Loading a Motorcycle in a DCSB (pics)
Discussion in 'Motorcycles' started by Pugga, Oct 30, 2010.
  1. Nov 12, 2010 at 12:05 PM
    obanion63
    obanion63 Active Member
    Arnold
    San Diego
    10 SR5 4X4
    Bull Bar
    Front D-rings are nice. How did you install those? I was told that additinal D-Rings couldn't be installed due to the new composite bed.
  2. Nov 12, 2010 at 12:12 PM
    Pugga
    Pugga [OP] Pasti-Dip Free 1983 - 2015... It was a good run
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    There's a couple methods. I bought the same D-rings that are mounted in the back of the bed and drilled out two of the water drain holes in the front of the bed. I put a decent size plate washer on the underside so it couldn't pull through. I've hauled the motorcycle quite a few times like this and haven't had any issues.
    The other option is to pull the bolts that secure the bed to the frame and attach the D-rings using them. For heavy hauling this would be better since you're attaching to the frame directly.
    I opted for the drain holes because they're spaced further apart and give better side to side stability when hauling the bike.
  3. Nov 12, 2010 at 12:21 PM
    obanion63
    Arnold
    San Diego
    10 SR5 4X4
    Bull Bar
    Good deal. Thanks a lot!
  4. Nov 15, 2010 at 10:54 AM
    buck
    buck Don't sweat the petty - pet the sweaty
    Ontario, Canada
    15 DC V6 4x4 TRD Magnetic Gray
    High-flow coconut smiley-face air freshener.
    Canyon dancers allow the bars to turn. I've switched over to soft straps on the lower triples and the bars have not turned since. I don't use a chock, just park the tire against the bed wall. No issues.
  5. Nov 15, 2010 at 10:59 AM
    Pugga
    Massachusetts
    Can't get a strap to the triple tree on this bike/truck combo, it doesn't clear the fairings, believe me, I tried. I had the bed flex on me once with this truck and the tire turned so now I use the chock. Very simple/cheap fix for a potentially expensive problem. This is the only truck I've ever had that happen with by the way. I only haul the bike a couple times a year so I take my time loading/unloading, securing and traveling.
  6. Jul 22, 2011 at 8:44 AM
    dan0
    dan0 Well-Known Member
    swamplands of sc
    Sold 2011 Prerunner Doublecab 4cyl auto
    I havent hauled a bike in my DC yet. previous truck was a ford ranger, I always load the bike diagonally with the front tire held by the bedsides. also preload your suspension so it's bottomed out when you tie the bike down, if the bike cant bounce your straps wont come loose
  7. Jul 22, 2011 at 8:54 AM
    Pugga
    Massachusetts
    I wouldn't bottom out the suspension, no reason to have that much tension on the straps or on your fork seals. Just colapse them enough so they won't bounce. With my bike, colapsing them about 1/2 the travel distance works well. Depending on the bike, bottoming out the suspension puts a lot of pressure on your seals and could cause some damage.
  8. Jul 22, 2011 at 9:04 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    I also have a tonneau cover (no offense but it's in slightly better shape than yours ;). I built a brace that holds my front tire away from the tonneau. BUT it also disperses the forward pressure along the entire front of the bed. I'll see if I can dig up a photo but it's essentially a 2x6 cut to fit in the bed. Its painted black with cat litter mixed in to give it texture - holds the front from moving. I have also considered adding eye-bolts on either side of where my tire sits to add extra stability.
  9. Jul 22, 2011 at 9:13 AM
    Pugga
    Massachusetts
    What tonneau cover? :D
  10. Jul 22, 2011 at 9:26 AM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    I always use a shock brace between front tire and fender, snug as you want with no bounce. Several years ago I watched my Dads dirt bike compress and unhook one of the Ancra straps, of course the outside one stayed hooked, launching his bike off the trailer, and dragging it till he got the truck stopped. Lucky we were on a back road close to where we were to ride and was only going 30ish.
  11. Jul 22, 2011 at 9:36 AM
    Veccster
    Veccster bass turds
    Eric
    2020 Pro
    I was going to suggest a fork brace as well but I don't see how it could work on this type of bike. I started using one after my KTM fell off the back of our trailer when we hit a severe bump.
