Line-X Locations (SoCal, AZ)
Discussion in 'Product Reviews' started by boshak, Feb 6, 2011.
  1. Feb 6, 2011 at 9:28 AM
    boshak
    boshak [OP] Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    I'm looking to get Line-X for my bed. Can anyone vouch for certain locations that you've had experience with specifically in LA, OC, SD, and Arizona? I'm in these areas most often.
  2. Feb 9, 2011 at 7:48 PM
    boshak
    AG
    CA
    Bump... Anyone?
  3. Apr 1, 2011 at 9:07 PM
    fastguy95
    fastguy95 A man knows nothing
    SF Bay Area
    02 DC 4wd
    All Pro front/rear bumpers, OME 883's with Bilstein 5100 all around, Deaver J59 springs, TRD E locker, E locker Guard, Red Line hood struts, Weathertech floor mats, SS brake lines, EBC Rotors and green pads, Debadged, Line X, BAMF brake relocator bracket, Beefed Taco cb drop, Magnaflow muffler, Scuba Mod, live power outlet mod, disable door buzzer mod, tinted windows, light blinker conversion, Alpine HU, Infinity Kappa 600w amp, JL Audio 1000w amp for sub, JL Audio W3V4 12" sub, JL Audio 6x9's, Retrofit projectors bixenon 55w, Dynamat on all doors, and light bar.
    Just came across this older thread.
    I got my 02 double cab line x'd at the line x location here:
    2273 La Crosse Ave # 101, Colton, CA 92324-4463 (909) 783-1577 ‎ .
    I believe the guy's name is Dan. Took about 3 hours total...most of it was prep work. Definitely would recommend these guys.
  4. Apr 4, 2011 at 8:37 AM
    Brewman
    Brewman Member
    Minneapolis, MN
    2011 Access Cab 4X4
    Try searching for locations in that area, then google on those businesses to see if you can find any ratings. Checking the BBB for those locations might be somewhat useful too. It won't point out really good places, but may warn you off of any really bad ones. To get a bad mark from the BBB you have to be really bad.
  5. Apr 4, 2011 at 11:24 AM
    Manwithoutaplan
    ID
    Line X in Monrovia on Myrtle and duarte had good luck with them.
  6. Apr 4, 2011 at 11:08 PM
    boshak
    AG
    CA
    thanks guys... ended up using the line-x shop in torrance that weekend. for someone else's reference in the future:
    check out line-x in torrance. they did a great job... took 3.5 hours but a lot of it was prep work as mentioned above. the best thing you can do to judge a shop is by asking the owner to give you a tour of the shop. when a shop is clean/organized and open to showing you around, it shows they proud of their shop and take care of it. IMO, it's also a good sign they'll take good care of you and your truck.
  7. May 2, 2011 at 9:19 AM
    steve p
    steve p New Member
    sw va,
    11 tx pro
    can I spray line x in a 2011 bed? It's slicker than a peeled onion.
  8. May 2, 2011 at 2:58 PM
    singlefin
    singlefin Well-Known Member
    Hood River, OR
    Syncro
    Yes you can, there is a white reg cab who had his done. Bed mat is a must with these slick beds.
