Lightweight Wheels?
Discussion in 'Wheels & Tires' started by WATacoRider, Feb 6, 2013.
  1. Feb 6, 2013 at 11:32 PM
    WATacoRider
    WATacoRider [OP] Well-Known Member
    TRD Sport 4x4
    Is there a lightweight wheel for the 17" group? Lighter than stock? This seems like an easy way to save gas. No?
    Now I'm curious as to how much the stock wheels weigh.
  2. Feb 6, 2013 at 11:55 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
  3. Feb 7, 2013 at 6:37 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    The stock TRD Sport wheels, 17x7.5, weighs about 25.5lbs.
  4. Feb 7, 2013 at 6:38 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    Fixed, thanks Chaz:thumbsup:.
  5. Feb 8, 2013 at 8:53 AM
    WATacoRider
    TRD Sport 4x4
    I actually like that matte black Stealth6, but it appears to only be in 17x8.5". I was hoping for an exact OEM replacement since I don't want to have to buy new tires too.
    Would be ~2lb savings too. I wonder what that translate into IRL performance.
  6. Feb 8, 2013 at 9:17 AM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    No problem, but to be fair the Konigs were about a half lb lighter than your 5s ha I almost got them anyway for that retro look though! :cool:
  7. Feb 8, 2013 at 12:56 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    If your stock tires are 265/65/17, they're approved for an 8.5" wheel;). You don't necessary to have to upsize right now.
    You can go wrong with either wheel. Both are lightweight and within a few ounces of each other. Your truck looks great!
  8. Mar 12, 2013 at 7:26 AM
    snipes285
    snipes285 Member
    2013 TRD Quad cab
    Hood deflector, window vents, Tonneau cover, NFab nerf bars
    I was also looking to save some weight on a new set of rims. I wanted to keep my winter tires on the stock rims and mount the OEM rubber on something nicer. I purchased a set of SCS Stealth 6 rims along with some Mcgard spline lug nuts, both in gloss black.
    Both tires are stock size (265/65R17)
    The difference in weight with the SCS set-up is a reduction of 5.4lbs per wheel!
    I am VERY happy with the look and the way they feel so far. I know the OEM rubber sucks but, getting the rear to spin on acceleration and the way the truck accelerates now puts a big smile on my face.
    These rims also stick out further than stock, I believe by 2.2 inches according to Vin at SCS. I believe this also contributes to how planted the truck feels in aggressive cornering now!
    I'll be watching my mileage over the next few fill ups, I would expect it should be better as well...if I can control the jack rabbit starts.....
    Vin was awesome. He replied to all my email questions, got the shipment on the way asap and provided absolutely EXCELLENT customer service!!
    Cheers!
  9. Mar 12, 2013 at 1:05 PM
    JdMeF9SiR2
    JdMeF9SiR2 FN Wheels
    Corona, CA
    05 Tundra 06 Tacoma 14 FJ Cruiser 19 Tundra
    The 17x8" Konig Countersteer Type X is under 21lbs per wheel, and works great with stock tires (265/65R17) or larger tires. The 8" wheel width won't make your stock tires looked stretched out as would happen with a wider wheel.
    Available in anthracite light gunmetal, matte black or matte bronze.
    http://www.fnwheels.com/new-products/konig-countersteer-type-x/
  10. Mar 12, 2013 at 2:58 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    I like the 16" countersteers better because of the curved profile spokes.
    I'm hoping to get me some 16" countersteer off roads soon myself, wrapped with duratracs.
    :spy:
  11. Mar 12, 2013 at 7:00 PM
    JdMeF9SiR2
    Corona, CA
    PM sent to you. ;)
  12. Apr 5, 2013 at 7:14 AM
    jmandeville
    jmandeville Member
    Justin
    Alabama
    None yet
    @ SNIPES285 I was wondering if you had any numbers for miles per gallon now that you have had your wheels for awhile? I'm looking to get either one of these wheels and wondering how they will help my milage.
  13. Apr 5, 2013 at 11:35 AM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    I can tell you I went from heavy wheels and 28" tires to Light wheels and 31.7" tires that were significantly wider and slightly more aggressive tread and didn't lose any mpg (I also did some exhaust mods in there so not exactly definitive, plus I have a much weaker engine than you so the help is more drastic).
  14. Apr 5, 2013 at 12:47 PM
    jmandeville
    jmandeville Member
    Justin
    Alabama
    None yet
    I plan on doing a similar wheel tire setup as what you have. Just curious if the countersteers are worth the extra money.
  15. Apr 6, 2013 at 7:22 AM
    snipes285
    snipes285 Member
    2013 TRD Quad cab
    Going from my stock rims (17") with winter tires to the SCS Stealth rims and the OEM rubber, I lost a total of 5.4 lbs per wheel.
    Acceleration feels more agressive as does the handling. On my first tank of gas with these, my milage was the same but, I was accelerating from lights and passing much harder than I would normally do (having some fun!).
    My last fill up, however, was the best milage I've seen with the truck so far.
    I normally see a 21.5 m/gal, last fill up showed 23 m/gal. I know there could be a number of factors contributing to milage but, it was the best I have seen.
    I seriously considered the Countersteer's (even lighter). Both companies had great service and would respond all emails and were very helpful, I believe they both have a quality product. The Countersteers were more expensive but, it really came down to style of wheel. I preferred the look of the Stealths.
    You cant go wrong either way.
  16. Apr 7, 2013 at 12:57 PM
    jmandeville
    jmandeville Member
    Justin
    Alabama
    None yet
    I'm pretty torn between the f5's and countersteers. If they were the same price I would probably go countersteers. But for the price of them I can get the f5's and a CAI.
