Locker mod problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jason'sLawnCare, May 24, 2009.
  1. Feb 12, 2011 at 12:40 PM
    #61
    arrowthrower
    arrowthrower Well-Known Member
    Logan
    Henderson, KY
    2011 DC Tacoma TRD
    Got mine to work. All colors are the same. The only thing I ran into was that there are 2 blue. Make sure to use the larger blue. Everything else was the same. Works great.
  2. Apr 14, 2011 at 12:41 PM
    #62
    06taco
    06taco Well-Known Member
    Brendan
    South Jersey
    08 4x4 4-door TRD Sport
    *TRD Supercharger *3" OME lift kit *Dakar rear leaf springs *Total Chaos UCA *TJM T15 Plate Bumper *TJM Stealth 9000 winch
    So I thought I had it all figured out how to do the locker mod, pull the glove box off found the ECU and the correct wires, bought the 218 DC relay from radio shack and all the connectors and crimps but then I started to confuse myself! My questions are:
    1. Once I cut the wire, what side do I connect the female connectors too that go to the relay? The side of the wire coming from where ever their coming from or the side where the wire going to the clip that connects to the ECU or do i feed them both into the female connector? This might be a stupid question but I got myself so confused over this I figured I'd just ask to make sure I don't mess it up! I hope I made it clear so you guys would understand? Any help would be much appreciated! Thanks!
  3. Aug 12, 2011 at 6:42 AM
    #63
    Charged05
    Charged05 Active Member
    Colorado
    2005 TRD Charged 4.0 6SPD
    SuperCharged
    What about just hard wiring the locker to another switch? You may not have the light or anything but if it works it works.
    Has anybody tried that? or can it be done?
  4. Aug 12, 2011 at 6:45 AM
    #64
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    bad ground?
    do you have a locker? lol
  5. Aug 12, 2011 at 7:09 PM
    #65
    Black3144
    Black3144 Well-Known Member
    Bellevue, NE
    '07 TRD Off Road
    Alright so is everyone using the DC relay? My AC relay doesn't seem to be working, I've checked and rechecked the wiring. I checked power going to the coil and I have a good ground. Any advice???
  6. Aug 13, 2011 at 12:36 PM
    #66
    Black3144
    Bellevue, NE
    '07 TRD Off Road
    Well never mind, went out and bought the DC relay and it works fine. Not sure why the hell they say to get the AC relay when there's only 10 VDC coming out of the Black/Red wire. So for future reference buy the DC relay and save some time.
  7. Oct 8, 2011 at 8:20 PM
    #67
    falcon195
    falcon195 Member
    Micheal
    Kalamazoo
    Tacoma's and 4runners
    Headers, lift, exhaust, cold air, grill
    I need help trying to do the locker mod on my 06 trd tacoma. I got the relay you said to get, got the wires hooked up just like your picture but the relay isn't even coming on the connections are clean. So Idk
  8. Oct 8, 2011 at 8:27 PM
    #68
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    I heard from another member that radio shack has recently changed the pin numbers on the 275-218 relay. So the numbers no longer match my instructions.
    Please post a picture of the relay and the back of the package. I can give you new instructions.
  9. Oct 9, 2011 at 6:45 AM
    #69
    falcon195
    falcon195 Member
    Micheal
    Kalamazoo
    There are two greens for the power and there is a green for the ground but I have looked at your instructions and on my relay the numbers might be different. There are numbers on the bottom next to each out thing they go 1 and 4 is power witch are green 3 is pink 5 is blue 6 is LT green 7 is red/black 8 is ground and I'm going by your picture cause your numbering diagram changes on mine so Idk what to do now. [​IMG][​IMG][​IMG][/url[​IMG]
  10. Oct 9, 2011 at 8:00 AM
    #70
    DDD
    Derek
    Santa Clarita, CA
    Thanks for the pictures.
    Looks like radio shack changed the relay.
