Little to no grease in the driveline?
Discussion in '4 Cylinder' started by crashnrondo, Mar 18, 2011.
  1. Mar 18, 2011 at 7:20 AM
    crashnrondo
    crashnrondo [OP] Well-Known Member
    Ron
    Wisconsin
    2021 DCSB Limited
    I just did a 5000 miles service on my 4x4 last night and along with changing the oil and filter, rotating the tires I thought I would lube the drive line with Mobile 1 just for grins. I have a air powered grease gun and it took at least 20 shots on each zerk before the old grease even started to come out:eek: It only took 10-12 before it turned red from the new grease. I guess I should have done this as soon as I got home with the truck the first day.:(
  2. Mar 18, 2011 at 8:59 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    You are lucky to have zerks.
  3. Apr 3, 2011 at 10:40 AM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    Same here, you are not alone and not exaggerating when you say 15+pumps. I went through a whole tube of grease at my 5k. I bet they put in small amount at factory and the rest is supposed to be done at dealer for prep or at the first 5K service. O well I am glad I did it.
  4. Apr 6, 2011 at 7:36 AM
    Reepur
    Reepur Well-Known Member
    Brevard, NC
    '10 RC Black 4x4 2.7L
    265/75/16 BFG KM2 's on XD Hoss's 2.5" lift/4xBillies, OME 885's, Firestone Ride-Rites Desert Specialties UCA Volant CAI Grillcraft Grill Kobalt Slim Line Box Weathertech mats and Ventvisors. DTRL mod. 4 Lo -Trac Mod. Int. Wiper Mod. rcbs204 4x4 LEDS URD Short Shifter Plate Front bumper with Smittybilt XRC8000 winch Body Armor rear bumper with swing out tire carrier. ATO Front Skid Ultragauge BHLM
    ditto, just greased mine and they had little or no grease at all.
  5. Apr 6, 2011 at 11:19 AM
    JEA86
    JEA86 Well-Known Member
    Jeremy
    WV
    2016 TRD Off-Road
    i hate to sound dumb but this is my first truck can someone psot pics of what your a re supposed to grease up?
  6. Apr 6, 2011 at 12:48 PM
    crashnrondo
    Ron
    Wisconsin
    2021 DCSB Limited
    Sorry no pics but there are 5 or 6 grease zerks on the driveline, don't forget the front drive shaft zerks to
  7. Apr 6, 2011 at 12:51 PM
    georgeandkanoa
    georgeandkanoa the point is simply this
    jeff
    calgary
    07 tacoma trd
    bilstein5100's front tinted windows access cover pioneer stereo weathertechs grillcraft grill kc's behind cbi sliders
    there's a write up somewhere in here about that, with pictures
    try a quick search it might pop up for you:eek:
  8. Apr 6, 2011 at 1:51 PM
    JEA86
    Jeremy
    WV
    2016 TRD Off-Road
    oh i figured there would be i just thought it might be good to have a link in this thread as well js
  9. Apr 6, 2011 at 3:00 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Any hints on getting grease into the front drive shaft zerks ? The back ones are easy but the front ones are hard to get to. I can't seem to get the grease gun couple to snap on tight to the zerk and the grease goes out around the zerk instead of into the zerk. Thanks for any ideas.
  10. Apr 6, 2011 at 3:13 PM
    george3
    New Jersey
    I got the Flexible hose. The problem is the fitting on the end that goes on the zerk seems to be just a little to big and doesn't snap on tight enough. I just thought someone might have had the same problem and figured a way around it. BTW I used to take it to a quick lube place. They said I didn't have and zerks. I said yes I do. They said oh yeh we'll grease em. Well the front ones squirted water the first time I greased it. Scary :eek:
  11. Apr 6, 2011 at 3:51 PM
    george3
    New Jersey
    I got to check this out. "You can adjust the tip to be tight or loose on the zerks" The one I looked at today didn't adjust. I'll check the guys at work tomorrow on this.
  12. Apr 6, 2011 at 4:10 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    This is the first I've heard of zerk's on the front drive shaft of the 2nd generation trucks...where are they exactly?
    Be careful if the grease gun tip is adjusted too tight. When pulling it off the zerks never do it at an angle...allways pull straight back. The zerk fittings aren't that strong and can snap in half. Some of the zerk's are pressed in...can't just screw in a new one!
  13. Apr 6, 2011 at 4:14 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    Anyone have pics (location pics) of the zerks on a on a 4x4 and a 4x2 ?
  14. Apr 6, 2011 at 4:20 PM
    OffroadToy
  15. Apr 6, 2011 at 5:09 PM
    george3
    New Jersey
    Thanks whippersnapper, I'll see how I do and let you know.
  16. Apr 6, 2011 at 5:15 PM
    SOSHeloPilot
    2024 4Runner SR5
    :thumbsup: ... Thanks
  17. Apr 6, 2011 at 5:20 PM
    Manwithoutaplan
    ID
    I grease my zerks all the time.. i be zerking off.
  18. Apr 6, 2011 at 5:40 PM
    Manwithoutaplan
    ID
    hahahaha. will do
  19. Apr 6, 2011 at 5:45 PM
    Manwithoutaplan
    ID
    my zerk gun is hand pumped.... just like my penis pump. :)
  20. Apr 6, 2011 at 5:59 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    do first gen 4x4s have zerks also? thanks!
