Link to 2016 oil filter wrench
Discussion in '3rd Gen. Tacomas (2016+)' started by LaPorta, Dec 8, 2015.
  1. Dec 8, 2015 at 6:42 PM
    LaPorta
    LaPorta [OP] Well-Known Member
    Can someone link to where I can purchase the oil wrench fitting for the oil canister? I'd like to get one that works off a ratchet wrench, if possible.
  2. Dec 8, 2015 at 6:44 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    kngharley likes this.
  3. Dec 8, 2015 at 6:48 PM
    LaPorta
    Much obliged!
  4. Dec 8, 2015 at 6:52 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    wow, already had it long enough for an oil change. isn't it a 10,000 mile interval motor?
  5. Dec 8, 2015 at 6:53 PM
    LaPorta
    Just want to make sure I have one, and I plan to change at 500-1,000 to get the fine metal and other products that accumulate as the engine wears itself in. I was told that it is a 5,000 mile interval. Can anyone either confirm or refute?
  6. Dec 8, 2015 at 6:58 PM
    ZachPrerunner
    Southeast TN
    Sometimes car manufactures place "special chemicals" in the oil to assist in the break in period. I'm not sure whether or not the Tacoma utilizes this, but I'd go around 7,500 before changing it. I believe the 2016 Tacomas are suggested to be changed at the 10,000 mile interval anyway. Do you have a manual on hand?
  7. Dec 9, 2015 at 3:56 AM
    mz3onturn7
    mz3onturn7 Member
    I have never heard of manufacturers adding these "special chemicals" to the engine oil before the vehicle leaves the factory. If you have a source or a reference for this information I would like to read about it. Perhaps you could post a link. Thanks in advance.
  8. Dec 9, 2015 at 4:14 AM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Changed mine at 800. You'd be amazed the amount of casting flash, casting sand, and other wear metals that are in the oil for the initial break in.
  9. Dec 9, 2015 at 8:01 AM
    proven21
    proven21 Well-Known Member
    Sterling, VA ( Loudoun County)
    2016 Taco DCSBOR 4x4 - Super White
    OME 90021 Front Strut 2887 Coils & OME N182 Rear Shocks, Wheelers Progressive AAL Pack, TC UCA's, BFG TA KO2 285/70r17 w/ 17" Method Wheels, AVS Window Visors, CoverKing NeoSupreme Seat Covers (charcoal/black), Mobtown Offroad Sliders, Relentless Fab. Bed Rack.
    i was told 5k mi.
  10. Dec 9, 2015 at 8:10 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    North DFW
    19 Tundra
    With the cartridge style your truck has, I'd recommend one with the notches on the side like pictured below to help keep anything from slipping. I don't know what size the new trucks take; otherwise I'd link you to an actual product.
    I got one from the dealer for my wife's Camry.
    TopherWV likes this.
  11. Dec 9, 2015 at 11:49 AM
    LaPorta
    Dude, that's like a disco tool!
  12. Dec 9, 2015 at 12:09 PM
    TopherWV
    TopherWV Well-Known Member
    Christopher
    OH
    16' DCLB OR Inferno
    I've heard of this too... below is a link and states:
    "a Honda spokesman says its cars come from the factory with a special oil formulation for the break-in period. Honda advises owners to not change the oil early. Stark said Blackstone Laboratories' test of Honda's break-in oil shows it contains molybdenum-disulfide, an anti-wear additive. But Stark said Honda is the only manufacturer he knows that's using special break-in oil. The take-away? If there are any special break-in recommendations from the manufacturer, follow them. And consider analyzing the oil at 3,000 miles."
    http://www.edmunds.com/car-care/top-7-urban-legends-about-motor-oil.html
  13. Dec 10, 2015 at 1:30 AM
    mz3onturn7
    mz3onturn7 Member
    That was a good read, thanks for the link. The manual for the 2106 Taco outlines a few very generic precautions regarding the first 1000 miles but there are definitely no "special break-in recommendations" outlined in the manual. In my opinion an early oil change is a very good idea as it removes the fine debris from the manufacturing / assembly process that isn't captured by the oil filter and gets rid of any extra sealant, assembly lube etc. that may be mixed in with the oil.
    It may not be necessary to change the oil early but I can't see how it would hurt. It cost me less than $40 CDN to change mine out and I would consider that cheap peace of mind. I will post a picture of what I got out of the used oil after 290 km.
  14. Dec 10, 2015 at 1:55 AM
    mello03
    mello03 Salute the flag.
    Greensboro, NC
    2018 Taco Turd
    The only manufacturer I've ever seen that uses "break in fluid" is BMW in their M cars.
  15. Dec 13, 2015 at 5:56 PM
    LaPorta
  16. Dec 13, 2015 at 6:33 PM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
  17. Dec 13, 2015 at 6:37 PM
    LaPorta
    Looks like that is only for 1.8L engines.
  18. Dec 13, 2015 at 6:38 PM
    qnyla
    NM
    64mm 14 flute...should be the same.
  19. Dec 13, 2015 at 7:24 PM
    Northwoodshyun
    Northwoodshyun Well-Known Member
    St. Paul MN
  20. Dec 13, 2015 at 9:12 PM
    mikmabz
    mikmabz Well-Known Member
    2016 Magnetic Gray Metallic Tacoma 4x4 TRD SPORT DCLB
    Roof Rack, Side Step Bars, Chrome Exhaust Tip
