Like new JL AUDIO FIX 82 $250.00
Discussion in '3rd Gen Tacoma Parts Marketplace (2016+)' started by MannyTheAudioGuy, Oct 20, 2019.
  1. Oct 20, 2019 at 9:51 PM
    MannyTheAudioGuy
    MannyTheAudioGuy [OP] Well-Known Member
    Emmanuel
    Napa
    2017 Tacoma TRD Sport
    I have put in Racesport gen3 leds I'm the process of doing a custom audio overhaul which will include Hybrid audio unity 6x9 mid bass, unity 3 inch mid driver in the dash and fiberglassing tweets in pilar soundeading all the doors, floors, and headliner and I will be using a helix processor to retain the factory radio and as far as subs I might make custom brackets to move rear seat foward a few inches to get a full size sub in there or I might just go with a pair of jl tw5 or tw3 and it will all be powered by jl audio HD amps or I might try out the new hybrid amps
    For all of you thinking of upgrading your oem sound system I have a jl audio fix 82 which will take all of your speaker inputs from your factory head unit and clean and de-eq the signal and will give you a optimized 2 channel rca output or fiber optic output which you can then send to your amps or dsp! For you old school guys think of it as a audiocontrol lc7 but on steroids
  2. Jan 21, 2020 at 12:56 AM
    MannyTheAudioGuy
    Emmanuel
    Napa
  3. Jan 21, 2020 at 12:56 AM
    MannyTheAudioGuy
    Emmanuel
    Napa
    Make offers!
  4. Jan 21, 2020 at 5:44 AM
    Tac0Man
    Tac0Man Well-Known Member
    Evan
    New York
    2018 TRD Off-Road
    OEM Roof Rack OEM Flaps 18% Tints to match the back Pro Grill MESO V4 Turn Signals MESO Gasshole Coming Soon: Fuel D664 265/70R/17 K02s
    I am novice here, but to my understanding this would go between the head unit and factory amp (in JBL trucks) so we can get away from that horrible POS that overheats constantly?
  5. Jan 21, 2020 at 9:45 PM
    MannyTheAudioGuy
    Emmanuel
    Napa
    This is a summing dsp that takes the output from any factory radio or amplifier and it corrects the signal so that you end up with a clean flat signal go send to your amps
  6. Jan 21, 2020 at 10:18 PM
    Stretch2323
    Stretch2323 Well-Known Member
    2016 OR
    Will this help an aftermarket unit?
  7. Feb 17, 2020 at 8:33 PM
    MannyTheAudioGuy
    Emmanuel
    Napa
