Locker mod problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jason'sLawnCare, May 24, 2009.
  1. May 24, 2009 at 12:27 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    To check the operation:
    With the key in the ON position, engine off, you press the RR DIFF LOCK button, you should be able to hear both the relay click and the electric motor on the diff. The diff lock light does not come on until the diff is locked. So you may have to roll forward a little to lock it. It does not flash and beep when the button is pressed and diff not locked. But, if you can hear the locker motor run you know the mod is working.
    Before correcting the connections on the relay, I would hear the relay click, but not the elect. motor on the diff.
  2. May 24, 2009 at 12:43 PM
    jolayiv
    jolayiv Carolina Alliance
    Jim
    Hertford NC
    07 DC TRD 4x4 Off-Road
    Revenge-Fab Sliders, AVS Vent Guards, Rear TSB, Hose clamp MOD, Locker MOD, Flowmaster 40 Series Delta Flow, Midland Radio, Wilson 1000 antenna, Rear Diff breather MOD, Weathertech liners, Maglite mount, Bed Divider, LEER 100XR, Pop&Lock
    Your right. I was thinking 4LO for some reason.
  3. May 24, 2009 at 12:46 PM
    DDD
    Derek
    Santa Clarita, CA
    Before completing this mod, my light would flash and beep until the lock actually engaged. Now I see and hear nothing until it is completely locked.
  4. May 24, 2009 at 12:48 PM
    DDD
    Derek
    Santa Clarita, CA
    Maybe he is out having fun with the locker...
    :burnrubber:
  5. May 24, 2009 at 12:49 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    probably
  6. May 24, 2009 at 12:51 PM
    Jason'sLawnCare
    Jason'sLawnCare [OP] Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Yeah i had to go find some dirt to fully test it. It worked as expected thank you so everybody especially db67fm. You are my savor. My father and I were pulling our hair out for hours trying to figure out what the heck it could be.
    Thanks for your concern rmb.
  7. May 24, 2009 at 12:53 PM
    rmb_crew
    haha np we will have to try it out soon.
  8. May 24, 2009 at 12:53 PM
    Jason'sLawnCare
    Yeah I def had the same problem as db67fm. I bet this thread will help alot of people out that are experiencing similar problems.
  9. May 24, 2009 at 12:54 PM
    Jason'sLawnCare
    Yeah. definatly. Maybe next weekend we can get a group together and find a place to have some fun.
  10. May 24, 2009 at 12:55 PM
    rmb_crew
    i cant next weekend. I will be up in atlanta. I will post something in the jax section when i will be back in town and stuff.
  11. May 24, 2009 at 12:55 PM
    DDD
    Derek
    Santa Clarita, CA
    Thanks. I sat there for about 1 hour yesterday looking at the pdf and comparing it to the relay package.
    I am just glad nothing broke when we originally hooked it up incorrectly. Someone should update that PDF to add this relay.
  12. May 24, 2009 at 1:04 PM
    Jason'sLawnCare
    Yeah. I'll see if I can edit it later when I get back.
    rmb we can do something another weekend whenever you're not busy. My mom will be much more excited about going if she sees Ava. Of course though there's no obligation to bring her.
  13. May 24, 2009 at 1:05 PM
    rmb_crew
    haha yeah she comes with me most of the time so she will probably be there.
  14. May 24, 2009 at 6:17 PM
    Jason'sLawnCare
    Hey guys check it out. Look at the cheap/free mods thread. You can find it in the mods and tutorials v. I wrote piercedtiger(the god of the cheap/free mods thread, one of the best threads known to man imo) and he edited it to let the people with the radioshack relay know that there's a difference in the config.
  15. Dec 20, 2009 at 7:50 AM
    #35
    kwelklin
    kwelklin Well-Known Member
    Northeast Michigan
    15 TRD OFF-ROAD DC
    Reviving this thread as testmony that I did search first. Same problem that JLC had, 2008 no lights, no movement in the relay, and don't hear the locker motor at all. I am using the 275-217 relay which is 125vac as recomended in the intial write-up. Will this actually work with 12v dc or do I need to get the 275-218 part?
  16. Dec 20, 2009 at 8:19 AM
    #36
    DDD
    Derek
    Santa Clarita, CA
    I think you need a DC relay.
    I have not tried the AC, but I don't think it would work.
  17. Dec 20, 2009 at 8:33 AM
    #37
    kwelklin
    Northeast Michigan
    15 TRD OFF-ROAD DC
    Dang-it! I wonder why that part would be recomended?
  18. Dec 20, 2009 at 1:00 PM
    #38
    Jason'sLawnCare
    I don't know why either. You should be able to return the other one. Radioshack seems to be pretty good about that.
  19. Dec 20, 2009 at 2:34 PM
    #39
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Was there an issue with the relay mod throwing a CEL when doing this? Or was that if you spliced it in? The whole reason I haven't done this mod is cause I really don't want to throw a CEL and have the vehicle get pissy with me.
  20. Dec 20, 2009 at 2:36 PM
    #40
    Jason'sLawnCare
    No CEL for me. The locker just couldn't be activated in anything before db67 told me it's different for the relay we had.
