Line-X for different parts of my Truck??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iDRiVaTRD, Oct 18, 2009.
  1. Oct 18, 2009 at 11:14 AM
    iDRiVaTRD
    iDRiVaTRD [OP] Well-Known Member
    San Marcos, CA
    I know some have Line-X'd their stock plastic fenders and bumpers but....
    1. I just ordered the rear All-Pro Bumper from the group buy and I was thinking of getting it Line-X'd. I was thinking about just rattle can it black but would rather get something that will look better and last longer.
    Or should I just use Herculiner on it? Never used the stuff so not too sure how it works or will look all said and done.
    2. My sliders are welded onto my frame, I rattle canned those black but they have since started to rust. Would Line-X be able to spray those since they are mounted or should I use Herculiner on those?
    3. One last thing I was thinking of doing. I want to remove the stock plastic fenders. The only thing is since my truck is silver, those little holes that hold the plastic fender would stick out like a sore thumb. I was thinking about maybe have line-X sprayed to the stock metal fenders where the plastic fenders were. It would in turn make my truck look like the All-Terrain edition and would maybe strengthen the stock fenders a little. I could even trim the fenders a little to allow more tire clearance when stuffed. With them now being black, the fender mounting holes and trimmed fender would not be all that noticeable.
    Or I could use Herculiner on those too after I become familiar with the stuff.
    **What do all think, should I attempt all this, which material would be the best and etc? How does Herculiner and Line-X stand up to sun? Would they begin to fade after a certain time?? Thanks for your help.
  2. Oct 18, 2009 at 3:23 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I've used Herculiner on many things....my 96 tacoma bed, rock sliders, my jeep interiors, etc. I had the stuff on for about 5 years. Areas that were exposed to the sun/weather, it can fade over time. And - I did have areas that wore thin also. Although, Heruliner is cheap enough and easy enough to repaint it without any prep work. I had no complaints.
    You can keep the Herculiner looking black by putting 'tire shine' on it - but that makes everything slippery as shit....so if you're stepping on these ares, don't use tire shine.
    On the rocksliders - I put it on the tops & side but not the bottom. The rocks will only rip it off in no time at all.
    Have you thought about having the bumper & sliders powder coated? That might be more durable in terms protection from rust (instead of Herculiner).
    I can't speak for the professionally applied Line-X. I know its thicker...but it also costs a lot more.
    I wouldn't recommend putting any Herculiner or liner on the fenders. Cuz - you might regret it afterwards and it'll be one hell of a mess trying to get it off - but that's me.
  3. Oct 18, 2009 at 4:20 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
  4. Oct 18, 2009 at 4:32 PM
    SubZombie
    SubZombie Well-Known Member
    South East
    2019 Voodoo TRD Pro
    The problem with rhino liner is its really rubbery and kinda soft and not all that hard to tear into, and once you get one tear it all starts coming off from there. It also has a cottage cheese texture.
    Its good for a bed to keep stuff from sliding around though.
    Line-x is harder and stronger and smoother.
  5. Oct 18, 2009 at 4:41 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    As a former Rhino liner dealer, I'm a little biased, but I can guarantee you it is MUCH better of a product and will look much better than Herculiner. They will also stand behind their product.
  6. Oct 18, 2009 at 4:44 PM
    cheehab
    cheehab I bleed Black and Gold
    Adam
    Winter Park, CO
    2015 Tundra TRD Pro CrewMax
    Might I ask why you're going to remove the stock fender flares? IMO they do serve a function, and aren't just there for looks. If you go with a wider tire at all you'll be flinging rocks and dirt and shit everywhere.
  7. Oct 18, 2009 at 6:49 PM
    Kenny650
    Kenny650 Well-Known Member
    I think he wanted more clearance. :notsure:
  8. Oct 19, 2009 at 8:37 AM
    iDRiVaTRD
    San Marcos, CA
    My front tires when compressed fully rub the rear portion of the front fenders. Removing the Plastic fender would give me about another inch of clearance. I'm already running wider tires so I've gotten used to dirt flinging. Another 1/2" less fender width not gonna bug me too much. Those square little holes that hold the retaining clips very noticeable though on my silver truck. That's the only thing that bugs me.
    I've had powder coated bumpers in the past and the powdercoat would start peeling away after a few hits and scrapes off road. Maybe it was a cheap powdercoat that those bumpers had but I just don't want to risk it again. I'll research a bit more on herculiner and see what I'm gonna do. That sounds like it would be better since I can always touch it up from what I read.
  9. Oct 19, 2009 at 1:17 PM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    If you're going to put herculiner on the fenders, might as well patch the holes before you paint it. It would look even better and not leave open areas for the liner to start peeling off...
