locking gas cap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bigguy78619, Jul 1, 2008.
  1. Jul 1, 2008 at 7:26 AM
    bigguy78619
    bigguy78619 [OP] Well-Known Member
    san diego, ca
    07 TRD Off-Road PreRunner DC
    does anyone have a locking gas cap?...does it mess with the emissions?...can anyone recommend one?...ive been a victim of a "gas sucker" and i dont want it to happen again.
  2. Jul 1, 2008 at 7:38 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    My concern would be the gas tank puncturer. I'm sure you've heard about people punching holes in the gas tank.
    yes, a few people have them and a few of them cause a check engine light. I'd have to search here to find one.
  3. Jul 1, 2008 at 7:42 AM
    bigguy78619
    san diego, ca
    no my tank was not punctured, the siphoned the gas out...all or it
  4. Jul 1, 2008 at 7:45 AM
    Banchi94
    Banchi94 Well-Known Member
    Ron
    Parker, CO
    2008 Indigo Blue TRD Sport DCSB 4x4
    ToyTec 3" basic lift
    Stant usually makes a pretty good one. The part number for 2005+ Tacomas is 10509. Take heed, though, I found a review about it recently posted on Amazon on June 2, 2008:
    "After reading the reviews on Amazon and multiple Toyota forums concerning this "locking" gas cap I called the manufacturer (STANT) and talked to a fella named Chris. He assured me that maybe 1 in 200 caps had a problem. He then added that the 10509 cap was being re-designed and the new version would be available in maybe 6 months. Based on the current problems with gas prices, theft (siphoning), and his statement that "1 in 200" had a problem, I bought one. TRUST ME .. It doesn't work at all!!! Called him again today and explained the problem. His response was "I told you we were re-designing it and you went out and bought one anyway?!" Now, if they knew the thing didn't work, why are they still selling it??? I'm out $22.00. I'll be contacting the Federal Trade Commission tomorrow. In the meantime, I'd advise NOT buying this product."
    Of course, this is one person's opinion, but I'm with Isocoee, you might have other problems with folks puncturing your fuel tank.
  5. Jul 1, 2008 at 7:49 AM
    bigguy78619
    san diego, ca
    i have a skid plate
  6. Jul 1, 2008 at 7:54 AM
    mmatheny
    mmatheny Well-Known Member
    Dickinson, Tx
    2017 SR5 DCSB Magnetic Gray Metallic
    BakFlip MX4
    Under your gas tank?
  7. Jul 1, 2008 at 8:00 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    BudBuilt makes a really nice one. :)
    I have a Stant locking cap for my 70 gallon tank and it's more for show than anything. To open it without the key, simply push down and turn. I figure it's at least a deterrent if not a real solution. Goes back to that whole "locks are for honest people" thing.
  8. Jul 1, 2008 at 8:01 AM
    bigguy78619
    san diego, ca
    yeah, my cousin own a fabrication shop and i had him fabricate sort of an enclosure, that will stop anyone from puntureing it but not from siphoning it. I lives really close to the mexico border in san diego and its more common than anywhere else.
  9. Jul 1, 2008 at 8:23 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    It is impossible to siphon gas out of the 05+ Tacomas.(Not sure about the older ones.) The filler is designed to prevent a hose from going far enough to make it into the tank. Go ahead and try. I double dog dare you! :p
    If you want the locking cap to keep vandals from pouring something INTO your tank that's a different matter and the locking cap would work.... But if someone's that determined to spoil your day they'd likely damage the truck some other way.
  10. Jul 1, 2008 at 8:26 AM
    bigguy78619
    san diego, ca
    i know that the tacomas actually almost all makes and models not have this coil set up for the gas tank so noone can siphon out gas....maybe the ailens took it!
  11. Jul 1, 2008 at 8:40 AM
    hondabuster
    hondabuster Active Member
    MN
    08 reg cab 4x2
    Tinted window,vent shades
    I took my stant cap, back for a refund. Mine didnt lock either...just keep unscrewing on it, and itll come off. What a BS design.:mad:
  12. Jul 6, 2008 at 8:43 PM
    blatant
    blatant Well-Known Member
  13. Jul 6, 2008 at 8:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Until someone punctures your tank from the bottom. :eek:
  14. Jul 6, 2008 at 8:53 PM
    ricepow
    ricepow Well-Known Member
    Vegas
    08 4x4 TRD Sport
    Mine works fine too as far as I know. Ill try to get it off without the key and if something changes Ill edit my post.
  15. Jul 7, 2008 at 1:04 AM
    ERdept
    ERdept Well-Known Member
    +1. No problems, works well.
  16. Jul 7, 2008 at 11:31 AM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Same here no problems. Have had mine since the day I bought the Taco. No CEL's Even if it fails to lock, which happened once, no CEL's. Good Product IMO
  17. Jul 7, 2008 at 11:37 AM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    A Locking Gas cap will only stop somebody who wants to dump sugar down your tank. If somebody wants to steal your gas, they will by simply drilling/punching a hole through your tank. It's quick and easy; especially with the ground clearance of our trucks. I'd rather have somebody siphon the fuel out for $80 than have to replace the gas tank at $300.
  18. Jul 7, 2008 at 12:07 PM
    N3VMM164
    N3VMM164 North East PA Junior TACO Member
    Bloomsburg,Columbia County,Pennsylvania
    2007 Double Cab Short Bed TRD White
    secondary air filter removal,ABS Mod, TSB work on Rear Springs,Added MFJ Power Strip for scanner,low band radio,high band radio , Hi-Lift Jack install in bed ,portable battery system for portable radio,rear window stickers,Tonneu Masters Tonneu Cover,
    I purchases a slant gas cap and have no problems. I also bought an other one when I ordered my current one so I have an extra. I'll be willing to sell it.
  19. Jul 7, 2008 at 12:48 PM
    LRH
    LRH Well-Known Member
    GA USA
    '07 2.7L PreRunner
  20. Jul 7, 2008 at 5:34 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    So you leave your windows down all the time too then, right? How about your keys? Do you leave them in your truck? Because, using your logic, the alternatives would be a lot more expensive than just handing your property over to thieves.
    Whenever someone uses this argument I always think of Full Metal Jacket:
    Gunnery Sergeant Hartman: Private Pyle, if there is one thing in this world that I hate, it is an unlocked footlocker! You know that don't you?
    Private Gomer Pyle: Sir, yes, sir.
    Gunnery Sergeant Hartman: If it wasn't for dickheads like you, there wouldn't be any thievery in this world, would there?
    No, I'm not calling you a dickhead, Stevie. Just illustrating a point. Plus, I never let the opportunity pass to quote Sgt Hartman.