    If you are allowing room for compression in the suspension, add a bungee cord between your front straps. As the suspension compresses, the bungee keeps the connections to the bars and D-rings tight I usually run it right over my front tire. You could also use carabeeners (sp).
    Yeah...that's a nice tonneau! I've never seen one with a front skylight like that.
  12. Jul 22, 2011 at 9:40 AM
    t4daddy
    North Alabama
    Yeah great point, forgot most street bikes have the fender mounted to the lower shocks. Epic fail on my part. Works great on DS, dirt and motards.
  13. Jul 22, 2011 at 7:58 PM
    badboyrr
    badboyrr Well-Known Member
    spring branch TX
    Tacoma
    matching topper, rear air bags
    Nice write up.............here is what I use. A very good product.​
  14. Oct 14, 2011 at 2:28 PM
    LilTuffGirl
    LilTuffGirl Well-Known Member
    Nikki
    WV
    3" rough country lift leather
    I'm probably going to have to ride my motorcycle up to get whatever truck I end up getting. Is there not any other way to secure the front end in without putting the D rings in? I'm not going to be keeping the bike much longer :( So don't want to spend extra just to get everything back home. Not to mention wont have a way to drill anything while picking it up...
    Was hoping to put it in at an angle and close tail gait but I guess not..
    May have to hope someone has the day off to drive me up to get whatever truck I get...
  15. Oct 14, 2011 at 2:39 PM
    #35
    oneBIGroom
    oneBIGroom SSS
    SSS
    SSS
    SSS
    SSS
    This picture messed with my brain :confused:
  16. Oct 17, 2011 at 5:33 AM
    #36
    Pugga
    Massachusetts
    Some people have used the plastic D-rings but personally I wouldn't trust them with the weight of a motorcycle. You could get some D-rings and use the bed bolts to secure them to the frame. That would eliminate the drilling but you'd need a torx head bit and a ratchet (and maybe a breaker bar). Are you definitely getting a Tacoma? If not, most other trucks have heavy tie down points in the front of the bed (as they should).
    How come? I backed the truck up to the hill so I could just roll the bike straight on to the truck rather than have to make it drive up the ramp. Much easier and I don't even have to start the bike.
  17. Oct 17, 2011 at 10:21 AM
    #37
    buck
    Ontario, Canada
    Make sure to keep the bike in gear.... I forgot to last weekend and was wondering why my bike was moving back & forth in the bed LOL
  18. Oct 17, 2011 at 10:27 AM
    #38
    Pugga
    Massachusetts
    If you've got it properly secured, it shouldn't matter if it's in gear or not... If the bike can move, it's not tied down properly and should be secured better, in my opinion. Also, even if left in gear a motorcycle can move slightly.
  19. Oct 17, 2011 at 10:36 AM
    #39
    Whitster
    Whitster Well-Known Member
    Whit
    Golden, CO
    '09 AC w/SR5 & TRD, 6' bed
    I might also suggest the readyramp.com
    They have the arch to prevent bottoming-out and also act as a bed extender by sitting on an open tailgate, and rated at about 1000 lbs. Below is a pic of a past Silverwing, which surprisingly has a longer wheelbase than an ST1100. in the bed of an S-10. Have also carried ST1100's with no problem.
    Whit
  20. May 6, 2012 at 1:59 PM
    #40
    Pugga
    Massachusetts
    You can get cheaper D-rings from an Army Surplus store. I didn't know that at the time so I just bought OEM ones. The Army Surplus ones are only $3/ea + shipping. I actually ordered 6 of them last week for trailer tie downs.
    The ramp is an Ohio Steel folding aluminum ramp. I don't know where it was purchased, I got it for Christmas from my parents but it is a very nice ramp! When you dismount the bike, try to do the same thing as loading, find a hill, back up to it and that way when you're unloading, it's more level and easier to unload. If you have to unload from the bed onto level ground, just feather the front brake, keep it going straight and don't fight it. Takes a little practice but it's not bad.
