Locking rear differential question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DAVE94LIGHTNING, Apr 12, 2011.
  1. Apr 12, 2011 at 8:04 AM
    DAVE94LIGHTNING
    DAVE94LIGHTNING [OP] Well-Known Member
    When the rear locker is active should the red indicator on the dash be flashing or solid ? The truck I tested was flashing red.
    Also when engaged I took some tight turns in a parking lot and didn't feel any binding etc...
    I'm looking to buy a 2008 TRD off Road truck and just want to be sure everything works
    Thanks
  2. Apr 12, 2011 at 8:05 AM
    hudhawk
    hudhawk #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    The light will flash until the locker is completely engaged, i wouldnt recommend driving while its flashing. Once its completely engaged the light will be solid red.
  3. Apr 12, 2011 at 8:13 AM
    O.C.
    O.C. Well-Known Member
    NE PA
    90 DLX => 08 DC Offroad
    Nerf bars,Rugged cover Future: Vent shades,Bull Bar
    Yup
  4. Apr 12, 2011 at 11:01 AM
    DAVE94LIGHTNING
    Ok makes sense. I'll keep it from moving until it is solid red. How long does it usually take?
  5. Apr 12, 2011 at 11:06 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    it should activate within a few feet if not right away...when you first start to use it, it can be stubborn, but after a few uses it seems to activate much quicker
  6. Apr 12, 2011 at 11:10 AM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    If you want to test it, get it into 4low (must be in neutral to engage). Put the truck back in drive and press the diff lock button. Turn the wheel slightly and roll slowly forward about 5 feet or so.
    The should allow the diff to line up and lock. When it happens the light will go solid.
    If you are doing this on pavement don't drive any farther forward or backward. Put the truck back in neutral, unlock the diff, and take it out of 4wd.
  7. Apr 12, 2011 at 11:15 AM
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    ^What he said. If you listen carefully I usually hear a click when it locks in. Usually I have to drive forward and turn a little, but I'm getting used to it on my new truck. Find a gravel lot if you can.
  8. Apr 12, 2011 at 11:27 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Sherpa Grand Teton/Crows nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights
    Were you in 4LO? If you didn't experience binding doing tight turns on pavement it sounds like you were in 2WD...that also explains why the locker light was just flashing. By the way...never drive in 4WD on pavement (see links in my signature below)
  9. Apr 12, 2011 at 3:18 PM
    DAVE94LIGHTNING
    Good info. I'll test it on a forgiving surface. So the locker works in 4low and 2 wheel drive also correct?
  10. Apr 12, 2011 at 5:40 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
  11. Apr 16, 2011 at 7:02 PM
    David K
    That was easy!
    Sadly, in reality... it can take multiple tries to get it to lock... Maybe another reason I like the A-TRAC better?
