Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Apr 15, 2013 at 8:27 AM
    03aztaco
    03aztaco Well-Known Member
    adam
    lake havasu,mesa
    03 prerunner
    tc lt kit, king shocks, deavers, tc hangers,tc 12" shackels, king double bypasses, cab caged, beefed taco carrier bearing drop bracket, soild motor mounts,some more to lazy haha
    haha i have like 2" of up travel on mine at ride height:eek:
  2. Apr 15, 2013 at 8:35 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Really?
  3. Apr 15, 2013 at 8:51 AM
    03aztaco
    adam
    lake havasu,mesa
    03 prerunner
    ya really i never cycled my sua setup just mounted the shocks before full drop, i need to fix it i might take the challenge on this weeknd
  4. Apr 15, 2013 at 9:01 AM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
    Damn sic pic Adam, I will be out in parker again for my 21 bday on may 10-12
  5. Apr 15, 2013 at 9:03 AM
    03aztaco
    adam
    lake havasu,mesa
    03 prerunner
    thanks man, taking it you got you drive shaft handled? sorry i couldnt have been more help, let me know a couple weeks in advance before you go and ill try to make it back down there!
  6. Apr 15, 2013 at 9:05 AM
    precoma
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    For sure man, i appreciate your help, I found a drive line shop that got the u joint yolk for $30 so it was all good I didn't have to get bent over by Toyota lol
  7. Apr 15, 2013 at 9:08 AM
    03aztaco
    adam
    lake havasu,mesa
    03 prerunner
    hells ya
  8. Apr 15, 2013 at 9:12 AM
    esbyota
    esbyota Well-Known Member
    B-Rad
    AZ
    05 4x4 Taco
    New shock hoops is the only way to do it correctly. Shorter shocks isn't necessarily going to fix it.
  9. Apr 15, 2013 at 9:20 AM
    PLC721
    Patrick
    Chandler, Az
    Yeah i think that will be best all around!
  10. Apr 15, 2013 at 9:31 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
  11. Apr 15, 2013 at 9:45 AM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    quick ?. I can't seem to find what angle fitting to run with an 8" king coilover in the front to clear the mounting hat. I had some +1.5" arms made and the oem performance series don't quite hack it. Not much droop out of those things.
  12. Apr 15, 2013 at 9:50 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    best angles is to mount the coilovers 90 degrees or as close to that when the shocks are at full compression, so you have to cycle it.
  13. Apr 15, 2013 at 9:53 AM
    ntilehman
    Seth
    Charlotte, NC
    I wasn't clear on my question after I read it again. I meant the fitting for the hose going to the resi.
  14. Apr 15, 2013 at 10:00 AM
    esbyota
    B-Rad
    AZ
    05 4x4 Taco
    90 degree fitting...
  15. Apr 15, 2013 at 10:01 AM
    ntilehman
    Seth
    Charlotte, NC
    thanks. Now i need to get someone to buy my oem series shocks
  16. Apr 15, 2013 at 10:19 AM
    M C M
    M C M Well-Known Member Vendor
    Matthew
    Sin City, Nevada
    91 Toyota Pick Up, 02 Toyota Tundra
    Lots of expensive shit
    I hope its not a standard 8" king....
  17. Apr 15, 2013 at 10:30 AM
    ntilehman
    Seth
    Charlotte, NC
    Why do you say that? What would be better to run?
  18. Apr 15, 2013 at 10:31 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    Standard 6" will be better. The OEM shocks are like an 8" with a 6" body
  19. Apr 15, 2013 at 10:33 AM
    ntilehman
    Seth
    Charlotte, NC
    They have a shorter droop than the oem performance series. Why would you run that?
    Specs:
    2.5x 6" Coil Over Hose Reservoir (with springs)
    14.000 20.000
    2.5x 8" Coil Over Hose Reservoir (with springs)
    16.000 24.000
    Oem:
    Tacoma 05+ (6 Lug) Front Coil Overs
    16.750 21.687
  20. Apr 15, 2013 at 10:35 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
