Limited Slip Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MaGuyver, Nov 23, 2020.
  1. Nov 23, 2020 at 8:02 PM
    MaGuyver
    MaGuyver [OP] Well-Known Member
    Savannah, Ga.
    2020 Tacoma Sport, Cement
    Tinted glass, Bed mat, Rigid light bar, Bakflip FiberMax tonneau, Bull bar, LED cabin lights, Bed lights.
    I am looking at a 2019 Tacoma Limited 4wd. Is limited slip automatic with a 4wd or not possible. Do some models offer L/S and not others? I am not sure how it works.
  2. Nov 23, 2020 at 8:18 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    TRD Offroad and Pros offer a locking rear differential alongside the brake actuated simulated limited slip diff that comes with the truck. It's not a true limited slip diff, but in my experience it works well enough.
    Chew likes this.
  3. Nov 24, 2020 at 3:41 AM
    MaGuyver
    Savannah, Ga.
    On my 2007 TRD I get tire slip or spin when taking off at a light occasionally when I give it a little too much gas, especially when aspholt is wet. This happens because there is no l/s on, just rear locker. Is the ‘19 limited set up to stop wheel slip?
  4. Nov 24, 2020 at 3:56 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
  5. Nov 24, 2020 at 4:20 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    No limited slip will entirely eliminate wheel slip, but you aren't going to be burning the tires or anything. I don't believe any Tacoma has a true LSD though. Just an ABS stimulated one which works pretty well.
    Chew likes this.
  6. Nov 24, 2020 at 4:26 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    I will also add that on my 17 sport the auto LSD only comes on in 2wd. I should say, the light on the dash illuminates when in 2wd on the trails in the mud. Once I flip into 4wd HI, the light no longer comes on. Leading me to believe the auto LSD does not operate in 4wd, which makes little sense to me as I feel it would be well suited on light muddy trial rides. I could be wrong, just what I have noticed.
  7. Nov 29, 2020 at 11:40 AM
    MaGuyver
    Savannah, Ga.
    Hey, thanks for the help guys. I ended up with a 2020 2wd sport with L/S.
