Locker mod problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jason'sLawnCare, May 24, 2009.
  1. Dec 20, 2009 at 2:37 PM
    #41
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Is that a fact.
    Hmmm, I might have to hit the Radio shack later this week.
  2. Dec 20, 2009 at 2:39 PM
    #42
    Jason'sLawnCare
    Jason'sLawnCare [OP] Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    It's awesome. You should do it. Just obviously take it slow so you don't cut the wrong one.
  3. Dec 20, 2009 at 2:39 PM
    #43
    kwelklin
    kwelklin Well-Known Member
    Northeast Michigan
    15 TRD OFF-ROAD DC
    CEL? Barney me please
  4. Dec 20, 2009 at 2:40 PM
    #44
    Jason'sLawnCare
    Check Engine Light.
  5. Dec 20, 2009 at 3:18 PM
    #45
    kwelklin
    Northeast Michigan
    15 TRD OFF-ROAD DC
    Thanks, I'm the village idiot here!
  6. Dec 21, 2009 at 2:47 PM
    #46
    Jason'sLawnCare
    Haha. No problem.
  7. May 4, 2010 at 9:49 AM
    #47
    sbram500
    sbram500 Active Member
    NC
    11 dbl cab 4x4 trd off road
    3" lift, Rock sliders, Fog Light Anytime Mod, Vent guards, Full-Tilt Extang Bed Cover, More to come
    Hey guys, I know this is an old post, but I wanted to ask for some input.
    I have done this mod on my 07 and had no troubles for about 2yrs. now all of a sudden my locker won't engage at all. the indicator light on the dash doesn't come on at all, but I can hear my relay clicking.
    Had it in at Toyota for a service and mentioned that my locker wasn't working and they called me out on the modification... said they would have to charge me 80 bucks to rewire it back to stock then troubleshoot it. Any ideas, maybe bad contacts on the relay??
  8. May 4, 2010 at 11:25 AM
    #48
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    is your 4WD and 4Lo still working propper? i'd get a new relay and try it before you have the dealership go after it...even though it's still clicking...it may be bad. if 4WD is still working, your computer should be OK...maybe a bad actuator (locker motor)? take the actuator off and have the dealership test it for you? anyone know if there is a dedicated fuse/relay for the e-locker actuator? might be simple as something like that.
  9. May 4, 2010 at 3:18 PM
    #49
    Jason'sLawnCare
    I would replace the relay. It's cheap and if it doesn't work you can always return it to Radio Shack. Also I would check fuses. Just be aware it may reset your trip odometer if you pull out one of the fuses so if you care about it then right it down. I wish I could be of more help but I really don't know much about the electrical stuff.
  10. May 8, 2010 at 11:37 AM
    #50
    sbram500
    NC
    Hey guys thanks for the input. I did replace the relay and that did not SEEM to fix it right off. I began searching wiring diagrams and checking voltage and continuity and after way too much of that I decided to attempt the removal and inspection of the actuator. I removed the tiny little "skid plate" back there and removed the wiring connectors and one more time for good measure checked to see if voltage was present when I engaged the locker switch. There was so I dis-engaged the switch and (with the rear just barely off the ground) re-connected the wiring harness, grabbed a rubber mallet and "tapped" on the actuator. Then I tried it one more time. Engaged the switch and began to slightly rotate one of the tires and CLICK!!! the locker immediately engaged.
    Don't kow if it was truely the relay, reconnection of the wires at the rear (I put some dielectrical grease on those connectors while I had them off), or the hammer method, but it is working again.
    Thanks for all the input.
  11. May 8, 2010 at 11:44 AM
    #51
    Jason'sLawnCare
    Glad you got it working again. Thanks for letting us know.
  12. Feb 10, 2011 at 3:52 PM
    #52
    Bamfs01
    Bamfs01 Well-Known Member
    Magnetic Gray TRD Offroad. Locker, ATrac, DAC
    Stock leaf pack with TSB AAL, Wheelers progressive 3 leaf AAL, and Bilstein 5100's in the rear. Front OME coilovers with 885 coils. Cab mount chop. http://www.tacomaworld.com/forum/wheels-tires/37734-how-tire-rub-cab-mount-mod.html rcbs204 4x4 Illuminated Switch. http://www.tacomaworld.com/forum/lighting/68173-rcbs204-4x4-illuminated-switch.html JBL P963 6x9's and an MTX 10" sub wired inline to the stock HU with a MTX Jackhammer 404 amp. Rear diff breather relocation mod.
    Sorry to bring up this old thread... Could someone please tell me which is the (F12) ECU wiring harness? This is a photo of behind the glove box in a 2011 Tacoma TRD Offroad:
    F12 ECU wiring harness? by Bamfs01, on Flickr
  13. Feb 11, 2011 at 11:33 AM
    #53
    Jason'sLawnCare
    I'm not sure. That looks different than mine so basically this is just a bump.
  14. Feb 11, 2011 at 12:27 PM
    #54
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    I don't know which one is the F12 but in that photo if you are planning on doing the locker mod you'll have to remove the 10mm bolt in the center of the glove box catch and pull that piece of plastic off to get to the plugs on the 4WD ECU. I did this mod myself last weekend and wired a factory toyota switch into the power lead as a safety. It works great. Well once I figured out I had to drive about 10 feet to get it to engage. Before it would do it sitting still.
  15. Feb 11, 2011 at 12:59 PM
    #55
    Bamfs01
    Ok thanks 85GT 79FJ40
    I'm gunna pull that bolt and take a look. I may post another picture. I want to be positive I'm doing this properly before I even start.
  16. Feb 11, 2011 at 1:01 PM
    #56
    Jason'sLawnCare
    good idea lol
  17. Feb 11, 2011 at 1:43 PM
    #57
    Bamfs01
    This is it, correct?
    4wd ecu
  18. Feb 11, 2011 at 1:46 PM
    #58
    Jason'sLawnCare
  19. Feb 11, 2011 at 1:48 PM
    #59
    Bamfs01
    Will do, thanks Jason
  20. Feb 12, 2011 at 10:50 AM
    #60
    arrowthrower
    arrowthrower Well-Known Member
    Logan
    Henderson, KY
    2011 DC Tacoma TRD
    I am currently doing the mod on 2011. Not sure if the wiring scheme is the same colors as previous. Anyone else run into this? I will update as I go.
