Locker mod problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jason'sLawnCare, May 24, 2009.
  1. Apr 24, 2014 at 3:16 PM
    #121
    bueller
    bueller Well-Known Member
    AZ
    I've seen the same question asked on multiple locker mod threads and all have been unanswered. When cutting the wires, which end gets connected to the relay, the end coming from the harness or from the plug side that goes to the ecu?
  2. Apr 25, 2014 at 8:14 AM
    #122
    bueller
    AZ
    Why won't anyone answer this, lol? :confused:
  3. Apr 25, 2014 at 8:22 AM
    #123
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    The end coming from the harness. The relay replaces the function of the ECU.
  4. Apr 25, 2014 at 8:29 AM
    #124
    bueller
    AZ
    Thank you. I figured as such, but didn't want to wire anything wrong and screw something up.
    I tried the other single wire method and I didn't like that I would have to unlock and turn off the switch to get out of 4HI.
    I haven't opened it back up to check wire colors. Has anything changed for a 2013?
  5. Apr 25, 2014 at 8:38 AM
    #125
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    I don't think the wiring has changed for any 05+ tacoma.
  6. Apr 25, 2014 at 8:51 PM
    #126
    bueller
    AZ
    Success!! Tested it out and it works great. Mine is one of the ones that the locker light does not light until it locks. No blinking.
    Thanks for the help username :thumbsup:
  7. Jul 27, 2014 at 9:15 AM
    #127
    07terry
    07terry Active Member
    north carolina
    07 4x4 trd
    does this mod also work on 07 thanks in advance
  8. Jul 27, 2014 at 2:19 PM
    #128
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Yes it does.
  9. Aug 18, 2014 at 5:30 PM
    #129
    07terry
    north carolina
    07 4x4 trd
    i know tis looks like a hammered horse but , i am a recent discharged wounded warrior, my wife bought me a 07 crew cab 4x4 and the rear lock doesnt work in any selection will the mod help also when everyone says # 12345678 , they are talking about looking at the blades on the relay the two that are alike at the top starting left to right top to bottom that is order referred to right ? also if any trouble shooting would help my brother and dad took the actuator off it was clean as a pin inside , but are you supposed to be able to turn the worm gear and the contacts looked like new , also thy moved the rear fork into the locked position manually and it worked fine then un locked manualy and still no locking in 4 lo please help.
  10. Aug 18, 2014 at 7:14 PM
    #130
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    What does being a fubar joe have to do with it? (I am one too before you get huffy). The mod won't fix a fucked up locker motor, if that's what is wrong. They are kind of a pain to get locked. You saw the shift fork right? Well it slides a splined sleeve over the end of the axle and if the splines aren't aligned it won't lock. It helps to drive in an S pattern, as this lines up the splines. If the locker motor isn't spinning at all, it might need a tear down and cleaning. It's pretty common for them to go tits up, especially if they get submerged in water a lot. Here is a link on how to rebuild them. http://www.pirate4x4.com/forum/toyota-truck-4runner/698966-e-locker-actuator-rebuild.html
    If that's too complicated or you just want a new one you can buy them from the dealer or sometimes ECGS has them- http://eastcoastgearsupply.com/i-12068451-toyota-rear-differential-e-locker-motor.html
    Some other reading on the subject- https://www.marlincrawler.com/tech/guide/how-index-your-electric-locker-motor
    How to test your motor- http://www.customtacos.com/tech.old.../06toyrm/06toypdf/06rmsrc/rm2006ta/037008.pdf
    Good luck dude, let us know how it goes.
  11. Aug 19, 2014 at 12:41 PM
    #131
    07terry
    north carolina
    07 4x4 trd
    i tried the mod and my relay sounds like a motor running so i went back to r/s and got another and same thing any answers
  12. Aug 19, 2014 at 12:44 PM
    #132
    07terry
    north carolina
    07 4x4 trd
    sorry didnt finish my thought , what i meant to say is that being said it takes me a pretty good while to do this and of course i have to have help so it may be a while till i get to try and report back , sorry also i tried it and my relay sounds like a motor running got a new and same thing ?
