Locomotive throws a piston into a house.
Discussion in 'Off-Topic Discussion' started by Bama_TACO, Jan 28, 2011.
  1. Jan 28, 2011 at 8:29 AM
    98tacoma27
    Ben
    Not Beech Creek
    "Well, you're not going to believe this, but a Transformer flew over my house and took a huge dump......."
  2. Jan 28, 2011 at 8:35 AM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    You found my piston! I thought my taco seemed to be running a little rough here recently, now I know why, its in that dudes house!
  3. Jan 28, 2011 at 8:41 AM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    That one piston and jug probably weighs more than my entire 4 cylinder engine.
  4. Jan 28, 2011 at 8:49 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    That is a head and liner minus the piston. The head bolts failed. The round part is the liner. The squareish part is the head.
    Cylinder overpressure and failed head bolts. Notice there is nothing inside the liner. No con rod and no piston.
    Some, like me, also called it a power pack. It would have had a piston and con rod with it too. I worked on tug boat engines and have replaced many of them. Never seen that happen though. Must have been a design flaw.
  5. Jan 28, 2011 at 8:51 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Liner about 80lbs. Piston and con rod about 60 lbs. Head about 150lbs.
  6. Jan 28, 2011 at 2:22 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Crap. I just noticed the piston is still in the ceiling.
    I still stand by my design flaw theory. I saw the results of a 567 EMD throw a rod. Smashed the liner and piston to bits. Head stayed put. Engine kept running. It swamped the crankcase with cooling water from the broken passages in the liner. Wiped out all the bearings.
    FYI a 567 has 567cubic inches per cylinder.
  7. Jan 28, 2011 at 2:26 PM
    65tacodude
    65tacodude Well-Known Member
    Wade
    Manteno, IL
    '18 Tundra Platnium
    OEM running boards and roof rack. Yellow fog bulbs and WeatherTech mats and window visors.
    LMFAO
  8. Jan 28, 2011 at 2:56 PM
    mustangwilly
    mustangwilly Well-Known Member
    2017 DCSB OR Quicksand MT
