locker
Discussion in 'Off-Roading & Trails' started by Wildtaco, May 4, 2009.
  1. May 4, 2009 at 4:17 PM
    Wildtaco
    Wildtaco [OP] Active Member
    Anybody know whare i can get a E-locker for he rear for a 96 tacoma???
  2. May 4, 2009 at 4:32 PM
    Wildtaco
    I just want a locker and i have heard good things about a E-locker
  3. May 4, 2009 at 4:38 PM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
    I have an ARB in my 07 and I love it, But you cant go worng with a E locker.
  4. May 4, 2009 at 4:49 PM
    Wildtaco
    The air line kinda bothers me. I feel like im going to rip it off. But i do love ARB lockers
  5. May 4, 2009 at 4:49 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    How are you running the on board air setup? Is it just sitting in your tool box or something?
  6. May 4, 2009 at 4:52 PM
    silver07taco
    COIL
    Maryland
    My air lines up tight to the body so if I rip it off im goin to do some more damage:rolleyes:
    I have a main OBA in the tool box for tires and what not and the ARB comp under the hood, Its alot nice them taping off the main OBA
  7. May 4, 2009 at 4:55 PM
    rmb_crew
    Oh nice. Thats a sweet set up.
  8. May 4, 2009 at 4:59 PM
    silver07taco
    COIL
    Maryland
    Thanks, It works like a champ
  9. May 4, 2009 at 5:22 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    My air line is stainless steel braided. Plus, it's tucked into the frame.
  10. May 4, 2009 at 5:24 PM
    Wildtaco
    whare did you get the arb locker from
  11. May 4, 2009 at 5:24 PM
    silver07taco
    COIL
    Maryland
    Ive want that air line, Just have to add it to the list:D
  12. May 4, 2009 at 5:25 PM
    silver07taco
    COIL
    Maryland
  13. May 7, 2009 at 11:12 AM
    SafetyDang
    SafetyDang get your facts straight
    Dang
    Anaheim, CA
    DC with 4x4 & MT Conversion
    Swapped to Manual Trans & 4x4
    To the OP
    If you don't have a E-locker now you need a whole axle unless you some how have the 8" rear end. The E-Locker will only fit on the 8" (4 runners have them). If you have a Prerunner you most likely have the 8.4" rear end and will have to swap out for a 8" rear with E-Locker for a selectable locker. As far as selectable lockers go you only have 2 options. E-locker 8" (400-1000+) axle swap or get a Air Locker which is only ARB locker (1000+). Both are equal in cost unless you get a good deal on a wrecked TRD Tacoma. Other options for lockers are Detroit (300-500) which is a DD friendly locker as well as TrueTrack (300-400) which also has a DD friendly version. They also have Truetracks (200 or less) non DD friendly for less. Theres many other companys out there for Full time lockers/ Auto lockers. And if your rig is non DD then you can just weld the thing. If you want a more selectable set up I would go with a ARB in your current axle, because Running a Full/Auto locker up front is not ideal and causes lots of binding. And a E-locker for the front of the Tacoma is non exsistat.
    Hope The info I have given you will help you make your choice.
    As for your question. Try TTORA for a E-Locker and Axle. Or your local junk yard but most of the time TTORA.com will have a better deal.
  14. May 7, 2009 at 1:23 PM
    silver07taco
    COIL
    Maryland
    How do the lockrites work? There not full time locking?
  15. May 7, 2009 at 1:28 PM
    silver07taco
    COIL
    Maryland
    O ok, ive hurd stuff about them just dont know how they work
  16. May 7, 2009 at 1:32 PM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    I've used Both the Lock Rite and Powertrax No-Slip automatic lockers (different variations of the same locker). They are cheap and reliable.
  17. May 7, 2009 at 1:32 PM
    silver07taco
    COIL
    Maryland
    I guess that explans it:D
  18. May 7, 2009 at 1:43 PM
    silver07taco
    COIL
    Maryland
    X2 that would be nice
  19. May 7, 2009 at 1:46 PM
    drew02a
    San Antonio, TX
    I'm fairly certain the reason they don't is because it would defeat your ADD system. It would make your front drive shaft spin all the time which would lower fuel economy and increase wear and tear.
  20. May 7, 2009 at 1:51 PM
    drew02a
    San Antonio, TX
    You may be right.
    It definitely would defeat your ADD though.
    I'd only do it if I also had locking hubs.
