Long crank times when hot.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Triple-s, Nov 29, 2021.
  1. Nov 29, 2021 at 12:45 PM
    Triple-s
    Triple-s [OP] Well-Known Member
    So I have a 96 4 banger and with the high mileage but she still drives good. The problem I'm having is it cranks up right away on cold starts but if I drive it a bit and say stop to put gas and turn it back on it takes like 5 cranks to turn back on. If I were to let sit for like 15 min it'll crank right back up. Any ideas what to look for?
  2. Nov 29, 2021 at 12:47 PM
    Triple-s
    Also doesn't do it if it's really hot outside just if I drive it and does it every time.
  3. Nov 29, 2021 at 3:39 PM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    Hard starts.
    Interested in doing a tune up? I have some suggestions.
    Spark plugs (OEM) properly gapped and replaced if needed.
    Ignition coils checked and replaced if needed.
    I would continue tuning up..
    Spark plug wires if they are old.
    Air filter
    Fuel filter if you think that you need a replacement.
    Clean the MAF sensor.
    Clean the throttle body.
    Clean the Injectors.
    MalinoisDad and wilcam47 like this.
  4. Nov 29, 2021 at 3:55 PM
    Triple-s
    I've done all this already except take the injectors out for a cleaning. But I guess this should be my next step
  5. Nov 29, 2021 at 4:07 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe try a new coolant temp sensor; they’re cheap enough. Good luck!
  6. Nov 29, 2021 at 5:56 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Does it start okay if it's at operating temp and you turn it off, but start it again right away? Or, you let it sit for more than 30 minutes?
    If so, that's a sign of a leaky injector(s). If truck sits for 10-20 minutes, enough fuel leaks into the cylinders to produce a high fuel/low oxygen (too rich to ignite) condition. The extra cranking purges the excess fuel.
    Bivouac and wilcam47 like this.
  7. Nov 29, 2021 at 6:17 PM
    chainslap
    chainslap Well-Known Member
    Prescott, AZ
    95.5 SR5 V6 5spd 4x4, 2020 Tundra TRD DC
    I had similar problems with my truck. Would crank a lot longer if it sat for about 30mins. Thought injectors but it was actually a bad fuel pump. That was an aftermarket pump and not OEM though.
    wilcam47 likes this.
  8. Nov 29, 2021 at 8:37 PM
    Triple-s
    No it's at operating temp it won't start right back up takes a couple cranks to get it going.
  9. Nov 29, 2021 at 8:39 PM
    Triple-s
    You know i thought about that too any good way to check it?
  10. Dec 1, 2021 at 11:25 AM
    Triple-s
    So I took the injectors off this morning went and got them tested but they flowed good and didn't leak also got new screens and o-rings since I was there. I guess I'll try the fuel pump next when I get a chance.
    Steves104x4 likes this.
  11. Dec 1, 2021 at 9:09 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  12. Aug 5, 2024 at 7:08 PM
    Newtnewt
    Newtnewt New Member
    Chapel Hill, NC
    1999 Tacoma Prerunner 2WD Xtra Cab 2.7L 4cyl
    I’m having this exact problem with my ‘99 4cyl. When this happens, I’m able to get it to start with starter fluid.
    Did you ever figure it out?
    So far I’ve tried coolant temp sensor and fuel pressure regulator.
    In recent years I’ve replaced the MAF, fuel filter, injectors, and spark plug wires. I just ordered a new fuel pump.
  13. Aug 6, 2024 at 2:01 PM
    NC Gazzer
    NC Gazzer Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
    Had the same problem on my '96 2.7L. Any stop in hot weather would require either a lot of cranking or a cool down period before I could get back on the road. Can't say for certain that the problem was a faulty MAF, but one day the truck started running rough with low power so I did a scan that pointed directly to the MAF. Replaced it and all is good - no more hot start issue.
    Have you scanned for codes?
  14. Aug 7, 2024 at 4:44 PM
    Newtnewt
    Newtnewt New Member
    Chapel Hill, NC
    Wow that’s great that it went away after the MAF replacement! I actually had to replace my MAF a few years ago after I kept stalling out. Tried to replace it with two different ones from the store (they worked for a couple start ups and then quit) before I wound up having to get one direct from Toyota and all my problems went away.
    I scanned for codes, but nothing came up. I found today that my downstream o2 sensor is starting to fail and it’s a Bosch, so of course it’s failing. But thought maybe it’s sending incorrect data to the ECU and causing it to screw with the fuel injection.
    I replaced my spark plugs today and it looks like it’s running rich. Hoping maybe I just needed to change the spark plugs and that the new o2 sensor on the way will help. We shall see!
    Thanks for getting back to me! And glad to hear it went away for you!
  15. Aug 20, 2024 at 4:48 PM
    Newtnewt
    Newtnewt New Member
    Chapel Hill, NC
    Just following up in case someone else stumbles across this problem - it’s been starting up fine ever since I replaced my downstream o2 sensor. I never got a CEL for it, but was able to run a test on the o2s with a scanner to see that it was beginning to fail.
