Locking hubs hard to turn
Discussion in '1st Gen. Tacomas (1995-2004)' started by 91Toyotabogger, Aug 31, 2008.
  1. Aug 31, 2008 at 7:44 PM
    91Toyotabogger
    91Toyotabogger [OP] "Loud Tires Can Save Lives"
    North Carolina
    91 4wd 5sp manual Pickup Standard cab white
    Mud Tires, CD player, CB radio with PA speaker, De-badged, window decals, Flow Master 40 series
    How hard is it to grease the hub assembly yourself??
  2. Aug 31, 2008 at 8:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Not hard. Just pull off the caps, and put some grease in them. Find out if they require it first, as some hubs dont like grease.
  3. Aug 31, 2008 at 9:21 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    yeah i think yours (guessing it is on your 91 you are referring to) you can just unbolt them CLEAN THEM its really important to clean them incase its some dirt or something that is actually causing them to be hard to turn, then pack little wheel bearing grease in and go. ( i prefer to take hubs completely apart and spray em down good with brake cleaner...use a good shop rag to wipe them down and let them sit and dry before re-install)
  4. Sep 1, 2008 at 7:31 AM
    91Toyotabogger
    North Carolina
    Thanks guys ill try that. The hubs have'nt gotten bad yet but i want to make sure they dont.