    Looking at the diagram on that relay I believe this should work:
    1 - Violet
    2 - Green/Black
    3 - Pink
    4 - Violet
    5 - Blue
    6 - Light Green
    7 - Ground source
    8 - Red/Black
    You should be able to plug in just pins 7 and 8 (no other wires) and press your locker button and hear the relay click. That will tell you that pin 7 is connected to a good ground source and the relay is working properly.
    Let me know how it works out for you.
  11. Oct 9, 2011 at 8:54 AM
    #71
    falcon195
    falcon195 Member
    Micheal
    Kalamazoo
    It works. I just bought another relay redid all the connections and it worked thanks a lot can't wait to try it out. One more question. I know a lot about lifts kits and what's good and bad. I don't like doing things hafeway. so I'm looking at a 4.5 rcd lift kit on 33s or a 6in fabtect on 33s wondering witch one would be better wondering if 6in is too much and if I'm going to run into problems.
  12. Nov 6, 2011 at 1:05 PM
    #72
    sernabe
    sernabe Member
    brian
    Casa Grande
    05 SR5 TRD
    SnugTop camper shell
    As always, TW is the greatest site!!! i just successfully mod'ed the taco with the any time lockers. the only issue i ran into was you need to reattach the F12 connector after your work is complete if you expect the lockers and 4 wheel drive to work properly!!! :)
    Thanks gentlemen.
    Next weekend is the music player mod!!!
  13. Feb 1, 2012 at 8:04 PM
    #73
    kriskross
    kriskross Shits & Giggles
    Monterey
    Former 2ndGen Owner, in the market for another
    See Build Thread
    Just finished my locker anytime mod. Had no real issues. Only took about 30 minutes and it worked the first time. Thanks guys!
  14. Feb 21, 2012 at 11:32 PM
    #74
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    A question. would locking the locker then hauling ass in the sand be safe?
    Locking while under 5mph THEN playing of course..
  15. Mar 14, 2012 at 4:55 PM
    #75
    Jason'sLawnCare
    Jason'sLawnCare [OP] Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    I've gone pretty quick with it before, just be careful not to turn too sharp with too much gas because there rear is more likely to spin out with it locked.
  16. Mar 14, 2012 at 5:22 PM
    #76
    DDD
    Derek
    Santa Clarita, CA
    I keep mine locked the whole time I am in Pismo.
    Locked and in 4wd high. Works well at Pismo up to 50 mph with tires at 15psi.
  17. Jul 12, 2012 at 10:47 PM
    #77
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    not to revive an old thread, but which wire harness going into the ECU did you guys tap into. there are two that go into the ecu, the top or bottom one?
  18. Jul 29, 2012 at 4:13 PM
    #78
    tacobox
    tacobox Evasive Maneuvers PMKMS
    It's the F12 connector. check the PDF and wire the 275-218 relay like this:
    1- Green / Black
    2- Violet
    3- Violet
    4- Pink
    5- Green
    6- Blue
    7- Red/Black
    8- Ground
  19. Aug 6, 2012 at 9:58 PM
    #79
    wagz502
    wagz502 Active Member
    Wagz
    NE Ohio
    2012 TRD Off Road
    Workin on it.....
    Does this mod work the same on a 2012?
  20. Aug 22, 2012 at 4:36 PM
    #80
    06taco
    Brendan
    South Jersey
    So after reading many articles on anytime locker mod I felt comfortable to give it a try. I follow the diagram as mention in this thread:
    1 - Green / Black
    2- Violet
    3- Violet
    4-Pink
    5- Green
    6- Blue
    7- Red/Black
    8- Ground
    I used Radio Shack 275-218 relay and upon completion I turned the ignition to "on" and engaged the locker button. I can hear the relay click and visibly see the relay switch so I figured it was good and time to try it out in the dirt.
    Once on the dirt I engaged the locker button and drove some circles and spun the wheels some but could not get the rear tires to lock up. I still only had one tire spinning? I engaged the truck into 4hi and 4lo and both worked but the weird thing was I didn't have any lights on the dash light up except for a yellow 4lo light when it was in 4lo.
    Shouldn't there be some sort of light that will light up in 4hi and also when the locker Is engaged? Any suggestions would be appreciated.
