Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Mar 14, 2013 at 1:59 PM
    NoSoup4You
    NoSoup4You Well-Known Member
    David
    Palos Verdes
    2008 DCSB DMZ LT 4x4
    Camburg | King | Glassworks | DMZ | Nitro | Banks | Pelfreybilt | Brute Force Fab | Bay Area Metal Fab | Baja Designs | Rigid Industries | STL
    The weak link are the fiberglass bedsides themselves, not the supports or the composite bed.
    The Tundra you have pictured is 1) a full metal bed, not composite with bedsides and 2) pulled OEM bedsides, not fiberglass
  2. Mar 14, 2013 at 2:03 PM
    Redgrom
    Redgrom http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
    = double fail on my part.... guess you can't trust google search results...
    Thanks for chiming in Landon..kinda hoped you might have seen something similar.
  3. Mar 14, 2013 at 2:07 PM
    NoSoup4You
    David
    Palos Verdes
    I'd be very interested in what you come up with. For rear LT I need to mount the pack rack somewhere else, or have a cage with mounting locations for my roof tent.
  4. Mar 14, 2013 at 2:07 PM
    Bandwagon
    Bandwagon Well-Known Member
    Escondido/San diego
    Camburg long travel, full glass,
    make something that either goes under the bedsid and attatches to the frame that holds the bedsides up and mount the glass right to it or go over the bedside where they sandwich toghether that goes thru the bed to the frame. like i said can be done pretty easily
  5. Mar 14, 2013 at 2:28 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    If any of you guys have a picture of your 2nd gen without the bedsides on, but with the composite bed still on the frame, can you post them up for me? Particularly from the rear.
    Trying to plan something, but won't see my truck for another 4 months.
  6. Mar 14, 2013 at 2:33 PM
    Redgrom
    Brent
    san clemente
    I'll keep you in the loupe, only issue is I just sent out a deposit to start the build. Will be 2 months before my truck sees the grinder:(. I'm going to do the rear in steeps. So it will be a few months till its totally ready.
  7. Mar 14, 2013 at 3:05 PM
    NoSoup4You
    David
    Palos Verdes
    cool.
    do you ever see the LT silver DCSB parked in front of Cycle Werks? I see it there sometimes on my way home and have been meaning to post a pic in the spotted thread. Stock rims, TT glass in the rear, I think maybe an Engage kit? Also a sick FJ with Total Chaos LT parked across from Sonny's almost every day too.
  8. Mar 14, 2013 at 4:00 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    I think you are talking about Rylee's tacoma
  9. Mar 14, 2013 at 4:29 PM
    Redgrom
    Brent
    san clemente
    I have checked out the FJ and its pretty sick. The silver taco by cycle werks front is all done but I think the rear is still SOA. Ill try to grab a shot and post it in the spotted thread as both trucks look pretty sick!
  10. Mar 14, 2013 at 4:31 PM
    NoSoup4You
    David
    Palos Verdes
    is he or she on TW? pretty clean truck!
    sweet, yeah I have been meaning to stop and look one of these days. it's always there so I always say "ehhhhh, next time, I need a beer" as I'm heading home haha
  11. Mar 14, 2013 at 5:06 PM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Do this. Just make a bunch of supports and it will work just fine.
    Will this work?
  12. Mar 14, 2013 at 5:12 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
  13. Mar 14, 2013 at 5:43 PM
    Mxpatriot
    RJ, I actually have that one, but thanks.
    I'm looking at my options to be able to have fiberglass bedsides but have supports built in for a bed rack.
    I ordered a roof top tent (and will soon order a Defined LT kit) and right now I plan on using my stock bedsides, but flaring them out. Eventually I want to run fiberglass bedsides, but supporting the bed rack and RTT will be an issue with that. I could always do something off the bed cage but right now I plan on using the stock bedsides and rail system to support it.
    I have two weeks when I get home to get the truck ready for a two week camping / wheeling trip. In those first two weeks I plan on:
    Replace all bushings in front suspension, replace tie rod heims
    Replace power steering rack
    Install 50'' LED bar on roof, 10'' on bumper
    Install defined LT
    Build bed cage
    Mount 3'' Fox 2.0 bumps in the rear
    Build bed rack
    Relocate battery to bed, build box for battery and recovery tools, rewire everything to the bed.
    Mount winch between the frame spars in the rear of the truck, run winch line through bumper and mount fairlead.
    Box frame
    Replace front coil springs, moving to 18'' 600 pound springs.
    Mount iPad on dash
    build custom dash piece out of kydex plastic, same stuff I have used to make holsters in the past
    Basically I'm going to be busy and I'm doing as much planning here as I can, so when I get home hopefully it all goes smoothly.
  14. Mar 14, 2013 at 5:59 PM
    JawKnee
    JawKnee I <3 Pink Tacos
    Ontario Ranch
    2002 Tacoma
    Total Chaos, DMZ, Deaver, Sway-Away, KMC, BFG, Hella, ICOM, BTF, Glassworks, Trac Performance, Lowrance.
    2D1091F1-7B7F-46B2-BCB4-F644AD0A0117-458_6d13a56e1066ed316585d7d70afe96e43c6beaaa.jpg
    Everyone come out!
  15. Mar 14, 2013 at 6:43 PM
    Redgrom
    Brent
    san clemente
    Still thinking about heading out to the desert in the afternoon?
  16. Mar 14, 2013 at 6:43 PM
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
  17. Mar 14, 2013 at 7:55 PM
    JawKnee
    Ontario Ranch
    2002 Tacoma
    Right after
  18. Mar 14, 2013 at 8:13 PM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Yes. We accept all major credit cards.
    :laughing:
  19. Mar 14, 2013 at 9:19 PM
    kcbmx
    kcbmx doing my thing.
    Marco
    Bakersfield CaLiFoRnIa
    2tr-fe 4wd
    spit cup, weathertech floor mats, riffle rack, and bilsteins.
    bmiller, emtmeyer, and myself (from left to right)
  20. Mar 14, 2013 at 9:34 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    who did your bumper? more pics?
