Locking Diff vs. Slip Diff.
Discussion in 'Technical Chat' started by raycie, Mar 10, 2008.
  1. Mar 10, 2008 at 9:47 PM
    raycie
    raycie [OP] Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    K... thanks for dealing with me while I ask a slightly stupid Q..
    My '99 pre-runner TRD off-road had a rear locking diff (button on dash)
    Just bought a newly used '07 pre-runner sport DC LB.. at first I was bummed that he didn't get it with the locking diff, but now am reading that the sports come with full-time slip diffs..
    what is the main differences and what can I get into and what not with the slip diff.. do all TRD sports have the slip diff?
    Thanks..
  2. Mar 10, 2008 at 9:54 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    the LSD is best for normal on road use and the locking differential is for off-road use only. The LSD will not distribute equal amounts of torque, like the locker can; but the LSD is on full time.
  3. Mar 10, 2008 at 10:00 PM
    raycie
    Oahu, HI
    In need of $$$
    So.. I would throw on the locking diff when I would go slight off-road (nothing to wild - and probably didn't even need it).
    Anyone know the environmental limits of the slip diff?
  4. Mar 10, 2008 at 10:08 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    that's a hard question to answer, since I can't compare it on and off. I've almost gotten stuck in some slippery mud, but I'm not sure how far I was from being stuck. I'd feel better offroading with the locker because I would leave the locker off until I got stuck, then I'd still have the option to turn the locker on.
    If you want to add the locker, I think you lose out on the LSD.
  5. Mar 11, 2008 at 6:08 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  6. Mar 11, 2008 at 6:10 AM
    Janster
    Jandy
    Lancaster, PA
    Yes, absolutely.
    Both require changing the differential carrier, and both would require setting up your gears again.
    You can't have both.
  7. Mar 11, 2008 at 11:02 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    "The only stupid question is the one that doesn't get asked..."
    These guys have really answered your questions. The LSD is great in most situations. It really shines when you are towing and have minimal weight on the rear axle on a slippery surface.
    The only bad thing about the LSD (and why I am a bit bummed I am getting it in my new truck) is that the TRD LSD is clutch driven. Therefore, the clutch can wear out (just ask the X-Runner guys). It may take a while, but you will need to replace it far down the road. How far down the road depends on how you drive. The good news is that it will continue to work as an open differential even after the LSD clutch has burned up. So, it is reliable, but it does require maintenance.
    I hope that helps.
  8. Mar 13, 2008 at 7:28 PM
    Burban05
    Burban05 Member
    07 4x4 33x12.5 bfg mud 6speed diff lock
    3" 33x12.5 bfg mud terrains, k&n cold air, alpine doubledin touch screen, rockford power 600.4, rockford 6.5's, rockford power 12" p3s blacked out
    IF you know anything about offroading, you know that anyslip can kill you. as soon as you loose momentum. locked differentials mean that the tires always spin and dont slip. and you cant just get stuck then lock the differentials in when your stuck and expect to get out. put the truck in 4lo, lock the differentials use second gear. no rockcrawler has limited slip. every real offroader has at least welded axles.
  9. Mar 14, 2008 at 6:44 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    Maybe another term for the glossary," Lincoln Locker" as in Lincoln Arc Welder.Refering to welded spider gears.
  10. Mar 14, 2008 at 7:08 PM
    Janster
    Jandy
    Lancaster, PA
    Ummm.... I've gotten stuck many times and reached down and engaged my locker/s and was easily able to get out. It's most fun when you're climbing an extreme hill climb and you start loosing momentum on the way up. Your vehicle is sitting in one spot with 2 wheels turning.... reach down, engage rear and alot of times, the front locker and.........boom, you're going up the hill again.
    Real offroaders have welded axles? That's news to me....
    The HARD CORE & extreme offroaders have welded spider gears. They also have heavy duty axles too (like Dana 60's, rockwells, and portals).
  11. Mar 14, 2008 at 9:55 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    there is no need to be a prick. please take your attitude elsewhere. TW is a fun loving forum.
    I'm aware how important momentum is. I don't take my truck offroading, but I've been mountain biking for 15 years. Fat guys like myself depend on that momentum to get us through the rolling hills.
    By the way, you seem to have almost completely missed my point. I was saying that I would rather not push my truck to its limits when I've got nothing else up my sleeve.
    Thanks Janster.
  12. Mar 16, 2008 at 9:29 PM
    Burban05
    Burban05 Member
    at least welded axles is what i said... i was just saying... if u dont want to get stuck, then u need to obviously alread in 4, and its better when your already locked... but ya. im sure u already knew this but hill climbing is one of the reasons the new tacoma's have the clutch start cancel switch... when u get almost all the way up and your truck cuts off from loosing oil pressure, u leave it in first and use the starter to get u the rest of the way up... but ya i thought that was cool when my bro told me that... my cj5 has rockwells under it but right now it only has 40s but im gonna get the 6.67s for it and run 57s.. and the axles under it are welded too...
  13. Mar 16, 2008 at 9:56 PM
    Janster
    Jandy
    Lancaster, PA
    Never had any vehicle cut off because of oil pressure.... I wouldn't use your clutch cancel switch all that often or else you'll destroy your starter. Personally....I WOULD NOT trust the starter to drive me up an extreme hill climb sitation. I'd rather back-up and try it again or bypass the obstacle completely.
    40's? 57's? That's huge.... What kind of suspension do you have to run something like that? How much flex do you have? Doesn't sound like you've had much flex at all.
  14. Mar 17, 2008 at 1:37 PM
    Burban05
    Burban05 Member
    ya my brother is a fabricator... he has built everthing for the lift.... the axles are stretched as much as possible... it flexes pretty good though... like 10-12 inches...
