Loco's Mid Travel Badassery Build-Totalled
Discussion in '2nd Gen. Builds (2005-2015)' started by loco, Feb 9, 2013.
  1. Aug 26, 2013 at 1:46 PM
    #441
    loco
    loco [OP] Who wants to ride my Brack Burrito???
    Phil
    Virginia Beach, VA
    1996 Diesel Land Cruiser AKA Brack Burrito
    Well its a land Cruiser with a diesel so I've got that going for me.
    I would imagine if icon was building them for you with the 700# springs right off the bat their wouldn't be any change in the price for your COs.
  2. Aug 26, 2013 at 1:49 PM
    #442
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Nice! The King's make sense then ;)
    I've got a quote from a vendor on here for $1020 for a pair of Icon 2.5's (Ext. Travel and non-RR) with Icon 700# coils, so I don't know how that compares to what you originally bought plus the new ones.
  3. Aug 26, 2013 at 2:20 PM
    #443
    loco
    Phil
    Virginia Beach, VA
    That sounds about right for price really. Like I said for them to install 700# springs doesn't make a squirt of piss difference as far as cost. I bet a 13" 650# spring like they normally use is $120 each as well.
  4. Aug 26, 2013 at 5:12 PM
    #444
    loco
    Phil
    Virginia Beach, VA
    Debating on getting a y pipe instead of having my stock exhaust rerouted...thoughts?
  5. Aug 27, 2013 at 1:24 PM
    #445
    loco
    Phil
    Virginia Beach, VA
    Bump anyone... y pipe?
  6. Aug 27, 2013 at 6:00 PM
    #446
    DaveEli
    DaveEli Well- Known Member
    David
    Virginia Beach
    2011 Tacoma Sport 4X4
    Icon Extended Travel Coilovers, King 700lb springs, All-Pro Expo leaf springs, All-pro U-Bolt flip kit, Icon 2.0 Series custom length rear shocks, Wheelers Superbump Bumpstops, All-Pro extended rear brake lines, Warn 86255 VR10000 10,000 lb winch, Warn 90287 wireless remote, Redline Hood Struts, AVS Bugflector II, Pelfreybilt front bumper with Rigid 92031 SR- Series White 20" Spot/Flood lightbar, Brute Force rear bumper with short swingarm, Famous Fabrication Rock Sliders, Pelfreybilt Skid Plates, Rigid 50231 D2 Driving Lights, Rigid 20221 Dually Spotlights, Rigid 98000 SR-M backup lights, ARB CKMTA12 "12V"on-board twin high performance air compressor, Dick Cepek DC-2 17x9" wheels, 285/70R17 Goodyear MTRs with Kevlar tires, Wet Okole seat covers,Airflow snorkle, ARE CX HD cap, Front Runner Slimline II cap rack, TRD cat back exhaust, AVS in channel window vents, Toyota door sill protectors, Pop & Lock tailgate lock, Husky Rear floorliners, WeatherTech Front Floorliners, DeeZee bed mat, Window tint, TRD drop in air filter, Plasmaglow led bed lights, Hi-Lift jack mounted on bed rail, IMMRYO Rear View Mirror Relocate, ARB 63 Quart fridge freezer, Arb ARB209 Snatch Block, ARB ARB730US 3" x 10' Tree saver, ARB ARB705US 2-3/8" x 30' recovery strap, Bubba Rope 7/8" x 30' original rope 28600 lbs, Bubba Rope Gator Jaw soft shackle 7/16.
    Hey, how will you install the coils, I still haven't found anyone to install mine for a good price. The guy at Production wanted $250 which I thought insane since I was going to bring in the coilovers off the trunk. Any ideas?
  7. Aug 27, 2013 at 6:05 PM
    #447
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    Bring them here and I will do them for you....I am off on Thursday.
  8. Aug 27, 2013 at 6:19 PM
    #448
    DaveEli
    David
    Virginia Beach
    Thanks, but I have to work.
  9. Aug 27, 2013 at 6:33 PM
    #449
    loco
    Phil
    Virginia Beach, VA
    Dave just remove them and take them and the springs to any automotive shop that can replace a strut. I can assist you in finding the right spot if you need.
    Just walk in and tell them you need the spring swapped. They will compress the spring and you can then lift up on the lower perch so it will slide off the coilover shaft. They will then release the spring allowing it to slide off the coilover as well now. They will then compress the new spring on the coilover till you can slide the lower perch back on. Hint hint it is a great idea to fully back off the adjustment ring while the spring is off!
    Take this info and the stuff to a shop and explain how these work...or call me and I will go over there with ypu. Should be less than 50 bucks and that I think is way too pricey!
  10. Aug 27, 2013 at 6:38 PM
    #450
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    I was going to take them to Langley AFB auto craft shop....do them for free...
  11. Aug 27, 2013 at 6:44 PM
    #451
    loco
    Phil
    Virginia Beach, VA
    I can do that at Norfork too but if Dave needs them done sooner it isn't to hard to explain to a grease monkey.
  12. Aug 27, 2013 at 6:51 PM
    #452
    CanisLupus
    Stokesdale | NC
    The rent-a-ble compressors might be really sketchy with the 700#'s...when me and another member used a rented set on my OME 885's (590#) they were kind of struggling even with those.
    Just try calling around to some auto shops and see if they will use their wall mounted sets. I've heard of guys on here doing that and getting charged around $50-$75.
  13. Aug 27, 2013 at 7:10 PM
    #453
    DaveEli
    David
    Virginia Beach
    I am trying to get everything that's sitting in my garage installed. I am tired of looking at it. Winch going on this weekend. Then UCA's and coils.
  14. Aug 27, 2013 at 9:15 PM
    #454
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    I did my 700 on rentable compressor with no problem and I was no where near safe with them. In fact I did it totally in safe :cookiemonster:
  15. Aug 28, 2013 at 11:40 AM
    #455
    DaveEli
    David
    Virginia Beach
    I have a compressor from Eastwood. It has 3 rods and u-bolts for safety. It's pretty stout and and the hooks fit the springs properly. I am just nervous (chickenshit) about using it. What could happen?
  16. Aug 28, 2013 at 12:11 PM
    #456
    wrmathis
    Bonaire, GA
    parts and stuff
    death
  17. Aug 28, 2013 at 12:12 PM
    #457
    FrustrationFabTaco
    FrustrationFabTaco Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
    didnt psu taco's snap when he was putting on 700's?
  18. Aug 28, 2013 at 12:21 PM
    #458
    wrmathis
    Bonaire, GA
    parts and stuff
    his did, mine didnt. hell on the second one i cranked down all the way on one side with teh impact then did the other
  19. Aug 28, 2013 at 12:23 PM
    #459
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    :eek:
    i need to put the new top hat parts on mine soon. this squeak is killing me :banghead:
  20. Aug 29, 2013 at 3:58 PM
    #460
    loco
    Phil
    Virginia Beach, VA
    Just off the phone with Billy...bumper wrapping up in the next few hours and should ship tomorrow or Tuesday because of the holiday. Woot woot!
