Locking Rear Differential
Discussion in 'Off-Roading & Trails' started by SearchingTacoma, Jul 10, 2008.
  1. Jul 10, 2008 at 3:48 AM
    SearchingTacoma
    SearchingTacoma [OP] FunTruck
    Oakville, Canada
    04 SR5 TRD
    What is the deal with a locking rear differential? If I have a 2X2 with a locking rear differential, how close (in performance) does that make it to a 4X4?
  2. Jul 10, 2008 at 4:23 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    ...I'll try to explain the basics to ya...
    There's a few different 'rear differentials' on the tacomas.
    1) OPEN differential
    2) LSD differential
    3) Auto LSD
    4) Locking differential
    An Open differential (or open CARRIER) is what most cars/trucks have. Hard to explain - but when you make a turn, the rear wheels aren't going at the same speed or distance. Having this variance - the carrier needs to adjust for it allowing one wheel to stop turning (or slip). For example: If one wheel is in the air - all the power will go to the wheel with least resistance (tire in the air). Thus, the tire on the ground is sitting there motionless. That means, you're not moving at all.
    An LSD differential has a different carrier that allows for some traction in certain situations. It uses clutches in the differential, that force both wheels to be driven together up to a certain torque load when the clutches release and you have an OPEN diff. An LSD differential is better than an OPEN diff for traction offroad. The LSD is automatic and works at all times without you knowing it.
    3) An AUTO LSD (on trucks with VSC stuff) has an OPEN diff/carrier but uses the brakes to prevent any rear wheel to stop spinning. This is supposed to aid in tractin also...but I personally don't have any experience in how that all works.
    4) The Tacoma locking differential is selectable. That means, you can turn it on or off at anytime (Prerunners only). When the locker is OFF - you have an OPEN differential. When the locker is ON - the two rear wheels are LOCKED in. Both wheels will spin at the same rate all the time. If you have one wheel off the ground - the power will continue to drive both wheels.
    On the 4X4 models - you have to be in 4Lo range to turn the locker on.
    There's a heated debate on the capabilities of the locked 4x2 versus a 4x4.
    For ultimate offroading capabilities - you'll wanna get a 4x4 with the TRD Offroad package (rear locker).
    If you drive in any snow - I'd highly recommend the 4x4 with the LSD.
    In a 4x2 and have the locker - you should avoid using the locker for daily driving (unless you're in snow and need it).
  3. Jul 10, 2008 at 6:04 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    x2 on everything Janster just said.
  4. Jul 10, 2008 at 6:12 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    so wouldnt a 4x4 w/ auto lsd and a 4x4 w/ locker be fairly matched when offroad and in 4x4?
  5. Jul 10, 2008 at 6:18 AM
    Khaos
    Khaos Big Member
    Bryant
    Somewhat.
    But the LSD is gonna differentiate your power. The locker keeps your power locked equal between both wheels at all times.
  6. Jul 10, 2008 at 6:18 AM
    The_Hodge
    SC
    but if ur in 4wd...shouldnt all 4 tires be moving anyways?
  7. Jul 10, 2008 at 6:20 AM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    If buy fairly you mean slightly less than,I would say yes.Equal?? is a no.Refer to the "it's alive" again thread on 2x4 vrs.4x4.
  8. Jul 10, 2008 at 6:21 AM
    Janster
    Jandy
    Lancaster, PA
    Nooooooooooooooooooooooooooooo.........
    From what I understand, the Auto LSD uses the brakes simply to apply braking (pulsations I think) to the wheel that is slipping. Certainly it allows the wheel a 'chance' to gain traction again, but it has nothing to do with direct drive at the wheels.
    I would think even the mechanical LSD (LSD carrier) is better for traction than the Auto LSD - and I only say that because it's directly connected to the driveline via clutches.
    The locker - when engaged - is directly connected to the driveline. 100% power going to both wheels at all times.
