superbrightleds.com seem to fit the bill but what size is the question.
    Does anyone have those and can update this thread with specifics?
  17. Jun 23, 2013 at 1:30 PM
    #77
    HOOTERBIRD
    HOOTERBIRD Yeah You Right !
    NOLA
    2013 DCSB TRD Sport, 4X4
  18. Sep 18, 2013 at 1:14 PM
    #78
    tonytsai0429
    tonytsai0429 Well-Known Member
    SoCal
    Racy Inferno
    Hi Viet, possible to post those picture again for the head light adjustment, many thanks in advance, i have a 2013 tacoma, wondering if the same
  19. Dec 3, 2013 at 12:32 PM
    #79
    Naholo808
    Naholo808 Well-Known Member
    Jordan
    9th Island (Las Vegas)
    2020 4Runner Off-Road
    2020 Toyota 4Runner Off-Road 3inch lift 33s Ko2s Matte black SCS SR8 2013 Tacoma TRD Sport 2wd - Traded In.
    Will I have hyper flashing if i swap out my rear turn signal to LEDs?
  20. Dec 3, 2013 at 12:33 PM
    #80
    Oregon TRD
    Oregon TRD "GO DUCKS" Edition
    Ross
    Steel Panthers bathroom floor!
    2005 Mall Krawler
    6" Fabtech Lift, 35" Fierce M/T 17" Eagle Alloy Sim bead locks Naked girls in the bed 10.1" DVD head unit Two 7" Headrest Monitors PS2 in glove box
    Yep. But you get used to it.
