Loco's Mid Travel Badassery Build-Totalled
Discussion in '2nd Gen. Builds (2005-2015)' started by loco, Feb 9, 2013.
  1. Apr 23, 2015 at 6:51 AM
    #2941
    loco
    loco [OP] Who wants to ride my Brack Burrito???
    Phil
    Virginia Beach, VA
    1996 Diesel Land Cruiser AKA Brack Burrito
    Well its a land Cruiser with a diesel so I've got that going for me.
    There have been actual pictures of turds in toilets posted in this build so you could do no damage!
    For some people SUA is damn near a necessary mod...But for 99% it is a huge expense for very small gains and only in a very specific area. If I was living in So Cal and trying to huck my truck all the time as it's sole purpose in life I would think about SUA (More likely links but that's another discussion).
    It's a good debate and is very polarized. I am sure plenty of folks would debate it the other way with me all day long but it won't change my opinion.
  2. Apr 23, 2015 at 7:05 AM
    #2942
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    So what are you going to do, change the angle of the shock to try to squeeze more droop? Get into a bed cage with even longer shocks? Or just 4 link it and soon after solid axle swap the front?
    If you indeed want a rock crawler you might as well start that direction.
    You can sell me your 12" Kings :)
  3. Apr 23, 2015 at 7:36 AM
    #2943
    loco
    Phil
    Virginia Beach, VA
    Nahh Dawg I already fixed it....Just need to get it flexed to verify. Might pull out the hilift over the weekend.
  4. Apr 23, 2015 at 7:43 AM
    #2944
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
  5. Apr 23, 2015 at 7:56 AM
    #2945
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    But do you know the real reason they have SUA? You showed 2 examples of a truck with sua that can rock crawl. How many examples do you want to see of rock crawlers with soa? I can show you 2 examples of people who rock crawl with front LT. I can also show you 1000s of examples who rock crawl with SA. Does that mean you can't do it well with LT? No. Does it mean SA is better? Yes. There's a reason people build suspension components for certain types of wheeling. Just cause you can wheel well with it doesn't make it the best option. If you grew up around rock crawlers, you learn a few common sense things
  6. Apr 23, 2015 at 8:21 AM
    #2946
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Never said it was the best option... Nope totally oblivious as to why they have SUA, jebus, i've wheeled with both of them and know they love hucking their trucks. I've also crawled with them and know their travel numbers made the same trail way easier for them than me and im SOA...
  7. Apr 23, 2015 at 8:30 AM
    #2947
    2ndGenJonny
    Jon
    Gilbert, AZ
    Troof...
    Seen preprunners with SUA hitting 18" of droop and a spool make it up off camber rutted out hills with less effort than an FJ on 35s.
    In that kind of situation SUA is functional, but I've never seen one in a rock/ boulder bed.
    In AZ we have a mix of all of it. You could be blazing a wash one min and next starting at a giant waterfall covered in axle and trans fluid from last few trucks it claimed.
  8. Apr 23, 2015 at 9:00 AM
    #2948
    ajohnson
    Andy
    Charlotte, NC
    So... Can we get back to this Lamp dispenser?
  9. Apr 23, 2015 at 9:43 AM
    #2949
    loco
    Phil
    Virginia Beach, VA
    That's what I'm sayin! More Lamps!
  10. Apr 23, 2015 at 9:58 AM
    #2950
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    10 at a time,, yottamatt style.
  11. Apr 23, 2015 at 10:21 AM
    #2951
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Y'all also mention the fact that they had way more wheel travel then the others. Yes. A truck with 30" of wheel travel is gonna do much better then a truck with 10". But if you wanted to use that comparison then you could say my soa with 30" of wheel travel killed your SUA with 18" so it's obviously better. Or you could compare exact setup for setup and see which is better. SUA didn't mean more travel numbers. It's means travel numbers in a different range of motion then with soa.
  12. Apr 23, 2015 at 10:27 AM
    #2952
    2ndGenJonny
    Jon
    Gilbert, AZ
    Not arguing that one is better than the other. Yes, it is comparing an apple to an orange. I'm just simply stating that SUA can be functional given the right scenario.
    Personally, I'm staying SOA. If I really want to get deep into the rocks I can buy a used ftoy for around 6k. They are on CL every week out here.
  13. Apr 23, 2015 at 10:41 AM
    #2953
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    I completely agree. SUA is fantastic in the right scenario
  14. Apr 23, 2015 at 11:26 AM
    #2954
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
    This cracks me up! Big news coming up! stay tuned folks!
  15. Apr 23, 2015 at 11:48 AM
    #2955
    loco
    Phil
    Virginia Beach, VA
    I knew the reference would he caught by y'all.
  16. Apr 23, 2015 at 12:43 PM
    #2956
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    We caught it. Just too stupid to acknowledge.
  17. Apr 23, 2015 at 12:46 PM
    #2957
    2ndGenJonny
    Jon
    Gilbert, AZ
  18. Apr 23, 2015 at 2:43 PM
    #2958
    rjsimz
    rjsimz Well-Known Member
    Rob
    Huntersville, NC
    13 4x4 DCLB
    officially subbed to Coco's build. :spy:
  19. Apr 23, 2015 at 3:03 PM
    #2959
    ajohnson
    Andy
    Charlotte, NC
    Stupid fucking SUA talk. LAMP DISPENSER! We need to construct a cooker, basically a contained fryer with a holding bin that will pour X amount of Lamps into a basket. The basket will be on a motor and lower into the pan, on a timer of course. The basket will raise and pour the Lamps into the heated "cooked" bin (gotta keep them bitches warm til we're ready to munch!), where we can reach in and grab 5-10 Lamps at a time and stuff face!!!
    Here is a rough sketch I came up with
    We need to get rolling on this shit, dawg
  20. Apr 23, 2015 at 3:34 PM
    #2960
    loco
    Phil
    Virginia Beach, VA
    Hahahaha so here it is...the New DD... let the SAS conversion planning begin....
