Locked Rear Diff
Discussion in '1st Gen. Tacomas (1995-2004)' started by WalkerH02, Apr 3, 2021.
  1. Apr 3, 2021 at 5:21 PM
    WalkerH02
    WalkerH02 [OP] Active Member
    Jacksonville, Florida
    ‘02 5 lug Tacoma
    Anyone with a locked rear diff be able to give me some insight as to what it’s like on the road? I’ve read a lot on different things but I would like to add one to my truck just for when I’m at my hunt camp on the weekends. Any insight is appreciated!
  2. Apr 3, 2021 at 5:24 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    It's used off road.
    Don't use it on road.
    Don't use it on high traction areas while turning.
    No reason not have it or be talked out of it if given the choice; its an invaluable tool that helps even a 2WD truck get over obstacles and whatnot.
    Fuergrissa likes this.
  3. Apr 3, 2021 at 5:25 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    My truck has the locking diff. It feels weird. I don't keep it locked above 20 mph.
  4. Apr 3, 2021 at 5:25 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You can't drive it on pavement when locked. When unlocked it works just like any other rear axle. Locked it offers some extra traction, but it isn't a game changer. My trucks both have one, but I wouldn't pay to have it installed after market.
    koditten likes this.
  5. Apr 3, 2021 at 5:27 PM
    WalkerH02
    ‘02 5 lug Tacoma
    I have a limited slip diff, and find myself spinning my wheels sometimes if soft sand roads, so the only way I think I could make it work with a 5 lug would be a permanent system
  6. Apr 3, 2021 at 5:27 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    While your use may not dictate having one installed, which provides no added value, but many will spend upwards of $1300 for one before install even.
    Running Board Man likes this.
  7. Apr 3, 2021 at 5:34 PM
    WalkerH02
    ‘02 5 lug Tacoma
  8. Apr 3, 2021 at 7:06 PM
    Running Board Man
    Running Board Man Well-Known Member
    Those get you going idk if you're ocd or not but the clicking/poping/banging they make when you turn on hard surfaces isn't for me, nor is the fact they don't last forever I've heard reports of them not "locking up" as hard after a few months
    Which makes sense as it's just a couple cogged wheels that engage or skip past eachother as you turn
    Honestly the best route for you is to find an elocked Tacoma axle and do the sua conversion
    It ain't the cheapest or easiest but it is the best, you'll most likely be getting taller gears too
  9. Apr 3, 2021 at 7:09 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ah, didn't realize you had an LSD installed.
    Gas and brake manipulation is a way to get the LSD to engage more often in situations where you need it. Old trick.
  10. Apr 3, 2021 at 9:00 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    Never tried it myself, but I've been told that a few clicks of parking brake can help if you've got one wheel spinning. Easier than balancing three pedals if you've got a manual, and doesn't lock up the front wheels. Seems like it could help with either an LSD or an open diff.
    But again, I've never tried it... somebody stop me if I'm repeating bad advice :anonymous:.