  13. Aug 19, 2014 at 3:07 PM
    #133
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    The relay shouldn't make any noise other than "click" when you turn it on. Maybe find someone who is smart on electronics give you a hand, if you were closer I'd offer to help myself man.
  14. Aug 25, 2014 at 5:19 PM
    #134
    Taco5326
    Taco5326 Well-Known Member
    Fred
    Las Vegas & San Diego
    2014 TRD Off-Road 4x4
    Fox 2.5 coilovers w/ remote resi Fox 2.0 rear w/ piggyback resi Total Chaos UCS (mid travel) Icon Add-A-Leaf pack Front diff drop (1'') Demello Offroad front plate bumper Volant CAI with ram scoop and throttle body spacer AE 17'' Wheels Toyo Open Country A/T tires 285/70/17 with matching spare Trailer Products fiberglass front fenders Pop-Lock for tailgate Hoseclamp mod for tailgate Debadged Rear diff breather mod Rear fenders/flares/ trimmed 3'' Rear anytime locker mod Painted rear bumper Painted grille
    I know this seems to be brought back up, but I'm going to attempt as my first TW post to simplify this mod. I installed it today on a 2014 Tacoma TRD Off-Road.
    First off, the directions are kind of complicated in a way and don't give the full details. The pictures give you a good idea. So use them as a reference. Second, DO NOT use the Radioshack relay 275-0217 (120VAC). This is the mistake I made and it does not work.
    MAKE SURE YOU HAVE RADIOSHACK RELAY 275-0218 (12VDC).
    Once you get behind the glove box, DO NOT remove the CPU. Its the black box on the right side looking at the glove box directly behind the plastic. If you take it out with the 2 screws its a pain to get back in. You can slide it off the bracket but theres no reason to and its in there tight. You will probably just break something.
    Make sure your locker is disengaged and truck off. You do not have to disconnect the battery since with the RR DIFF LOCK button off you don't get power to the wires anyways.
    One confusion is which connector piece do you cut the wires on? Cut from the connector that has the VIOLET and the WHITE. Some of the other colors are the same with the other connect.
    Another confusion is which end to you attach the spade connectors. You want to attach them from the HARNESS SIDE, not the ECU side.
    Once you get all the connectors on, this is how to attach them:
    1. Violet
    2. Green/Black
    3. Pink
    4. Violet
    5. Blue
    6. Green
    7. Red/Black
    8. Ground
    I had some connections reversed and to disengage the locker I had to press the RR DIFF LOCK button to ON.
  15. Dec 29, 2014 at 11:33 AM
    #135
    dipstiktaco
    dipstiktaco Well-Known Member
    canada
    2006 TRD off road access cab auto URD supercharged
    Attempted this mod today. The relay clicks but for some reason my 4wd light comes on when I push the locker button, and the locker doesn't actuate ??:eek: any ideas as to what I did wrong? Check the wiring countless times and it's right according to the diagrams.
  16. Dec 29, 2014 at 11:49 AM
    #136
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    If the 4x4 light comes on then you definitely hooked up to the wrong wire somewhere. The light for the locker is red and does look similar to the 4x4 light except the 4x4 is green.
  17. Dec 29, 2014 at 12:04 PM
    #137
    dipstiktaco
    canada
    Excuse the electrical tape but that's my set up right now. The only green wires I have is the light green and the green/blk ones.
  18. Oct 11, 2015 at 9:33 PM
    #138
    bueller
    AZ
  19. Nov 21, 2015 at 5:00 PM
    #139
    jimsprotacoma
    jimsprotacoma Member
    James
    2015 Tacoma trd pro
    That 12v relay is not avalible anymore anyone know of a good replacement
  20. Nov 21, 2015 at 10:22 PM
    #140
    PSU Taco85
    optional
    Use of any standard DPDT switch or relay will work
