Load E or Load C on trails in Hawaii
Discussion in 'Hawaii' started by Chex808, Aug 29, 2018.
  1. Aug 29, 2018 at 11:49 PM
    Chex808
    Chex808 [OP] Well-Known Member
    Hawaii
    2017 Super White DCSB
    Was wondering what you guys were running and if you've had any trouble with C-loads on the trails here.
    HNLSFO1 likes this.
  2. Aug 29, 2018 at 11:56 PM
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    2021 T4R TRD Pro
    Most of us run E because it’s the only option for 33” tires. I’ve never read much bad in the way of C. It’s all how the tire sidewall is made, and that’s independent of load rating index.
    89hatcher, Rob Daman, HNLSFO1 and 2 others like this.
  3. Aug 30, 2018 at 10:33 AM
    Vigo
    Vigo WFO
    On a rock in the pacific
    '12 4 door
    stuff...
    Not all true. You can get C rated in
    255/75r17
    285/70r17
    35x11.5x17
    40x13.5x17
    those are trail grapplers
    I don't think anyone in the Hawaii section needs or makes full use of E rated tires. Where loads justify running 60-80 psi. C rated tires cant handle as much load, but should be lighter.
  4. Aug 30, 2018 at 10:59 AM
    seoulja99
    seoulja99 Well-Known Member
    E.J.
    Oahu
    2012 DCSB 4x4 V6 TX Baja (1GR-FE)
    all things mall rated
    “Should” be lighter, but not every time. Example, Nitto Ridge Grappler.
    Weight of C vs E are the same for a few of the sizes like 285/70R17.
    Sauce:
    https://m.nittotire.com/light-truck-tires/ridge-grappler-light-truck-tire/
    Does anyone know if there are 35x12.50 in load C? I guess I could have gone 35x11.5 but not a fan of Nitto Trail Grapplers. LOL.
    And as for needing or making full use of load E...that could be said about a lot of our mods. No one needs 35” tires, SAS, or a supercharger; but...it sure makes it fun to personalize our trucks. :D
    Vigo[QUOTED] and kakwvu like this.
  5. Aug 30, 2018 at 1:25 PM
    lemon177
    lemon177 Well-Known Member
    Matthew
    Oahu
    09 tacoma 4x4 sport pyrite mica
    TRD supercharger, URD 2.85" stealth pulley, TRD exhaust, TRD intake, DTLT headers, URD y-pipe, TRD boost gauge, PLX DM100 touch with OBDII and SM-AFR modules, 885 OME 3", Icon UCAs, Satoshi grill, Solid rear window, SCS stealth 6, 285/75/17 toyo AT2.
    I think bfg has a c load 35 (tires that come with raptor from the factory)...they still weigh alot tho
    seoulja99 likes this.
  6. Aug 30, 2018 at 2:26 PM
    kakwvu
    Kyle
    WV
    2021 T4R TRD Pro
    I said most. 17” wheels are a different story, and still few and far between.
    Like @seoulja99 said, Nitto C rated are just as heavy for the most part.
  7. Aug 30, 2018 at 6:08 PM
    Vigo
    Vigo WFO
    '12 4 door
    stuff...
    That is why I wrote "should" be lighter and not will be lighter.
    You said
    "Most of us run E
    because it’s the only option for 33” tire"
    I read it as most (people) run E
    E is only option for a 33
    and yes, there are a greater selection when dealing with 17s
    kakwvu and maxtherat like this.
  8. Aug 30, 2018 at 6:13 PM
    kakwvu
    Kyle
    WV
    2021 T4R TRD Pro
    :cheers:
    Vigo[QUOTED] likes this.
  9. Sep 4, 2018 at 9:46 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    A lot of the tires larger than 33" are available in load C/D because of Jeeps. 33s are a common tire for full size heavy duty trucks, so that's why you see so many in load E.
    My 37s are D.
  10. Sep 4, 2018 at 11:32 PM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    Had DDs.. there not all what their cracked up to be..
    Oh.. we talking about tires.. :rofl:
    In that case, I wish my Es were Cs or Ds...
    :rolleyes:
  11. Sep 14, 2018 at 12:56 AM
    Vigo
    Vigo WFO
    '12 4 door
    stuff...