  9. Jul 10, 2008 at 6:22 AM
    Ridingontrd
    Richard
    Laughlin,N.V
    What he said.In the dirt locked is where it's at.:cool:
  10. Jul 10, 2008 at 6:24 AM
    Khaos
    Khaos Big Member
    Bryant
    That's what most people believe. Keep in mind, our trucks only come with LSD/Locker/Whatever in the rear. The front is an open differential. In a situation where your losing traction up front, only one front wheel will spin. If you lose traction in the rear, your differential is gonna differentiate power to whichever wheel has no traction to regain traction. Thus your wheels that do have traction get no power and the wheels that don't have traction do, making you get stuck.
    This is why lockers are good. You have guaranteed power to both rear wheels (and front if you have a front diff locker).
    I hope that made sense. I didn't sleep last night and am basically kept awake by large amounts of caffeine.
  11. Jul 10, 2008 at 6:25 AM
    The_Hodge
    SC
    but what about my second question?........if ur in 4wd...shouldnt all 4 tires be moving anyways?
  12. Jul 10, 2008 at 6:34 AM
    Ridingontrd
    Richard
    Laughlin,N.V
    While on flat ground,yes.( Not meant as a wise crack.)
  13. Jul 10, 2008 at 6:57 AM
    Janster
    Jandy
    Lancaster, PA
    Depends on the terrain and the situation....
    The front & rear axles work seperately from eachother (so to speak). Power is not tranferred front to back.
    OPEN DIFF (non locked) - If you're stuck in a ditch with both passenger side tires (front & rear) in the air....they'll both spin and you won't have any forward momentum at all - you're stuck. That's because the open carrier forces all the power to the path of least resistance (tires in the air).
    Take the same scenario....you're stuck in that same ditch with passenger side tires in the air (front & rear) - but you engage that rear locker..... then you will be able to drive yourself out because ONE wheel (rear driver side) will have ALL the torque on it to drive out of the ditch (atleast until the other tires reach ground/traction.
    On a side note: ONE wheel drive (so to speak - as listed above) can be very bad because you're putting all that much torque on that one wheel which can cause breakage much easier and quicker.
  14. Jul 10, 2008 at 6:59 AM
    The_Hodge
    SC
    damn...i wanted to get a 4x4 sport, but u guys might be making me change my mind...lol
  15. Jul 10, 2008 at 7:33 AM
    Janster
    Jandy
    Lancaster, PA
    I guess you don't get much snow down in S.C.?
    If not...than yeah, the TRD locker is the best choice for offroading.
    The LSD is better for us wintery driving people who want a little extra insurance (traction) in the snow.
  16. Jul 10, 2008 at 7:38 AM
    The_Hodge
    SC
    SC/NC....uh no....lol the LSD works well on the trails and beach. it definately worked like it should, but now the 09's went to the auto lsd as a standard feature....so that kinda blows
  17. Jul 10, 2008 at 7:54 AM
    klown
    klown Tacoma World Ring Leader
    Lynchburg, VA
    2008 TRD sport 4x4 double cab 6-speed
    Black, leather and heated seats, borla sport exhaust, side curtain airbags, daytime running lights, all weather mats, JBL premium 6 disk changer system, stainless step tubes, window tint, tow package
    So in 4x4 mode with a TRD sport which has a LSD. The front wheels are still locked right?
  18. Jul 10, 2008 at 7:56 AM
    Khaos
    Khaos Big Member
    Bryant
    Front differential is OPEN in every Tacoma. The only way to have the front diff locked is with an aftermarket locker.
    Atleast We get ATRAC in the '09s.
  19. Jul 10, 2008 at 7:57 AM
    The_Hodge
    SC
    the front wheels dont lock in a stock sport or OR. only the back. the front wheels should still move, however.
  20. Jul 10, 2008 at 7:59 AM
    klown
    Lynchburg, VA
    So then why is it so hard to make a turn on dry pavement in my TRD sport in 4HI?
