Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Aug 25, 2014 at 11:42 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    A long travel Coilover is about 2 inches longer mid travel ext Coilover is like a 2.5x6 and lt is like a 2.5x8
  2. Aug 25, 2014 at 11:43 AM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    Length of the shock. Because of where it mounts on a LT vs MT the shock uses more stroke.
  3. Aug 25, 2014 at 1:16 PM
    Dj318
    Dj318 Well-Known Member
    Dylan
    Concord, NC
    02 Tacoma
    bilstein 5100, wheelers AAL, Trail gear bumper, SOS sliders, RAT skids, 35" Mtr/k
    Ahh got ya! Thanks!!!
  4. Aug 25, 2014 at 1:34 PM
    BradyT88
    BradyT88 Well-Known Member
    When talking ext travel vs non ext travel Coilovers, people are referring to model specific coilovers, ie those coilovers were specifically designed to fit the 1st gen Tacoma or 2nd gen Tacoma etc. I know for 2nd gen Tacomas they vary from about 4.5" to 5.5" stroke depending on the ones you get.
    The long travel coilovers are just a generic 8" stroke coilover. They are not specific to a Tacoma or any vehicle for that matter.
  5. Aug 25, 2014 at 2:21 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Generally yes, some kits require a non-generic shock to get all of the up travel. Mine are an 8" coilover but collapse to 14 3/8" instead of 16"
  6. Aug 25, 2014 at 2:23 PM
    BradyT88
    Yeah, guess I could have specified that they are slightly customizable to your needs.
  7. Aug 25, 2014 at 6:17 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Each to their own, but I personally wouldn't run a body lift on a desert truck unless the cab had solid mounts and the cab was plated to an internal cage. The extra leverage with a body lift is frightening.
    And while with LT you don't have the concern of hitting the frame, you can still hit the pinchweld. I only have 33's (285x75x16) and I rubbed the pinchweld full lock/stuff with my old wheels (4" BS). Adding another inch on the tire radius will certainly compound that. I still constantly hit my wheel well aprons at full bump.
    In the end it all depends on what the goal is for the truck. 35's take a lot of massaging to make work if you are planning on using all of the the suspension travel on a first gen.
  8. Aug 25, 2014 at 6:24 PM
    Trusso24
    Trusso24 Well-Known Member
    Tony
    San Luis Obispo
    99 Prerunner XCab
    Fox Coilovers Blacked Out Debadged
    Wish me luck!!
  9. Aug 25, 2014 at 9:19 PM
    JordanSmith127
    JordanSmith127 Jordemo805@yahoo.com
    JORDAN
    SAN LUIS OBISPO & MARIN
    2017 DCSB 4X4 TRD SPORT
    ICON / LSK
    you'll be fine your fully caged and balk-halved bro
  10. Aug 25, 2014 at 9:37 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Im with Jason. Id never do a body lift either
  11. Aug 25, 2014 at 9:53 PM
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    Nates truck came with the body lift on it.
  12. Aug 25, 2014 at 11:38 PM
    santabarbarataco
    santabarbarataco Well-Known Member
    jordan
    santa barbara
    In order for me to clear 35"s I took a huge portion of the fire wall/floor out and plated it back in and teimmed the glass 1.75" al the way around the edge. It was full weekend job but now it clears locked and stuffed in both directions.
  13. Aug 26, 2014 at 12:01 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sounds like what i did.
  14. Aug 26, 2014 at 1:41 AM
    troyboy162
    troyboy162 Well-Known Member
    troy
    I have a 1" body lift and just beat the firewall with a hammer till it cleared. You gotta monitor the ECU while you do that though because it ends up encroaching on the wire harness and you dont want to pinch that the wrong way (3rd gen 4runner/1st gen tacoma)
    also I have stock fenders cut but the tires stick out alot and locals laws may stop that from being a option.
    This was for mid travel. I beat it back a bit more for LT
    http://www.ultimateyota.com/showthread.php?8846-fitting-315-75-16-tires-on-a-3rd-gen-4runner
    body lift is undesirable from a center of gravity stand point, but 1" wont be something that will break or shear mounts off. for fitting 35" its pretty helpful to just save some time and effort. Again if you take the time to clear without a body lift you are ahead of the game.
  15. Aug 26, 2014 at 1:59 AM
    Rylee
    Rylee Well-Known Member
    Rylee
    Mission Viejo
    07 dcsb long travel
    Engage front kit, 35" hankook mt, Glassworks, Deavers.
    Agreed , negatory on a body lift IMO
  16. Aug 26, 2014 at 5:46 AM
    Dj318
    Dylan
    Concord, NC
    02 Tacoma
    Ok, thanks guys! I've decided just to go mid travel, but what uca would give me the most flex?
  17. Aug 26, 2014 at 6:33 AM
    anthony250f
    Anthony
    San Diego, CA
    Uca doesn't give flex...camburg 1.25 Uca will give the most droop
  18. Aug 26, 2014 at 6:36 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
  19. Aug 26, 2014 at 6:48 AM
    Bubbataco
    Bubbataco Well-Known Member
    Alec
    Hollister
    Baja Tx pro
    2 inch lift and tires
    Just a question would you think 35's would rub with a total chaos at full bump? Im already commited with the 35's and the total chaos kit, i was just wondering if i had to do some massaging
    thanks
  20. Aug 26, 2014 at 7:05 AM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    without a doubt, yes.
